Question about American Standard Heating & Cooling
Why does it shut off after it starts ? 2a6b3060a1000a american standard
When the thermostat's on cool, the unit comes on and the unit charges and the pipe on the unit gets hot then there is a clack every thing shuts down. also the defroster did not work last winter so we went to emergency heat to stop the Ice up. could you tell me the most likely problems
  • 25 Answers
It sounds like a stuck reversing valve stuck in heating mode based on a hot refrigerant line.
It could be stuck in the heat position because it isn't receiving 24 volts to operate, or it could be stuck internally.
Tapping on the copper tubes on the reversing valve sometimes frees one that is stuck internally. It is copper so don't get carried away or you will destroy the reversing valve.
Did you feel the temperature of both copper lines?
If the reversing valve is stuck in heat, during the winter, your heat pump will ice up, because it isn't reversing to cool as it should when it calls for the defrost cycle to occur.
Google "heat pump reversing valve" to see what one looks like
You'll need to use a voltmeter to verify that the reversing valve is receiving twenty four volts.
Pull the two wires at the reversing valve coil and check for 24 volts.
If you don't have 24 volts there when you put the unit in cooling cycle,you either have defective thermostat wiring, or a defective thermostat.
If you have 24 volts you will need to check the electrical coil that the two wires plug into.
Set the voltmeter to ohms, and make contact with the meter leads onto the terminals of the coil. One lead goes on one terminal and one lead on the other terminal at the same time, to check for continuity. You should get an ohm reading. That means the coil is good.
If the meter indicates "0" ohms the coil is shorted and needs replacement.
If the meter doesn't read any ohms at all that means that the coil is burnt out and needs replacement
When the reversing valve is activated there will be a "whoosh" sound you can clearly hear if you are near the outdoor unit.
You can order the A/C parts you need online unless you have friend that is a HVAC tech and he could get one from the Trane supply house.
It is a big job to replace the reversing valve involving freon removal and brazing. Hopefully you will find the problem in the wiring, Thermostat, or the reversing valve coil.
Posted on May 19, 2014
pierre1811
  • 144 Answers
SOURCE: Defrost Cycle Problems with Heat Pump
It's a defrost board issue. The timer on the board or something similar is hanging up. Unfortunately the solution is to replace the board. By lowering the temp. on the T-stat you are resetting the timer on the board. As you see that only works until the next cycle.
Posted on Feb 23, 2009
  • 52 Answers
SOURCE: 2 weeks ago one of my units stopped working
sounds like the coils inside the air handler/furnace are freezing up. likely cause is the freon charge is incorrect (probably undercharged). it may have been correct when the tech did the work but some may have leaked out. it is slightly possible too that the system is overcharged. you should have the system pressure verified, and then have it checked for leaks.
Posted on Jun 18, 2009
  • 46 Answers
SOURCE: heat comes on with ac cooling
what type of unit do you have fleet wood monaco ? useually this is a bad ground problem in a trailor motor home useually low voltage dc problem
Posted on Aug 01, 2009
SOURCE: I am renting a house which has a Trane heat pump
If it is a heat pump it may not have enough oomph.
Posted on Oct 20, 2009
shastalaker7
  • 1515 Answers
SOURCE: Intertherm model T3RC-030K Shortly after unit
Hi, if this is a split system with a remote condenser It sounds as though you are having a problem with the thermostatic expansion valve on the heating cycle. If indeed this is a heat-pump, it has 2 metering devices that meter freon into the evaporator to heat or cool. The reversing valve changes the direction of the flow. If the condenser starts to ice up and shut down and repeat itself. I would say that is you're problem. This is something that would have to be changed by a service tech do to the equipment required to do this. I wish I could offer you a quick fix but I can not. You can let me know if this is a split system, and I may have other solutions for you, so get back to me on this please.
Sincerely,
Shastalaker7
Posted on Dec 24, 2009
Testimonial: "Thanks for your help, will come back if I have other questions"
Heat coming out when in cool mode.. got new thermostat same thing. American Standard XL 624
Does it cool when in heat? Is this a heat pump? What's supply air temp vs. return air temp? Outdoor unit running?
Mar 26, 2018 | American Standard Heating & Cooling
Stage 2 is on the screen but no heat will come on. American standard thermostat. A/c comes right on but when heat is turned on "stage2" comes up on the screen but the heat won't Not a touch screen.
You should look at your furnace and see if any safety lights are flashing. Make sure your thermostat is set to heat.Check system your using for updates.
Nov 19, 2016 | American Standard Heating & Cooling
Where can I find an instruction manual for a n american standard remote for a trane split heating and ac unit?
AccuLink Remote Control - American Standard
https://www.americanstandardair.com/.../acculink-remote-control.html
Find more information on the AccuLink Remote Thermostat available from ... terms for your AccuLinkTM Remote Thermostat, please refer to your owner's manual ...
Thermostat Controls - American Standard
https://www.americanstandardair.com/products/thermostat-controls.html
Discover thermostats and get a digital thermostat for your home with American Standard. ... 7-day programmable comfort; Remote monitoring and programming ...
Free American Standard Thermostat User Manuals ...
homeappliance.manualsonline.com/manuals/.../american_standard/ameri...
Products 1 - 34 of 34 - Find the user manual you need for your home appliance products and ... American Standard Central Thermostat Installation Instructions.
Free American Standard Air Conditioner User Manuals ...
Feb 03, 2016 | American Standard Heating & Cooling
My American Standard Heritage 11 unit was not working properly when i came home from work and the temperture in the house according to the thermostat show the temperture in the house to be 85 degree&#
the dual run capacitor is bad located in main panel of unit size of small red bull can it will be swelled up on top indicating it bad get on at electric motor or electric supply house most ac stores wont sell it has a rating like 35/5 370
Aug 27, 2012 | Heating & Cooling
My thermostat when prgrammed and set on "auto" mode kicks on heat when temp drops below set temperature. The problem is that after warming up to that temperature...it does not shut the fan off. ...
I have a honeywell TH8320U thermostat and American standard Air handler with heating unit put in. THE thermostat works fine with the ac and follows the programs I have set. However the heat is a different story. The thermo clicks on to follow program but the unit does not run. (auto settings) If I place the thermo in heat and turn it to on I get heat?
Dec 08, 2010 | Honeywell Programmable Thermostat Heater
I have error codes flashing on my thermostat..it is an american standard model the manual for the therm. has ACOT900AC43UA on front..says to find addedum 18-HD32D2-1/69-2009 for codes i cannot find it...
Error codes from American Standard Pub 18-HD32D2-8, which is a one-sheet document that came with my American Standard air-conditioner:
29 = not listed
129 = not listed
80 = HPCO Fault - problem is in outdoor unit - Desscription: High Pressure Monitor Fault (hard lock out, cycle power to reset)
91 = Communication Inactive Fault - problem is in air handler - Descriptions - COMM Bit Master Clock Error, COMM Heat/Cool Demand Error, Serial Motor Communication Inactive Error
91 = Communication Fault - problem is in furnace - Descriptions: Blower motor no COMM response, Inducer motor no COMM response, Loss of heat/cool demand, Loss of clock signal
91 = Communication Fault - problem is in outdoor unit - Descriptions: Loss of Heat/Cool Demand Message (COMM), Loss of Bit Master (Clock Signal)
91 = Communication Fault - Description: Comm line is dead and no bits have been received.
By the way, I do not recommend American Standard. I've had mine 14 months and it just blew up - the entire control panel blew. My advice to you - think about a different brand.
Nancy
Scottsdale, Arizona
Aug 22, 2010 | American Standard Heating & Cooling
It wont go into the heat side when i put thermostae to heat
If the fan comes on in Auto, thats a good thing, same if the cooling come on when put to cooling.
At the unit turn power off and remove and identify thermostat wires. Put a jumper wire between R an W or W1. Restore power, heat should come on.
If not,were there any wires attached to w or w1 before you started, if yes then you need to make sure the same wires and color are hooked up to same terminals at thermostat.
Jan 10, 2010 | American Standard WCZ036F Air Conditioner
Unit shuts off when outside temp drops and will not come back on
Have him trouble shoot the defrost board. Also check the charge of the unit, it may be shutting off from either low pressure or high pressure.
Dec 06, 2008 | American Standard WCZ036F Air Conditioner
Heating & Cooling Logo
80 people viewed this question
Top American Standard Heating & Cooling Experts
Craig Butler
Craig Butler
Tim Whalen
Mack Baxter
Are you an American Standard Heating and Cooling Expert? Answer questions, earn points and help others
