Milwaukee radio C12-28 DCR-0
Radio switching itself off at random times, battery or mains, but the screen looks as if all is ok, just the sound goes off and doesnt come back on, it does look as though the power is off but the screen still shows the time/channel etc sometimes its fine for hour other times its difficult to get it to stay on at all.
  • PETE A May 18, 2014
    strange one but yesterday it seemed to work ok on mains, tried different batteries which are all ok, sound goes off as if power cut, but display still working, turn volume up and sound came on, however another time gave it a tap and it came on?
SOURCE: Failure of radio to turn on
The solution to a nonworking Grundig S350 seems to be to junk it. My seller, Radio Shack, claimed to know of no one who could fix it nor had any solution. Your solution, to identify the overheating part and replace it is way beyond my expertise and beyond the people at my Radio Shack. I asked them. Hey, the S350 is made in China. We should always be sure to check where things are made before we buy them. Ex Grundig owner
Posted on Aug 25, 2007
Bajanguru
  • 7752 Answers
SOURCE: Blackberry 8310 Blank Screen
you need to have the LCD replaced.....take it to a mobile service center and have them replace it for you.
Posted on Feb 11, 2008
SOURCE: Magnavox MS3252S431
Replace:
Q7461 C33725
O7463 C32725
C2455 47uF@50V
Posted on Jun 17, 2008
SOURCE: TV turns itself on, keeps changing it's own channel
the problem is with the control panel of your tv...make sure your remote doesnt have any part in this...just remove and the batteries and check if the channels still are changing.....see if the onboard switch for channel changing is stuck ?..if stuck u can use homemade tools to pull it back......if your tv is within your gurantee period...just giv a call to customer care....if not u can take it to a local repair shop...there is nothin that u can urself do to make it right ...sorry....for further info contact at
Posted on Sep 07, 2008
noone
  • 105 Answers
SOURCE: 17" Sony Monitor Goes Black and No Light Shows On The Switch
Sounds like your backlight bulbs are wearing out.It is a common problem with Sony LCDs. Difficult to replace then.
Monitor Mike
Posted on Jan 04, 2009
Radio changing stations as well as tachometer at 0 or moving random while driving.
No, you have two separate issues. The tach is run by a logic chip in the instrument panel. This chip also runs other things, like the speedometer. So you have a bad solder joint on the tach motor(easy fix after the IP is out). The radio changing stations is because the button is stuck or moisture in the button. These aren't hard to replace either. You spend more time dismantling the radio than fixing the problem. Is the radio worth it?
Jan 20, 2015 | 2006 Kia Amanti
MILWAUKEE JOBSITE RADIO'S CLOCK DISPLAY WORKS BUT NO RADIO
if it work on battery and didnt work on 120 volt,the transformer is dead,i see a lot of radio with dead transformer.
if it dont work with battery and 120v,the control board have problem.
Oct 18, 2012 | Milwaukee Tool 49-24-0200 AM/FM Radio
Milwaukee Tools18V Lithium Ion battery is very intermittent in performance, it performs very poorly in the garage at 35 degrees, short battery life, poor performance, sometimes the battery will charge and...
Depending on how much you have used them, two years may be all you are going to get. Make sure the battery is fully discharged before re-charging if you have not tried that already. It is recommended for those type. Sound like just need a replacement. Are you sure the charger is ok? take care.
Jan 15, 2011 | Milwaukee Tool Milwaukee Power Tool...
My milwaukee radio just quite working ? why ?
may be there is something wrong with the male end you plug into the wall or the cord itself
Aug 20, 2010 | Milwaukee Tool Milwaukee 49 24 0280 Radio...
Milwaukee 28v battery problems
Take a look for warranty, and contact them ... If your warranty is out of date, than you must get new one. The best place is amazon for sure, Milwaukee 48 11 2830 M28 Lithium Ion Battery Pack. Hope this was helpful, cheers
Apr 14, 2009 | Milwaukee Tool Milwaukee 48 11 2830...
Milwaukee Job site radio
Questions:
1. Does the AC cord look ok? Not damaged?
2. Have you tried another AC outlet?
3. Does the AC cord unplug from the radio?
When you operate the radio from the AC power cord, the radio uses an internal power supply consisting of a step-down transformer, rectifier, and filter that converts the AC to DC to operate the radio.
When you run the radio off of batteries, it powers the radio directly. In some radios, when you plug the AC cord into the radio, it activates a switch that disconnects the battery voltage to the radio so that the batteries wont be damaged from the voltage created by the internal supply.
The radio can be powered by either the batteries or the internal supply. You don't want either supply affecting the other, so that is why a switch is sometimes used.
Since the radio works fine off of batteries, that would indicate that there is a problem with the internal power supply. This could be a blown fuse, bad transformer or bad rectifier diode.
Good Luck,
- Jim
Jan 24, 2008 | GE Superadio III AM/FM
 Grubhead
Grubhead
