Question about Behringer Gi100 Ultra G Active Di Box
Behringer GI100 has hiss when cab simulator is enguaged
Has a pretty pronounced hiss when 4x12 cab button is enguaged seems pretty good without the 4x12 switch enguaged. what could be wrong
  • 5603 Answers
SOURCE: Behringer XENYX 1622FX, won't power on. Phantom power works(?)
After reviewing the schematic, I don't understand how the Phantom power can REMAIN on with the power switch off... this CANNOT occur except for what energy is left in the 48 volt supply filter cap... This might last for minutes after the fuse went... UNLESS you have devices connected which are backfeeding the 48 volts. (which would be a disaster)
The 48 volts, +/- 12 volts and +/- 15 volts and the +5 volts ALL come from the SAME switching power supply. I suspect one of the filter caps went or the primary switching regulator a TDP245Y chip.
You should ONLY work on the line side of this using an ISOLATION transformer since the line side has lethal voltages.
To do testing, one replaces the fuse and puts a 60 Watt light bulb in series with the hot side of the inout line. The lamp "acts" as a resetable fuse and limits the current for testing. When all is well again, the lamp will remain out with the power flowing through it.
The D1 diode bridge and C7 input rectifier and filter are first things to check. You can do those with an ohmmeter.
I will caution you to ALWAYS power any and all equipment from the SAME power source. Plugging in devices from across the room will set up ground loops and any ground fault will fry equipment.
Posted on Apr 05, 2010
  • 5603 Answers
SOURCE: My Behringer XENYX 2442FX Mixer does not power up,
You should find +/-15 volts and +5 volts as well as the phantom power... but that light can come on at much lower than desired voltage.
Note that the regulators are current limited so a short on the mixer board can kill one of the voltages.... but you are not getting any input from teh switching portion of the regulator so the switching part of the supply is apparently dead. To replace the supply you would have to call Behringer at 1-425-672-0816 to get the part number and an incident number and then call FullCompass which is their part distributor now.
When working on a switching power supply, use an isolation transformer for safety and use a 60 watt lamp in series with the power cord to limit current during testing.
The circuitry will be SIMILAR to the power supply found on page 9 of schematic you can download at:
http://elektrotanya.com/behringer_ub1204fx_pro.pdf/download.html
Posted on Dec 15, 2010
  • 6 Answers
SOURCE: I have an Behringer Xenyx 1222FX that won't power
The phantom power light wouldn't illuminate unless the unit was powered on. Possibly the main power indicator light is burned out.
Posted on Jan 16, 2011
  • 5603 Answers
SOURCE: Behringer Xenyx 2222fx doesn't power
The Phantom power comes from a seperate winding on the switching power supply.Likely one or more of the other voltages are not present due to a failure of one or more components. The supplies are current limited so a short anyplace on the board may cause the problem. I had one of these short betwen the +/- 15 volt busses because somebody spilled liquid into it.
Here is a close schematic... a slightly different model with less channels, but circuoitry is the same, just more copies of it in yours: I believe it is zipped with four files... the last is the power supply.
http://elektrotanya.com/behringer_xenyx-1222fx_v1000_dpm5m_ub-spsu2_sch.zip/download.html
Posted on Feb 20, 2011
  • 5603 Answers
SOURCE: Behringer XENYX 1620FX, won't power
Here is a schematic close to your unit:
http://elektrotanya.com/behringer_xenyx_1622fx.pdf/download.html
Scroll down to "get manual" and click to download. Ignore other download links.
The phantom power is a separate rectifier and regulator. See page 11 of the download service manual for the power supply. Be careful when working on line operated switching supplies. I suspect you will find one of the other supplies is dead. If the phantom is OK, then the switcher is working and one of the rectifier/filter/regulators is bad. Check if an electrolytic cap is shorted.
Posted on Jul 22, 2011
How can I reduce white noise / hissing I'm getting over the mic on a Behringer Xenyx 1204 USB setup?
Hi, you didn't say if the mic actually passes sound? The C-1 is a condenser Mic & needs phantom power - switch on the rear of your mixer. If that's no help, what happens if you disconnect the mic, then turn the levels back up? Still hissing or gone? If it's gone then it's the Mic - must use a 3 wire cable, preferably XLR so it gets the phantom power. If the hiss is still there without the Mic then sounds like the mixer is faulty - try some of the other channels..... How loau is the hiss - just in the background or as load as a vocal "one, two" test? A few things to check anyway...... Good Luck!
Dec 01, 2016 | Behringer Music
Need to know how to wire a marshell speaker cab
here you go.
http://www.jumbosunshade.com/swd01.htm
make sure to figure out what the ohms are of each speaker and how it is currently wired before messing with it. Make a plan, then act.
Jan 29, 2014 | Marshall Amplification Marshall MG412A or...
Have a Behringer 1202 Xenyx FX, balanced cable into a new windows 7 PC and keep getting hiss. When I raise the gain, mic or master volume the hiss is more awful. my internet broadcasts sound awful. what am...
You are running your balanced cable into a windows 7 PC? What interface are you using... not the line input on the PC I hope as it is NOT balanced... it is Stereo input with UNBALANCED input. If you tie the mixer using a balanced to 1/8 inch balanced connector you will get plenty of hiss since you are driving the stereo channels oppositely. For high quality, get a good audio interface that runs on the USB of the PC. If you can tolerate a bit of noise but wire it correctly, then you will need to use two UNBALANCED lines out of the mixer for L and R and merge them to a stereo 1/8 inch plug for the PC.
Jul 10, 2011 | Behringer Xenyx 2222fx Premium 22 Input...
I have the Behringer Xenyx 502 mixer, it's brand-new, and for some reason there's a weird buzzing/hissing sound in the main mix that will just not go away no matter what I do. I've unplugged everything,...
Is the sound a low frequency buzz or high frequency hiss? With all the input level controls at the minimum position and the output level controls at the maximum is the sound audible?
Waiting clarification, don't hesitate to post.
Thanks and regards
Please kindly rate this solution
Stelios
direct fixya link: http://www.fixya.com/users/technical114
Mar 31, 2011 | Behringer Xenyx 502 Audio Live Music Mixer...
BEHRINGER AM400, I seem to be getting what appears to be a hissing sound coming from my brand new acoustic modeler pedal. If I turn the "attack" level right down it seems to reduce the problem....
First of all you should try to use another guitar - if the problem is still there try using different batteries or another power supply unit and finally a different amplifier. If none of these actions lead to success i would send it back if i were you.
When you buy equipment you should always test it at the shop to avoid such problems!
Feb 26, 2011 | Behringer Am400 Acoustic Modeler Pedal +...
My marshall cabinet has serial# 44439. Can you tell me what year it was manufactured?
Have a look at this web page:http://www.thegearpage.net/board/archive/index.php/t-275743.html Also this one:http://www.marshallforum.com/cabinets-speakers/1034-dating-marshall-4x12-cabinet-without-speaker-codes.html Hope this gives you some help.
Nov 01, 2009 | Marshall MG412A 120W 4x12 Guitar EXtension...
No jack from the cab to the head
Try looking here:http://www.marshallparts.com/
4 x12 slant cab grill is ripped its a '' MARSHALL''
From behind the amp there shouls only be a couple os screws that hold that fron panel on, once removed you can take it off to work on it, you can get the same material from a good music store or even some type of fabric store or craft store.
Mar 29, 2009 | Marshall Mg100dfx 100-Watt Combo Guitar...
Behringer Gi100 Ultra G Active Di Box Logo
Top Behringer Music Experts
Michial Gueffroy
Vito Vacirca Jr.
Matthew Spark
Matthew Spark
Are you a Behringer Music Expert? Answer questions, earn points and help others
