Question about Samsung WF337AA Front Load Washer
Samsung front load washer hour glass on screen and washer will not run
  • 4 Answers
Try unplugging it and re plugging it back in if that does not work you might have to replace the front electronic touch pad it might be burnt out ..
Posted on May 16, 2014
    Prodigy:
    An expert who has answered 500 questions.
  • Samsung Expert
  • 517 Answers
Any error code
Washer was running fine got to the spin now won't to anything DB appeared on the screen and it kept beeping
it's from an unbalanced load,you can try unplugging it or kill power to the washer forlike 10 minutes to reset the computer board and hopefully this will do the trick,i've never seen this code,i goggled it and found it's from an unbalanced load.hope this helps
Oct 20, 2014 | Samsung WF337AA Front Load Washer
What does the hour glass mean on the display
HI Bethany,
The users manual is located HERE. As I look thru the manual, I cannot see or locate any reference to an "Hour Glass". If you look thru the manual yourself, you may find the answer to your query there, yet if there are any further question, don't hesitate to ask.
Please rate and comment,
Thank You Joe
Sep 06, 2011 | Samsung WF337AA Front Load Washer
Washing machine won't drain. What does the hour glass symbol mean. It is defined in the owner's manual
From <http://support-us.samsung.com/cyber/popup/iframe/pop_troubleshooting_fr.jsp?idx=419733&modelname=WF409ANW&modelcode=&session_id=V5mMmkpq72BqyQB5Lny5vwblqvWTyT6hLbGQypLMbhMpMhlQBdfJ!-943087853!1669102353!1442424460210&from_osc=&homeid=2217>: "The hour glass is displayed to let you know the washer's timer is counting down. This is normal, and does not require service."
Dec 16, 2010 | Samsung WF337AA Front Load Washer
De1 error message on Samsung front load washer
Hello,De error refers to "Door Error".
You do not need to buy a new machine. You can fix this.
Look at the below mentioned link
http://lgknowledgebase.com/kb/index.php?View=entry&EntryID=799
No doubt the above page is for "LG", However it's the basic and would remain the same for all models and machines whether that's GE, LG, Samsung etc....
Thanks
May 30, 2010 | Samsung WF419AA Front Load Washer / Dryer
Washer Glass window in front load door glass is broken.
they should replace it. sounds like problem with unit.proberly only replace door . good luck with it.
Apr 08, 2010 | Kenmore Front Load Washer
Samsung Front load washer has small leak coming from door. How can this be fixed? It has a mold problem and I've been trying to clean it. Now, it's leaking, too.
First check not a likely cause: Does your door stay centrally aligned when closed? If it doesn't center it could cause a leak. The glass bowl on the inside must be centered in the gasket. It will have to be adjusted or bent to center.
Second check: If it is a leak that happens when it is running then you will need to reset your gasket if there is a wrinkle in it or a new gasket. To check for a wrinkle put 1 layer of paper towels around the glass bowl insert, close the door and turn it on. Let it run for a bit then check the paper towel. You should be able to find the place leaking by the wet spot on the towel. If it only leaks a little when you open the door then you have a choice, keep a rag handy and mop it up (I'm talking about a couple of tablespoons at the most) or follow the instructions above. Even with a new gasket front loaders often leak a few drops that mop up nicely with the next load of clothes.
Warning: the gaskets don't just pop in they take some work. One side is attached to stationary cabinet and the other to the drum which moves a bunch. This will take a parts breakdown at a minimum. If you see any gasket sealant listed make sure and get some.
Apr 07, 2010 | Samsung WF337AA Front Load Washer
Samsung WF337AA Front Load Washer Logo
495 people viewed this question
Top Samsung Washing Machines Experts
Jaime Hernandez
shaun taylor
Are you a Samsung Washing Machine Expert? Answer questions, earn points and help others
