Question about Hardware & Accessories
What does the battery indicator mean on the raindrip R672ct timer
3 Suggested Answers
SOURCE: How to set start time on timer raindrip r672c
The start time on these style of timers is whenever you set it. So if you want it to run at night it needs to be set at night, e.g. turn to off/reset, then at 10pm go set to the freq. and duration desired, then it will run at 10pm. Also note this timer waits a full cycle to run the first time after it is set, e.g. if today you set it to run weekly, the first time will be next week.
Posted on Jul 24, 2009
  • 17 Answers
SOURCE: how do I set my R672C Raindrip timer
http://www.raindrip.com/information/catalogs-and-manuals
http://www.raindrip.com/images/stories/pdfs/R672-single-timer.pdf
Posted on Oct 08, 2010
Why are the battery light and battery icon blinking?
it usually means that it needs a new battery, if you have tried that already did you put in new one, u should. replace the battery with a new one, a good new one, a good brand name like Duracell or something similar
Jun 01, 2016 | Raindrip R673CT Digital Water Timer
Only part of the display is visible
Copy following link for sprinkler timer manuals for all current products including raindrip, with possible troubleshoot section each manual:
http://waterheatertimer.org/Woods-timers-and-manuals.html#sprinkler
If this timer is not new, then change battery before buying replacement timer.
If timer is new, then exchange for timer that works.
Gene
h
Aug 19, 2013 | Raindrip R673CT Digital Water Timer
Raindrip r672c
Possible water in battery compartment
Corrision in unit
May 11, 2013 | Raindrip Rain Drip R672CT Analog Electric...
I can not get my raindrip R673CT to program in the days I want it to go off. Lost my instructions. It puts in what days it wants and won't let me change them. Even removed the battery and let it sit...
Call raindrip 888-825-4716
I can post manual R673CT timer.
http://waterheatertimer.org/pdf/Raindrip-R673CT.pdf
Manual does not have troubleshoot steps
Try 2 new AAA batteries, and clean battery terminals.
The fact that you get display suggests that batteries are not the problem.
Manual says timer will no longer turn on with low battery, so timer is reset by removing battery.
Generally it is bad news when basic timer will not function after reset.
Aug 06, 2011 | Raindrip R673CT Digital Water Timer
I would like to down load a manual for R673CT
I found the instructions for a 672,, I think they are the same if its just basic info you need, if you need more lemme know and I'll kep digging http://www.ehow.com/how_7344042_set-raindrip-r672ct-water-timer.html
Jul 06, 2011 | Raindrip R673CT Digital Water Timer
How do i set timer
How to program Raindrip R673CT
Download R673CT manual at raindrip
Other models
R683CP
R672CT
Raindrip drip water guide
R673CT
Install 2 AAA batteries to power display
Set current time:
Press TIME and hour digit flashes > Use up-down arrows to set 24 hour clock
Press SET to confirm hour
Use up-down arrows to set minute
Press SET to confirm minute
Use up-down arrows to set day of week
Press SET to confirm day
Program review
Timer can set 16 watering schedules
When programming, look at display:
Notice: PROG for programming mode, #1, start time, run time, SU MO WE for days
Press PROG and display appear just like image above
Use arrows to select 1, 2, 3, 4 through 16 different watering schedules
Programming
Start time hour will flash
Once hour flashes, use arrows to select hour
Minutes will flash
Use arrows to select minute
Press SET to confirm minutes
Run time hours will flash
Use arrows to set run time hours duration (0 to 9 hours)
Run time minutes will flash
Use arrows to set run time minutes
Press Set to confirm
Now #2 shows on display this is about which days the timer will water
Decide 1) every other day, 2) every third day, or 3) watering at will
1) To water every other day:
While 2nd is flashing, press SET and SU TU WE FR will appear in display
2) To water every third day:
While 2nd is flashing, press down-arrow
3rd will start flashing and TU WE SA will display
3) To water at will:
While 2nd is flashing, press down-arrow twice
SU will flash
Press down-arrow to go to MO TU WE etc
Press SET when day you want appear on display
To set another watering program
Scroll back up to "programming" on this page
Press arrows to select programming 1 thru 16
Repeat programming sequence
After programming is set, press clock button and current time will show
Oct 07, 2010 | Raindrip R673CT Digital Water Timer
Raindrip timer R672C
Problem for Raindrip R673CT Digital Water Timer Raindrip timer R672C I am trying to program the days of the week on this time and cannot do it. Can you help?
May 16, 2010 | Raindrip R673CT Digital Water Timer
Hardware & Accessories Logo
80 people viewed this question
Top Hardware & Accessories Experts
Gene Haynes
Hippy_dd
Are you a Hardware and Accessory Expert? Answer questions, earn points and help others
