Question about Dell UltraSharp 1702FP 17" Flat Panel LCD Monitor
Why won't Dell 1702FL monitor won't work as plug and play to laptop?
    New Friend:
    Problem Solver:
  • 19 Answers
You have to sellect video out option to external on your laptop
Posted on Nov 23, 2014
2 Suggested Answers
  • 124 Answers
SOURCE: Second monitor for laptop not working as plug and play
Go Here.
http://support.dell.com/support/downloads/download.aspx?releaseid=R83276&formatcnt=1&libid=0&fileid=109465
Download driver & install.
Hope this fixed ya. Please Rate.
If you need more help send comment & ill respond. Good Luck!
Posted on Mar 12, 2009
I cannot get my Dell Vostro 3450 laptop to recognize a second monitor. Suggestions?
in xp plug an pray was turned off in an update.
try the function to send the screen to the monitor as a primary an if it works
Jan 04, 2015 | Dell Computers & Internet
E248WFP (external) Monitor Won't Power Off when Laptop Screen does!
this is not a pc problem... this is because the connection loss between pc and monitor... not all pc's have sleep mode in externa vga connection.... it just cuts power off... u can configure monitor of possible to do that..
Jul 09, 2012 | Dell UltraSharp E248WFP 24" LCD Monitor
( Dell xps m1530 laptop ) Monitor blank, powers up but screen won't come on.
It ISN'T the LCD screen. Since you diagnosed with an external VGA monitor, you now know the problem is the laptop.
(When you connect an external VGA monitor to a laptop, you are bypassing the Video Cable, and LCD screen. You are connected directly to the laptop )
The basic Windows files aren't being found. The boot files. This may mean a bad Harddrive.
Do you have the Restoration CD Disk? Laptop on insert it into the optical drive tray, close the tray.
When asked choose - Repair. (Non-Destructive Installation)
If a checkdisk is done, you have bad sectors on the harddrive.
There IS a special procedure in replacing a harddrive.
[ More information on Harddrives,
http://computer.howstuffworks.com/hard-disk.htm ]
Regards,
joecoolvette
Feb 26, 2012 | Dell XPS M1530 Laptop
Acer lcd monitor attached to dell computer optiplex gx620 have windows xp professional default is plug and play won;t recognize monitor. have service pack3. in device manager under monitor only plug...
Is it attached to your computer via a VGA cable or DVI cable if it is vga then that is your problem
If your graphics card does not have DVI then you will not be able to make best use of that monitor.
Aug 20, 2009 | Computers & Internet
Dell computer will not work with an older HP monitor
no dell have set up there computers so you cant use othe appliances that arnt dell. so im sorry for the inconveince.
please rate my help to you.
thank you.
Apr 22, 2009 | HP Pavilion F1503 15" LCD Flat Panel...
Go Here.
Mar 12, 2009 | Dell E193FP 19" LCD Monitor
Dear Sir, My Laptop Dell Lattituede, I am facing difficutly in getting display in lcd, external display is coiming , Laptop goes shut off immediatley if run without external cable plugged in, after...
I think there is some severe problem in the VGA of the laptop, that is not supporting your LCD. There may be some thing relating to a very sensitive golden color strip in the laptop that is used to VGA signals. If you have opened the laptop for repairing then it can be a issue. Better to try another VGA first and then tell me what happened.
Jan 19, 2009 | Polyview V17E 17" LCD Flat Panel Monitor
I cant get my acer aspire one to connect
your describe: connect a laptop VGA out to a monitor but no signal: you need check
1) newer monitor have two signal interface (analog or digital) and you may try to do a logical change the signal way by select buton
2) any laptop have two way display (local LCD or extenal VGA) change by the key (fn+f key showing creen icon)
Nov 08, 2008 | Dell E207WFP LCD Monitor
I want to connect a Ultrasharp 1907 FPt monitor to my Dell inspiron. I have a power cable and also one from monitor to lappy, do I need a driver?
to toggle the screen between your laptop and the dell 19" monitor. Hold down the Fn key on the laptop and tap the F8 key. The screen would move to the external display.
There are three settings that can be done by the Fn + F8 key combination
1. Both the laptop and external monitor works
2. Only the external monitor would work
3. Only the laptop screen works
Thanks
Proton
Nov 04, 2008 | Dell UltraSharp 1907FP 19" LCD Monitor
Laptop
First try reinstall the OS.
Mar 17, 2008 | Gateway FPD2275W LCD Monitor
Dell UltraSharp 1702FP 17" Flat Panel LCD Monitor Logo
46 people viewed this question
Alun Cox
