Question about Thermador PRD304EG 30in Pro Grand Dual-Fuel Range
HOW TO CALIBRATE OVEN TEMPERATURE INDICATOR AND THE OVEN TEMPERATURE ON THERMADOR PRD304EG RANGE
OVEN KNOB AND OVEN TEMPERATURE INDICATOR DO NOT MATCH, ITS ABOUT 25 DEGREES OFF AND WHEN YOU TURN OVEN OFF THE COOLING BLOWER STOPS.
    Problem Solver:
  • 6 Answers
If you remove the knob, you will see the very center of the male part the know attaches to has a small flat head screw in the middle of it. Buy turning this screw in and out, you are micro adjusting the temp when the oven cycles on and off. Its best to have a digital thermometer set up within the oven so you can see exactly when the oven cycles on and off. It's going to fluctuate about 20-30 degrees. So set your oven to 350, let it turn on and watch carefully when the red light shuts off it should be between within 30 degrees from where you set it, up or down. If its too low,turn in( could be out, I forgot) the screw in the center of that know with a mini flat head screw driver. If you turn it and the light goes back on, you turned it up. If it does not go on in an quarter turn, you went lower. Once your digital thermometer matches up closely whith what your oven says, your good. 25 degrees isn't much to be gentile whith turning that middle screw, you could miss your mark and be off even more very easealy.
Posted on Jun 30, 2014
3 Suggested Answers
EllaWatson25
  • 725 Answers
SOURCE: I need a Thermador griddle control/ignitor & a light switch knob
We are Thermador factory authorized service and parts suppliers. Just contact us at:
http://www.fixya.com/repair/d499389-accurate_appliance_repair_service
and we can get your ignitor and light switch out to you asap.
We look forward to working you. Thanks, Ella
Posted on Nov 10, 2009
BarrettDenCo
  • 1772 Answers
SOURCE: Hello, Looking for the oven control knob for
Sorry to read about your problem, I hope this helps you out.
call this number for knobs 1-877-477-7278
I tried to help you. Please help me and Rate/Vote on my response, thanks and good luck
Posted on Dec 21, 2010
How to replace spark module?
How to replace spark module Todd, Check the attached links,instruction and guides, Good luck
"I hope this helped you out, if so let me know by pressing the helpful button. Check out some of my other posts if you need more tips and info."
http://forum.appliancepartspros.com/oven-repair-including-ranges-cooktops/42129-thermador-spark-module-replacement.html
Thermador Stove Burner Won Light
Burner on Thermador cooktop won light
Mar 22, 2016 | Thermador Cooktops
How to calibrate kenmore meat probe? it says 170degrees when plugged in cool.
170 degrees is likely the minimum it can read. put a container of water in the oven, put the probe in the water, and set the oven for 250 degrees. Watch the probe, and see what temperature it shows when the water boils. Depending on your altitude, it should be 212 or a little less.
Sep 04, 2014 | Kenmore 30 in. Freestanding Induction...
There is gas to the burners on my old Hardwick range, but not to the oven.
perhaps you need to call someone to have the gas line cleaned going to the oven .have heard that spider webs can stop gas flow .it doesn't take much
Jul 22, 2014 | Maytag Crosley Hardwick Caloric Kenmore 8"...
Hello, Looking for the oven control knob for Thermadore oven model no.CT130 alos mil;ssing small oven panel knob. Can you please help me ?
Dec 19, 2010 | Thermador 37 in. SGSX365 Gas Cooktop
Gas Range Oven Knob Area Gas Leak
The only two things you can do are pull the core of the oven thermostat and re-grease it, but that could throw your temperature calibration way off. The other is to replace the thermostat. Either way, a calibration is probably a good idea.
Feb 04, 2010 | Jenn-Air JGD8130 Gas Cooktop
We have a thermador 5 burner gas range top and the pilot light seems to have gone out. The burners don't go on but we smell gas. How do we re-light it?
Most gas range tops no longer have pilot lights but use an electronic ignition (sparker) to light the burner. Normally when you turn the burner on you should here a snapping or sparking sound, at which point the burner should ignite. Here is a link to the user manual for 36" - 5 burner Thermador rangetop...maybe this will help: http://dl.owneriq.net/a/ac64ae7b-1ed3-44a3-9235-e4dbd8fe4628.pdf
By the way, in the short term you could always use a match to light the burner. JUST BE VERY CAREFUL THE YOU HAVE THE MATCH LIT AND OVER THE DESIRED BURNER BEFORE YOU TURN KNOB TO START THE BURNER!!!!
Jan 15, 2010 | Thermador 37 in. SGSX365 Gas Cooktop
Nov 10, 2009 | Thermador 37 in. SGSX365 Gas Cooktop
Thermador Gas Range - Griddle ignition will not spark
I have a Thermador Gas Range PG364GDBS - Oven, 4 burners, and center griddle. All are gas. The four burners and gas oven work fine. The griddle just stopped working, no spark. Turning on the griddle control, the gas valve opens(hear it), gas flows (smell it), but the ignitor will not spark (no loud or faint spark that I can hear). I got a replacement ignition device (mount at the burner) thinking it might be the problem, but still no spark. I checked the AC voltage at the terminal and measured 39 VAC between the terminal and ground. Not sure if that is the correct voltage. Any insights or advice would be great.
Dec 07, 2008 | Thermador SGS36GS Gas Cooktop
Gas range with stricker burners and oven burner
Most likely the oven will not work because the striker is not coming on. I am not very familiar with this stove but most thermador gas oven uses a electronic igniter. the switch controls both the igniter(striker) and safety solenoid so if neither the striker or solenoid is not powered up the switch may be the problem
Regards
Nov 07, 2008 | Thermador SGS36GS Gas Cooktop
JENN-AIR MODEL D156B Electric oven
code f 0 means what?
Feb 11, 2008 | Cooktops
Thermador PRD304EG 30in Pro Grand Dual-Fuel Range Logo
122 people viewed this question
Top Thermador Cooktops Experts
Dan Webster
Dan Webster
richie46
Are you a Thermador Cooktop Expert? Answer questions, earn points and help others
