Question about Hifonics Car Audio & Video
End caps Where can I buy end caps for hifonics bxi 20100 watts
  • 631 Answers
SOURCE: no sound in my Hifonics Brutus BXi 1206D amp
Have you confirmed that you have a good signal feeding the amp?
Have you confirmed that the speakers are in good working order and don't have any breaks in the wiring?
Posted on Jan 02, 2008
  • 4 Answers
SOURCE: Hifonics amp keeps blowing the main fuse
have u tried using thicker wire from the battery to the amp u need to put a fuse in there thats a minumum 60
Posted on Aug 14, 2008
fixyathing
  • 341 Answers
SOURCE: blown resistior in a hifonics brutus bxi 1606d
If you can point it to me in the schematic diagram I might be able to help you. But I suggest you bring it to a qualified audio electronic technician if you still value it. cheers!
Posted on Oct 17, 2008
sicaudio
  • 96 Answers
SOURCE: Hifonics BXI 1606D problems
it may be a wiring problem you need to make sure all the speaker positives and negatives are correct. I sell alot of hifonics amps and have never had 1 do that. it may also be a bad rca cable. if it only does it when you use the filter i would say not to use it also make sure the gain is no more than 3/4 turned up and the bass boost no more than 1/2. if you have a dif amp try a temp setup using it and if it still does it its a wiring issue. also try 1 speaker at a time on the hifonics and keep adding 1 till it comes back it may be a bad voice coil on 1 sub .
Posted on Jan 10, 2009
SOURCE: how to connect HIFONICS BXI 2607 D watt at 1 ohm
two dual 2 ohm subs = .5 ohms wired parallel and 2 ohms wired in a series / two dual 4 ohm subs = 1 ohm wired pallallel and 4 ohms wired in a series / one dual 2 ohm sub = 1 ohm wired parallel and 4 ohms wired in a series / one dual 4 ohm sub = 2 ohms wired parallel and 8 ohms wired in a series......this means if you have two dual 2 ohm subs or if you have one dual 4 ohm sub you are not going to be able to get a 1 ohm load.......running parallel on a dual coil speaker is both positives are ran to the positive on the amp and both negatives are ran to the negative on the amp.....running in a series is the positive terminal from one coil ran to the positive on the amp and the negative terminal on the other coil ran to the negative on the amp and having the remaining open positive and negative terminals connected to each other with a jumper wire
Posted on Dec 10, 2009
I have a brutus bxi 1206d 1200 watts, and the amp is coming on fine not protected. But there is no sound output. u can hear a small feedback rumble when connecting the input rca's. But thats it. My...
i would check the speaker cables to see if something came disconnected first maybe wire i touching other terminal shorted out the channels output .
run a new set of rca cable to see if one use are bad . check to see if rca cables pluged into right output of radio . check to see if your remote wire is powering up the amp to turn on the amp ..
will still light up with battery power but will never put output to the speakers with out the remote turn from the radio ... how to check this is to disconnect the cable at the amp and take a short 18 gauge wire and strip both ends and touch the battery terminal at the amp terminal one end the other end where the remote wire is mounted on the amp if do this for a few seconds to see what happens or better yet buy a digital volt meter and check for 12volt a the remote wire when you turn on your radio
Dec 23, 2010 | Hifonics Brutus BXi 1206D Car Audio...
I bought a hifonics bxi2006d new and doesnt turn on
you should not have any spark from your ground...you may want check and make sure your ground is properly installed. Try wiring the amp without the cap and see if that works.
Mar 28, 2010 | Hifonics Brutus BXi 1206D Car Audio...
Hifonics BXi 2610D amp fuse
sorry but this amp has no fuses..you wud think it would but it dont..
Jan 08, 2010 | Car Audio & Video
Can a hifonics bxi 1608d support a half ohm
http://www.maxxsonics.net/manuals/hifonics/pdfs/HifonicsBrutus2009AmplifierManual.pdf
THE ABOVE LINK WILL ALLOW YOU TO DOWNLOAD THE .PDF MANUAL FOR THE CURRENT VERSION OF THE AMPLIFIER WHICH IS THE BXI1610D WHICH IS STABLE DOWN TO 1 OHM WHICH PRODUCES 1600 WATTS. YOU CAN ALSO CALL TO VERIFY THE MINIMUM IMPEDANCE OF YOUR AMPLIFIER BY CALLING MAXXONICS AT 847-540-7700......V
Dec 27, 2009 | Hifonics BXi1608D Car Amp
Hifonics bxi 1606d
you could just take some out of some other electronics because all they do is reproduce sound so there is litteraly no power going through
Jul 04, 2009 | Hifonics Brutus BXi 1206D Car Audio...
Hifonics brutus 2000 watt help??!!??
If an RCA took a dive your amp has most likely seen a very nasty input spike and may never be the same as its circuitry has been damaged.....sorry
Mar 09, 2009 | Hifonics Brutus BXi 1206D Car Audio...
Jan 08, 2009 | Hifonics BXI 1606D Car Audio Amplifier
Jul 15, 2008 | Hifonics Brutus BXi 1206D Car Audio...
Brutus 1206D
yes it can only at 2 ohms never 1 ohm good luck
May 25, 2008 | Hifonics Brutus BXi 1206D Car Audio...
Car Audio & Video Logo
61 people viewed this question
Top Hifonics Car Audio & Video Experts
Steve Sweetleaf
Steve Sweetleaf
Jaime Hernandez
Are you a Hifonics Car Audio and Video Expert? Answer questions, earn points and help others
