Question about Sanyo DP42746 42 in. Plasma Television
GREEN POWER LIGHT NO LIGHT ON SCREEN NO SOUND
WILL START WORKING AGAIN IF LEFT UNPLUGGED FROM POWER FOR SEVEVRAL HOURS
    Problem Solver:
  • 10 Answers
I am a military spouse and our Sanyo 42 inch plasma tv just decided to die on Super Bowl Sunday 2009, and was only a few years old. We did everything we know to do: call the company, called the repair man, etc. There apparently isn't a solution to this that wouldn't cost more than the tv is worth. So I got an attorney to start a class action:
If you would like to be compensated for your TV, if it is the same model and you have the same problem (just abruptly stopped working) please contact me @
Danimimozi@gmail.com
Posted on Jun 24, 2009
Tv does not turn on
If green light flashes more than 8 times, it could be as simple as repairing or replacing the power supply. Unplug the TV ,remove the back. Look for bulged or leaking capacitors on the power supply. Do it yourselfer? only if you have soldering skills, or purchase replacement board. remember, used boards are just as old as your failed board, buy new or rebuilt, Good Luck
Feb 17, 2014 | LG Televison & Video
Toshiba Satellite l445d-s5976 won't power on
Well,that happend to my mom's computer and it was all working and was turned on but the image on the screen didn't show so I'm not sure how to fix it but I think you should send it to repair the same happend to my TV and it was sounding but didn't see the screen so I think the best thing you should do is sen it to repair or drop it off at Best Buy
Nov 24, 2012 | Toshiba Satellite L455D-S5976 Notebook
Vizio P50HDM No Picture/No Sound
this is most likely the sustainer board(s) problem. Replacing the sustainer boards should correct this problem for you. you can get the parts at vancebaldwin.com
May 29, 2009 | Vizio P50HDTV10A 50 in. Plasma HDTV
When turned on, no picture, sound or response. LED is OK
I had a similar problem with my HANNSLounge 32", the screen switched on with green light but none of the front panel buttons worked (screen is black apart from showing the input source in the top left).
After powering off numerous times I tried starting up with a blank SD card in the reader and the tv cycled between red green and blue screens and then reset itself. (Some sort of firmware restore?) After which point I had a working screen again! (Will have to see how long it lasts for!)
Feb 12, 2009 | Hannspree HANNslounge 32 in. LCD HDTV 32
No power to my computer.
hi
stuart
just read this carefully.................
Unplug the power cord and the display cable from the monitor. Now press the power button for 60 sec exact. Plug the cables and your system is working................ This is just a power drain.
Enjoy
Jan 13, 2009 | Dell DimensionTM XPS 710 PC Desktop
Blinking lights
I left if off and unplugged for a few hours. When I plugged it in it started working again. My recommendation if this happens to you is to just unplug it all and let it stand for at least 4 hours and then plug it back in.
Good Luck
Oct 01, 2008 | Sony RDR-VX555
I have a 62 inch mitsubishi dlp model#wd-62525 serial#125902 , tv will not power up it has a flashing green lite below the timer button that flashes,i have try the reset button but it just starts blinking...
if the light just constantly blicks green and doesnt stop. You will need the" V26 DM repair kit " which will usually repair that issue. You can get the repair kit at the following link which includes the replacement capacitor and instructions
http://servicemanuals.vstore.ca/
Sep 26, 2008 | Mitsubishi WD-62525 62" Rear Projection...
Infinity 3.5c , 2 powered Woofer 5.25" suddenly no sound.,
The woofers on my 3.5c stopped working, but with mine the light was off. I unplugged it and left it for about 24 hours and then plugged it back in and it worked. No idea why. It's happened twice and each time takes at least 12 hours or a day or so before it'll work again, just unplugging it for an hour won't do it.
It seems like both times the problem started when the speaker got unplugged without it being shutoff first, but I can't confirm.
But if your light is still on it's probably a different problem. With my 4.1t towers when the light was on but there was still no sound it equated to numerous fried amp components which cost about $150 for repair.
Oct 31, 2007 | Infinity Intermezzo 3.5C Center Speaker
Green Blinking Timer Light Mitsubishi WD-62527
hold the menu bottun for 10 seconds
after press power
see if that works
Sep 22, 2007 | Mitsubishi WD62527 62 in. LCD HDTV
Acer will not start up properly; "pulsing" On and Off
Hi Melody, Try removing the battery with the AC unplug for a couple of minutes (an hour preferably). Try with just the AC adapter only with no battery and see if it works; try with the battery only and see if it works, try with both the battery and the AC adapter and see if it works. If none of the above will make it work, then you have probably a hardware issue or BIOS power saving issue. Post back results of the 3 tries and will figure something else. Good luck and kind regards.
Sep 03, 2007 | Acer Aspire 5050-3242 Notebook
Sanyo DP42746 42 in. Plasma Television Logo
327 people viewed this question
Top Sanyo Televison & Video Experts
 Grubhead
Grubhead
Are you a Sanyo Televison and Video Expert? Answer questions, earn points and help others
