Stealth trio DOES NOT BOOT
I CALL AND SOME TOLDME TO VOL AND POWER WIPE PARTITION AND REBOOT BUT DONT DO NOTHING
    Genius:
  • 1,552 Answers
Plug it in to some source of electrical power, and let it (at least partially) charge its battery. Then, while still connected, try to boot it.
Posted on May 16, 2014
I have a trio stealth g2 10" and it was stuck on the start up (logo) page. I tried the hard reset (holding -volume and power button) and it worked for a day then froze up again. When I tried another h
I cases like this you might not have a choice but to factory reset to fix the start-up error. Repeat a hard reset (Vol up/Power button) and make an effort to get to the tablet Settings after boot up. Get to the Settings>Backup & reset>Factory data reset. In the majority of cases a factory reset will resolve critical issues. This is thought of as a "nuclear option."
If this nuclear option fails then a more complicated process that's beyond this post is to consider installing a custom Android ROM after rooting the device. XDA has a forum discussing rooting and installing custom ROMs for Stealth tablets: http://forum.xda-developers.com/showpost.php?p=34126848
Good luck.
Nov 20, 2014 | Mach Speed TRIO Stealth G2 10.1" 16 GB...
How to fix trio stealth g2 stuck on boot ?
turn it off. if you can't then their is a reset button on the side where the charger is. Get a safety pin put it in the hole. You will know if you reset it. It will reboot. It won't effect your files or info. I hope this helps!
Jul 01, 2014 | Mach Speed Trio Stealth G2 Tablet -...
How to reset a trio stealth g2
If you can power it on go into settings then backup and reset. This will reset tablet to the out of the box status. You will loose all of your data. If it will not power up, press power and volume up while booting till the screen comes on.Boot options will come up then reset. Be sure the tablet is fully charged.
May 28, 2014 | Mach Speed Trio Stealth G2 8 inch Tablet...
What number do u do if ur trio stealth pro is not working
More then likely you powered the unit on before it had enough of a charge to operate, Chargers for these types of tablets are way to little power for these things, will hold the charge when you use it but will not charge the unit when you use it, needs to go into standby to charge. Hold the power button and see if you can get a reboot screen or a turn unit off screen. Turn the unit off fully let it charge up alll the way then powere the unit back on. Should reset it. If not look for a small hole in the unit that says reset. push this and see what happens.
Nov 28, 2013 | Mach Speed Trio Stealth Pro Trio Stealth...
How do I fix my tablet it turns un but wount boot up
You'll need to do a factory reset:
1. With the device off, press and hold Volume Up and Power.
2. Release the Power button when you see the logo, but continue to hold Volume Up until the recovery screen appears.
3. Use the Volume buttons to navigate the menu and select wipe data / factory reset. Press Home to choose the selection.
4. Press Volume Up continue.
Oct 31, 2013 | Mach Speed Trio Stealth Pro Trio Stealth...
Trio stealth pro frozen
Try this factory reset from androidtablets.net, (Pressing Vol (-) and Power together). The first time I held them down with the machine on, the light changed color then went off. The second time I held them down with the machine off and it started as normal. I'm not sure which worked I'm just glad it did.
Mar 31, 2013 | Mach Speed Trio 4GB 7" Trio Stealth Pro
Touch screen won't work
same problem with me too.. i was told to reset the phone and it worked fine.:)
1.Power off the phone.
2.Press and hold Vol+ key and Power key simultaneously for about 10 seconds until the some option appear on the screen which are reboot system now; apply update from sdcard; wipe data/factory reset; wipe cache partition.3.Use Vol+ key and Vol- key to move the cursor to "wipe cache partition" and press camera key to confirm it.
4.After 5 seconds, the cursor will be on "reboot system now" again and press camera key to confirm it. The phone will reboot automatically.dont forget to backup important data to you sdcard.this will save your information.
Feb 15, 2013 | ZTE Warp
The phone turns on but once it gets to boost mobile logo it turns off again
Jan 26, 2013 | ZTE Warp
Phone wont start
This might be a software issue on the phone. So, reset your phone by following instructions:-
3.Use Vol+ key and Vol- key to move the cursor to "wipe data/factory reset" and press camera key to confirm it.
Jan 21, 2013 | ZTE Warp
Zte x500m boot problem
Reset your phone once by following instructions to solve the booting issue on the phone.
1.Power off the phone.Press and hold "Vol-", and "Power" key until the phone goes to recovery mode.
2.Press home key get into next interface.
3.There will be four choices:reboot system now;apply update from sdcard;wipe data/factory reset;wipe cache partition.
3.Use "Vol+" and "Vol-" to move the cursor up and down.
4.Move cursor to "wipe data/factory reset", press "camera" key to select it.
5. Move cursor down to "Yes - delete all user data" and press "camera" key to select it.The data will be erased.
6. The cursor will be on "reboot system now" at the end, so just press "camera" key to reboot the phone normally.
(It will take a long time to reset the phone after press the "reboot system now".so please be patient)
Dec 20, 2012 | ZTE Score
20 people viewed this question
 Grubhead
Grubhead
