Question about Canon PIXMA iP3600 Photo Printer
Canon printer error 6A80
Does not turn on get green and yellow blinking lites
    Genius:
  • 1,552 Answers
SOURCE: canon s9000
This solution sounded to strange to be real but I was desperate for a solution to the orange light blinking 7 times and getting NO response from the printer whatsoever. It actually worked!
  1. Turn off printer
  2. Hold down Resume button and press Power button.
  3. Keep holding down Power button and let Resume button go.
  4. Press Resume button 2 times then let BOTH buttons go.
  5. Green lights will flash and then stop blinking.
  6. When green lights are solid, press the Resume button 4 times.
  7. Press the Power button and the printer should turn off, if not, press the Power button once more.
  8. Your printer should respond as normal.
Posted on Jul 13, 2008
SOURCE: Canon i560 printer
I have similar problem. I found this solution that may help you. My problem insists tho.
>>> 5 flashes indicates a faulty printhead or possibly a problem with the p/head contacts. Try removing the head which is easier if you take the cartridges out first(no tools required) and re-seat it having checked the contacts for dirt.
If that doesn't work it may be that the waste ink tank is full. Try this ...
Canon S9000, S300, S400, i550, i560, i850, i860, i865, i9100, i9950, PIXMA iP3000 above,
1. Turn off printer
Posted on Aug 12, 2008
JongCur
  • 88 Answers
SOURCE: canon i860 error codes
Try this: With your i860 printer turned ON, press and hold the I/O switch then pull off the power cord. This will turn off your printer. But without lifting your finger on the I/O switch put back your power cord. the I/O switch will blink for a second and will go off, then turn-on your printer again and see if it works.
Posted on Oct 06, 2008
bschilz
  • 2049 Answers
SOURCE: getting error code 6A00-Canon PIXMA MX850 all-in-one printer
The error indicates that the slide the cartridges run on has debris buildup or a component of the printer is blocking the cartridges ability to slide.
Steps to fix...
1. Unplug printer from power source
2. Slide the cartridges to the middle and inspect the slide for a buildup of "gunk" or pieces of debris. Remove what you see and clean the slide with a lint free rag and isopropyl alcohol
3. Look for any part of the printer that may have become dislodged or moved from vibaration and use and try to put it back in to place.
4. Get some "canned air" at any computer or office supply store and blow the printer out thoroughly.
Plug the printer back in and it should work again.
Posted on Oct 29, 2009
  • 1126 Answers
SOURCE: Printer error 6A80
6A80
6a90
c000
6C10 feeder unit and / or purge unit defective.
Blocked Zahnrad-/Kupplungs-Verbindung between the two systems / defective.
Troubles with purge pump and or purge tube plugged (clogged). Needs service tech.
Posted on Nov 24, 2009
How can I fix error No. 6A80 on my Canon Pixma iP4700
Hi, That error may cause of a paper jam, check your printer if there is blockage and then remove those blockage if no blockage, and the error still appear try to reset your printer.
To reset follow this:
1. Turn off the printer.
2. Pressed simultaneously for 10 seconds on the following buttons:
3. Release the button "On / Off".
4. After a few seconds release the other buttons.
Thank you for using FixYa
Nov 15, 2010 | Canon iP4700 InkJet Photo Printer
I have a Canon MP550 and after pressing ON button in few seconfs appeares message: ERROR CODE 6A80
[6A80] & Light Blinking 12 times = APP Position Error. An error occurred in the APP motor. Maybe foreign material or paper debris around the PURGE UNIT (at the printer most right hand side) or Auto Sheet Feed area.
May 24, 2010 | Canon PIXMA MX700 All-In-One InkJet...
Canon i470D Printer will not work. Yellow light
1. Turn off the printer ( "Power" button).
2. Hold the button "Resume", include printer (click "Power").
3. Hold the "Power" button, release the button "Resume" (power indicator / preparedness must turns green)
4. Not releasing the "Power" button, double click "Resume" and release both buttons
-- each time you click "Resume" power indicator / willingness to change color (one-click - yellow, the second hitting - green). U printers with more than one indicator - indication switches (power indicator / preparedness - green indicator error - yellow)
-- after the buttons are released, power indicator / preparedness will be for some time to blink green (Stamford time depends on the printer model), and then the green light permanently
-- If after these actions instead of constantly burning green printer continues to display error, or you are mistaken in paragraphs 1-4 (turn off the printer and repeat with paragraph 1), or if additional printer error that must be corrected, or it will not go down to a service mode.
5. Four times click "Resume" (each time you click "Resume" power indicator / willingness to change color, and the printers with more than one indicator - indication switches: the willingness / error).
6. Once you click "Power" to confirm the selected action (reset counter absorber). To disable the printer "Power" button to click again.
For some printers (for example, iP2000) to switch off clicking "Power" again, that is three in a row.
May 08, 2010 | Canon i 470D InkJet Printer
Blinks green, yellow, green yellow
Anytime it flashes green and yellow there's a service error, but you need to count how many times it flashes between the longer green flashes, that tells us the error code.
Oct 28, 2009 | Canon PIXMA iP3000 InkJet Photo Printer
CANON I350 DOES NOT PRINT
Green and yellow is a service error, but it flashes a longer green, and then the green yellow flashes, and a longer green again. You need to count the number of yellow-greens in between the longer green flashes, to know the error code.
Sep 17, 2009 | Canon i350 InkJet Printer
Error 6A80
Error 6A80 indicates that "an error occurred in the APP motor
during purging operation". Either the sheet feed unit, purge unit, or logic board could be at fault.
I'd recommend bringing the unit into your local canon authorized service facility for complete diagnostic and repair.
May 22, 2009 | Canon PIXMA MX700 All-In-One InkJet...
Canon S400 lite binks 6 times won't print.
1. Turn off printer
Dec 27, 2008 | Canon S400 InkJet Printer
CANON PIXMA IP1200 resetting
My converted iP1200 is currently blinking green, yellow, green, yellow on the power lights after start up and print request. The pop-up prompt suggests turning off the printer and turning it back on. Error 5100 is always seen.
Please Help Me...
rakibfuture
Mar 30, 2008 | Epson Stylus Multifunction Inkjet Printer/...
Canon PIXMA iP3600 Photo Printer Logo
old marine
old marine
