Question about LG GSA-2166D DVD RW Dual Layer Burner
Not recognized on my computert
I just borrowed a friends simpletech 250gb hard drive. I wanted to copy his music. My dell computer with windows XP made a noice indicating it's recocnized but it does not show up under my computer.
    Problem Solver:
  • 19 Answers
Re: not recognized on my computert
Try rebooting with the drive plugged in. You can also manually add the drive by right clicking on my computer in the start menu, and selecting 'manage', In the manage window on the Disk drives section, right click on the usb hard drive's partition and assign a drive letter to it. Hope this helps you :)
Posted on Nov 30, 2007
0 characters
3 Points
What do i need for a computer to start burning or to creat a cd/mp3/dvd .
First you need music to put on the CD. You can put your own music CD in the drive and run Windows Media Player and rip them to your hard drive (copies them). After you get all the songs you want onto your hard drive, you can make an audio CD if you ripped the songs as WAV files (this CD can be played in most CD players) or you can make an MP3 CD if you ripped the songs as mp3 files (this CD can only be played in CD players that support the MP3 standard). To make the audio CD or MP3 CD, just download the free program called BurnAware from the internet and run it. Insert a blank recordable CD in your computer, choose Audio CD or MP3 CD, then choose the songs you want and burn the CD. That's it.
Nov 13, 2013 | LaCie (LAC300920) DVD±RW Dual Layer...
I'm trying to burn a music CD on my new HP computer and can't get the source disk to download to my hard drive. I'm an old dude and did print out the HP instruction sheet-still confused.
Hello rhughes612,
You may try burn by CD to CD burn but if you want to select files that you want to burn, you have to ripped the music from the Music CD by using Window Media Player 10 or higher. Or try using software that ripped music from CD.
This is the instruction of CD to CD:
1. Insert the source disk
2. Then hit burn or copy to CD on your HP CD & DVD burner software or application.
Then it will be temporarily copied to the hard drive.
3. after it finishes copying the source disk, you will be ask to insert a blank CD then hit continue or OK
Please reply or respond if this doesn't work so that I could provide you another solution and I'll get back to you as soon as possible.
Sep 22, 2011 | HP CD & DVD Burners
That's fine, you won't need the CD, just install the burner and the computer will automatically recognize it.
Nov 04, 2010 | LG GSA H62N Super-Multi - Disk drive - DVD...
I have a Dell. My Roxio prog doesn't recognize a discs
That means there is something wrong with your driver. If it cannot read any disc you inserted then the problem exist in your drive. You don't need to reinstall any driver as long as you can see your drive being recognized by your computer and you can see your drive in the My Computer with a letter indicated on it. Your drive is in need for a replacement. This problem indicates a hardware failure specifically the lens of the device.
Hope this helps..
Mar 29, 2010 | Acer (4432A-002) CD-RW Burner
Blank cd's are not recognized by the Dell Inspiron cd burner
I would first try removing the device in the control panel, system, device manager and then reinstalling the driver. There may be a problem caused by a windows update. In general CD drives rarely go bad. If the CD works say for a music CD then it should work for blank cd. You may also want to check the CD type. If you accidentally used a DVD, that won't work and in some of the older CD drives, they may not handle every type of CD format.
Good Luck
Feb 02, 2010 | Dell CD & DVD Burners
How do i copy a disk
Before you Begin Make sure there is no program runing that has opened any file on the original disk. You cannot run the Disk Copy procedure if any file on the original or destination disks is in use by any program. For example, if you were editing a document in MS Word, saving to the disk in Drive A, and now want to copy it to another disk: FIRST quit the MS Word program, then execute the Disk Copy procedure. Caveat LectorThis Disk Copy procedure will make an exact copy of the original disk on the copy disk. It will completely overwrite the copy disk, replacing anything on it with the contents of the original (source) disk. That means that if there are any files on the copy (destination) disk before you begin, those files will be destroyed. You might want to take a look at the destination disk before beginning to be sure there's nothing on it you want to save. -------- Copying a Disk
  1. Double-Click on the My Computer icon on the Desktop. The My Computer window will open.
  2. In the My Computer Window, click once (not the usual double-click!) to select the icon for 31/2 Floppy A:
  3. Click on the File menu and select Copy Disk. The Copy Disk window will open onscreen.
  4. In the Copy Disk window you will see the option:Copy from 3 1/2 Floppy (A:) to 3 1/2 Floppy (A:)Click on the Start button.
  5. A new window will open prompting you to Insert the disk you want to copy from (source disk). Insert the disk and then click on the OK button. The program will begin "reading" the files from this original (source) disk. You can watch the progress in the little "progress bar" in the Copy Disk window.
  6. Once the original disk has been read into memory you'll be prompted toInsert the disk you want to copy to (destination disk)Now remove the original (source) disk from the drive and insert the copy (destination) disk into the drive. The click the OKbutton. You can watch the progress as the computer "writes" to the copy (destination) disk in the Progress bar in the Copy Disk window.
  7. When the copy is completed you'll see a new, small window popup that will report:The copy completed successfullyNow remove that copy (destination) disk. You are finished!
------- This will help. Thanks please keep updated.please do rate the solution positively .thank you for using fixya.
Nov 04, 2009 | Acard Technology (ARS-2030LD) DVD±RW...
Dell Lat. D600 will not read cd and does not recognize cd
this tool will fix it
use this tool to reset the cd in the registry
after you run the file - reboot the computer -
May 30, 2009 | Dell (313-1220) CD-RW/DVD-ROM Combo Drive
Dimension E510 dvd burner will not burn
Go to this link and click on the Fixit box. Microsoft has an issue with CD/DVD recognition and created a patch. This happens a lot when Windows Update runs and installs SP3. Hope this solves your problem. If it doesn't, right click on your DVD drive and ensure that recording is enabled. Hope this solves your recording issue.
May 18, 2009 | Dell (1G055) CD-RW/DVD-ROM (Combo) Burner
External hard drive
1) what are the operating systems on the old (dead) and target systems?
2) Try it on a second working system?
3) This sounds like an OS related problem (if it's not a dead hard drive problem). If you're running Windows, the newsgroups/forums run by Microsoft are actually pretty good. E.g. if you're using WinXP, try
microsoft.public.windowsxp.basics or
They can give you help in diagnosing the problem.
Jun 25, 2008 | CD & DVD Burners
My DVD RW problem with EXE files
There is a problem with windows itself or the drive is nearing its life span, you can try the drive on a different computer
If it works then its the windows if not its the drive
if its windows format and reinstall
if its the drive then replace it
If you cant get another computer to try it on
copy a disc to your hard drive and try running it. its images open but the exe fails to run then its the windows
of nothing works then its the drive
BUT TO BE SURE I RECOMMEND using it on another pc
Nov 22, 2007 | Pioneer DVR-112D DVD RW Dual Layer Burner
LG GSA-2166D DVD RW Dual Layer Burner Logo
63 people viewed this question
Top LG CD & DVD Burners Experts
Brian Sullivan
Brian Sullivan
Terry Allen
Terry Allen
Are you a LG CD and DVD Burner Expert? Answer questions, earn points and help others
