Question about Radio Communications
My toyota F Premio 2011 engine check light is always on...after check with a computer i found oxygen sensor,cpu malfunction, knock control and crankshaft sensor....how do i solve these problems?
    Genius:
  • 1,552 Answers
Get a qualified Toyota dealer to replace the CPU -- it's probably causing "false-positive" conditions -- there may be nothing really wrong with the oxygen-sensor and the crankshaft sensor.
Posted on May 16, 2014
Which O2 sensor is needed for The code P1135 tOYOTA aVALON 2002
code p 0035 refers to heated oxygen sensor(HO2S)--LH front ---heater circuit malfunction===causes ---wiring--HO2S--air induction system---fuel pressure ----injector/s---ECM
heated oxygen sensors are always located in the exhaust manifold/pipe before the cat converter
they control the fuel/air ratio parameters for the ECM to get best burn of the mixture
Oxygen sensor (O2) is always after the cat converter and sets the parameters for the cat burn off
Dec 10, 2016 | 2002 Toyota Avalon
I am getting the following codes on my 2002 Nissan Altima v6 3.5 liter P1430, P1420, P1805, P1152, P1102, P1011, P1021 & P1335 I'm going crazy here. Please help!
Definition of Diagnostic Trouble Code P1430 Ford: Electric Air Pump Secondary Lincoln: Electric Air Pump Secondary Mazda: Electric Air Pump Secondary Mercury: Electric Air Pump Secondary Toyota: Intake Constrictor CTRL Circuit Open or Short
Definition of Diagnostic Trouble Code P1420 Audi: Second Air Injection Valve Circ Electrical Malfunction BMW: Secondary Air Valve Control Circuit Electrical Buick: Intake Air Low Pressure Switch Circuit Low Voltage Cadillac: Intake Air Low Pressure Switch Circuit Low Voltage Chevrolet: Intake Air Low Pressure Switch Circuit Low Voltage Chrysler: Register Resonant Charging 1 (RRC1) Dodge: Register Resonant Charging 1 (RRC1) Ford: Catalyst Temperature Sensor GMC: Intake Air Low Pressure Switch Circuit Low Voltage Honda: Nox Adsorptive Catalyst System Efficiency Below Threshold Catalytic converter Jeep: Register Resonant Charging 1 (RRC1) Lincoln: Catalyst Temperature Sensor Mazda: Catalyst system efficiency below threshold (bank 1) Mercedes: AIR Pump Switch over Valve Mercury: Catalyst Temperature Sensor Oldsmobile: Intake Air Low Pressure Switch Circuit Low Voltage Pontiac: Intake Air Low Pressure Switch Circuit Low Voltage Saturn: Intake Air Low Pressure Switch Circuit Low Voltage Subaru: EVAP Purge Control Solenoid Circuit High Input Toyota: SCV Control Circuit Malfunction Volkswagen: Second Air Injection Valve Circ Electrical Malfunction
Definition of Diagnostic Trouble Code P1805 Ford: Four wheel drive high indicator circuit failure Lincoln: Four wheel drive high indicator circuit failure Mazda: (4WD) High Indicator Open Circuit Mercury: Four wheel drive high indicator circuit failure Toyota: SB Solenoid Circuit Malfunction
Definition of Diagnostic Trouble Code P1152 Audi: Bank1, Long Term Fuel Trim, Range 2 Leanness Lower Limit Exceeded BMW: Oxygen Sensor Heater Circuit Low Voltage (Bank 2 Sensor 1) Ford: Lack Of Heated Oxygen Sensor Bank 2 Sensor 1 Switches - Sensor Indicates Rich Jaguar: Lack of H02S-21 switch, sensor indicates rich Land Rover: Oxygen sensor response time bank 2.Short circuit to ground Lincoln: Lack Of Heated Oxygen Sensor Bank 2 Sensor 1 Switches - Sensor Indicates Rich Mazda: Lack Of Heated Oxygen Sensor Bank 2 Sensor 1 Switches - Sensor Indicates Rich Mercury: Lack Of Heated Oxygen Sensor Bank 2 Sensor 1 Switches - Sensor Indicates Rich Subaru: Oxygen sensor range /performance problem (Low) Volkswagen: Bank1, Long Term Fuel Trim, Range 2 Leanness Lower Limit Exceeded Volvo: Oxygen Sensor Front, Bank 2
Definition of Diagnostic Trouble Code P1102 Acura: Mass Airflow (MAF) Sensor Lower Than Expected Comprehensive Audi: Oxygen Sensor Heating Circuit,Bank1-Sensor1 Short to B+ Chrysler: HEV Stop Request Performance Dodge: HEV Stop Request Performance Hyundai: MAP Sensor Circuit Low Input Jeep: HEV Stop Request Performance Kia: Heated Oxygen Sensor Bank 1 Sensor 1 Heater Circuit High Input Land Rover: Throttle to air flow plausibility not active.Last occurrence - minimum signal Mazda: Mass Air Flow Sensor In Range But Lower Than Expected Mitsubishi: Traction Control Ventilation Solenoid Circuit Porsche: Heated Oxygen Sensor 1 Ahead Of TWC Heater Short To B+ Saab: Front Heated Oxygen Sensor Bank 1, Control Module Input, Current in Pre-Heating Circuit Too High Subaru: Pressure Sources Switching Solenoid Valve Circuit Malfunction Volkswagen: Oxygen Sensor Heating Circuit,Bank1-Sensor1 Short to B+ Volvo: Power Stage Group B
Definition of Diagnostic Trouble Code P1011 Saab: Injector Cylinder 1 Shorting To Ground Toyota: OCV for VVTL Open Malfunction (Bank 1)
Definition of Diagnostic Trouble Code P1021 Honda: Valve Pause System Stuck On Comprehensive Mitsubishi: OCV OPN. Bank 1 Saab: Injector Cylinder 2 Shorting To Ground Toyota: OCV for VVTL Open Malfunction (Bank 2)
Definition of Diagnostic Trouble Code P1335 Audi: Engine Torque Monitoring 2 Control Limit Exceeded Buick: CKP Circuit Cadillac: CKP Circuit Chevrolet: CKP Circuit Ford: (EGR) Position Sensor Minimum Stop Performance GMC: CKP Circuit Infiniti: CKP Sensor (Ref) Jaguar: CKPS Circuit Malfunction Land Rover: Exhaust gas recirculation position sensor minimum stop performance. Lexus: Igniter Circuit Malfunction Bank 2 (During Engine Running) Lincoln: (EGR) Position Sensor Minimum Stop Performance Mazda: (EGR) Position Sensor Minimum Stop Performance Mercedes: CKP Sensor Circuit Malfunction, Bank 2 Mercury: (EGR) Position Sensor Minimum Stop Performance Oldsmobile: CKP Circuit Pontiac: CKP Circuit Saturn: CKP Circuit Toyota: No CKP Sensor Signal Engine Running Volkswagen: Engine Torque Monitoring 2 Control Limit Exceeded http://www.obd-codes.com/trouble_codes/nissan
Jun 29, 2015 | Nissan Cars & Trucks
Trouble code in a 2003 kia Sedona PO106
These are the only ones I have listed
P0100 Mass Air Flow or Volume Air Flow Circuit Malfunction.
P0101 Mass Air Flow or Volume Air Flow Circuit Range/Performance problem.
P0102 Mass Air Flow or Volume Air Flow Circuit Low Input.
P0103 Mass Air Flow or Volume Air Flow Circuit High Input.
P0107 MAP/BARO Circuit Low Input.
P0108 MAP/BARO Circuit High Input.
P0110 A/T Circuit Malfunction.
P0115 Engine Coolant Temperature Circuit Malfunction.
P0116 Engine Coolant Temperature Circuit Range/Performance Condition.
P0117 Engine Coolant Temperature Circuit Low Input.
P0118 Engine Coolant Temperature Circuit High Input.
P0120 Throttle Position Malfunction - Circuit A.
P0122 APP/TPP Sensor Switch Low Input - Circuit A.
P0123 APP/TPP Sensor Switch High Input - Circuit A.
P0125 Insufficient Coolant Temperature for Closed Loop Fuel Control.
P0130 Oxygen Sensor Circuit Malfunction - Bankicon1.png 1 Sensor 1.
P0131 Oxygen Sensor Circuit Low Voltage - Bank 1 Sensor 1.
P0132 Oxygen Sensor Circuit High Voltage - Bank 1 Sensor 1.
P0133 Oxygen Sensor Circuit Slow Response - Bank 1 Sensor 1.
P0134 Oxygen Sensor Circuit No Activity detected - Bank 1 Sensor 1.
P0135 Oxygen Sensor Heater Circuit Malfunction - Bank 1 Sensor 1.
P0136 Oxygen Sensor Circuit Malfunction - Bank 1 Sensor 2.
P0137 Oxygen Sensor Circuit Low Voltage - Bank 1 Sensor 2.
P0138 Oxygen Sensor Circuit High Voltage - Bank 1 Sensor 2.
P0139 Oxygen Sensor Circuit Slow Response - Bank 1 Sensor 2.
P0140 Oxygen Sensor Circuit No Activity detected - Bank 1 Sensor 2.
P0141 Oxygen Sensor Heater Circuit Malfunction - Bank 1 Sensor 2.
P0170 Fuel Trim Malfunction - Bank 1.
P0171 System too Lean - Bank 1.
P0172 System too Rich - Bank 1.
P0261 Injector Circuit Low - Cyl. 1.
P0262 Injector Circuit High - Cyl. 1.
P0264 Injector Circuit Low - Cyl. 2.
P0265 Injector Circuit High - Cyl. 2.
P0267 Injector Circuit Low - Cyl. 3.
P0268 Injector Circuit High - Cyl. 3.
P0270 Injector Circuit Low - Cyl. 4.
P0271 Injector Circuit High - Cyl. 4.
P0300 Multiple/Random Misfire detected.
P0301 Misfire detected - Cyls. 1-4.
P0302 Misfire detected - Cyls. 1-4.
P0303 Misfire detected - Cyls. 1-4.
P0304 Misfire detected - Cyls. 1-4.
P0325 Knock Sensor Circuit Malfunction
P0326 Knock Sensor 1 Circuit Range/Performance - Bank 1 or Single Sensor.
P0335 Crankshaft Position Sensor Malfunction - Circuit A.
P0336 Crankshaft Position Sensor Range/Performance - Circuit A.
P0340 Crankshaft Position Sensor Circuit Malfunction.
P0342 Crankshaft Position Sensor Circuit Low Input.
P0343 Crankshaft Position Sensor Circuit High Input.
P0400 EGR Flow Malfunction.
P0403 EGR Circuit Malfunction.
P0404 EGR Circuit Range/Performance Malfunction.
P0420 Catalyst System Efficiencyicon1.png below Threshold - Bank 1.
P0422 Main Catalyst Efficiency below Threshold - Bank 1.
P0440 Evaporative Control Malfunction.
P0441 Evaporative Control System - Improper Purge.
P0442 Evaporative Control System - Small Leak detected.
P0443 Evaporative Control System Purge Control Valve Circuit Malfunction.
P0446 Evaporative Vent Control Circuit Malfunction.
P0447 Evaporative Vent Control Circuit Open.
P0448 Evaporative Vent Control Circuit Short.
P0450 Evaporative System Pressure Sensor Circuit Malfunction.
P0452 Evaporative Control System Pressure Sensor Low Input.
P0453 Evaporative Control System Pressure Sensor High Input.
P0455 Evaporative Control System - Large Leak detected.
P0470 Exhaust Pressure Sensor Malfunction.
P0500 Vehicle Speed Sensor Malfunction.
P0501 Vehicle Speed Sensor Range/Performance.
P0505 Idle Air Control System Malfunction.
P0506 Idle Air Control System Malfunction - RPM Lower than expected.
P0507 Idle Air Control System Malfunction - RPM Higher than expected.
P0510 CTP Switch Malfunction.
P0561 System Voltage Unstable.
P0562 System Voltage Low.
P0563 System Voltage High.
P0601 Internal Control Module Memory Checksum Error.
P0604 Internal Control Module RAM Error.
P0703 Torque Converter/Brake Pedal Switch Malfunction - Circuit B.
P0705 Transaxle Range Sensor Circuit Malfunction (PRNDL Input).
P0706 A/T Range Sensor Circuit Range/ Performanceicon1.png.
P0710 Transaxle Fluid Temperature Sensor Circuit Malfunction.
P0711 A/T Fluid Temperature Sensor Circuit Range/Performance.
P0715 Input/Turbine Speed Sensor Circuit Malfunction.
P0722 Output Speed Sensor Circuit No Signal.
P0726 Engine Speed Input Circuit Range/ Performance.
P0727 Engine Speed Input Circuit - No Signal.
P0731 A/T Gear 1 Improper Ratio.
P0732 A/T Gear 2 Improper Ratio.
P0733 A/T Gear 3 Improper Ratio.
P0734 A/T Gear 4 Improper Ratio.
P0740 Torque Converter Clutch System Malfunction.
P0743 Torque Converter Clutch Circuit Electrical.
P0750 Shift Solenoid "A" Malfunction.
P0753 Shift Solenoid "A" Electrical.
P0755 Shift Solenoid "B" Malfunction.
P0758 Shift Solenoid "B" Electrical.
P0760 Shift Solenoid "C" Malfunction.
P1000 Readiness Function Code.
P1115 Engine Coolant Temperature Signal from ECM to TCM.
P1121 Throttle Position Sensor Signal Malfunction from ECM to TCM.
P1170 Front Heated Oxygen Sensor Stuck.
P1195 EGR Pressure Sensor (1.6L) or Boost Sensor (1.8L) Open or Short.
P1196 Ignition Switch "Start" Open or Short (1.6L).
P1250 Pressure Regulator Control Solenoid Valve Open or Short.
P1252 Pressure Regulator Control Solenoid Valve No. 2 Circuit Malfunction.
P1307 Chassisicon1.png Acceleration Sensor Signal Malfunction.
P1308 Chassis Acceleration Sensor Signal Low.
P1309 Chassis Acceleration Sensor Signal High.
P1345 No SGC Signal (1.6L).
P1386 Knock Sensor Control Zero Test.
P1402 EGR Valve Position Sensor Open or Short.
P1449 Canister Drain Cut Valve Open or Short (1.8L).
P1450 Excessive Vacuum Leak.
P1455 Fuel Tank Sending Unit Open or Short (1.8L).
P1457 Purge Solenoid Valve Low System Malfunction.
P1458 A/C Compressor Control Signal Malfunction.
P1485 EGR Solenoid Valve Vacuum Open or Short.
P1486 EGR Solenoid Valve Vent Open or Short.
P1487 EGR Boost Sensor Solenoid Valve Open or Short.
P1496 EGR Stepper Motoricon1.png Malfunction - Circuit 1 (1.8L).
P1497 EGR Stepper Motor Malfunction - Circuit 2 (1.8L).
P1498 EGR Stepper Motor Malfunction - Circuit 3 (1.8L).
P1499 EGR Stepper Motor Malfunction - Circuit 4 (1.8L).
P1500 No Vehicle Speed Signal to TCM.
P1505 Idle Air Control Valve Opening Coil Voltage Low.
P1506 Idle Air Control Valve Opening Coil Voltage High.
P1507 Idle Air Control Valve Closing Coil Voltage Low.
P1508 Idle Air Control Valve Closing Coil Voltage High.
P1523 VICS Solenoid Valve.
P1586 A/T-M/T Codification.
P1608 PCM Malfunction.
P1611 MIL Request Circuit Voltage Low.
P1614 MIL Request Circuit Voltage High.
P1624 MIL Request Signal from TCM to ECM.
P1631 Alternator "T" Open or No Power Output (1.8L).
P1632 Battery Voltage Detection Circuit for Alternator Regulator (1.8L).
P1633 Battery Overcharge.
P1634 Alternator "B" Open (1.8L).
P1693 MIL Circuit Malfunction.
P1743 Torque Converter Clutch Solenoid Valve Open or Short.
P1794 Battery or Circuit Failure.
P1795 4WD Switch Signal Malfunction.
P1797 P or N Range Signal or Clutch Pedal Position Switch Open or Short
Oct 01, 2014 | Vehicle Parts & Accessories
My car is not moveing, and it takes lots of fuel
That means you need the Oxygen Sensor, Knock sensor Camshaft position Sensor is usually on the outside of the timing cover which is a good thing. . Bank one simply means you are in front of your engine and you would pull the wire from the Number one spark plug and that part of your engine is bank one. The opposite side is bank two.
I would have the ECM (Engine Control Module ) checked. So many sensors going bad at the same time is just not normal. It's something that only a professional can do . Sorry about that. But to replace all those sensors one at a time would cost you not only money but a serious amount of time.
Oct 21, 2017 | 1997 Toyota Camry
2002 toyota avalon engine check light on P0078 and P007C
P0050 HO2S Heated Oxygen Sensor -Control Circuit (Bank 2 Sensor 1)
P0051 HO2S Heated Oxygen Sensor -Control Circuit Low (Bank 2 Sensor 1)
P0052 HO2S Heated Oxygen Sensor -Control Circuit High (Bank 2 Sensor 1)
P0053 HO2S Heated Oxygen Sensor -Resistance (Bank 1 Sensor 1)
P0054 HO2S Heated Oxygen Sensor -Resistance (Bank 1 Sensor 2)
P0055 HO2S Heated Oxygen Sensor -Resistance (Bank 1 Sensor 3)
P0056 HO2S Heated Oxygen Sensor -Control Circuit (Bank 2 Sensor 2)
P0057 HO2S Heated Oxygen Sensor -Control Circuit Low (Bank 2 Sensor 2)
P0058 HO2S Heated Oxygen Sensor -Control Circuit High (Bank 2 Sensor 2)
P0059 HO2S Heated Oxygen Sensor -Resistance (Bank 2 Sensor 1)
P0060 HO2S Heated Oxygen Sensor -Resistance (Bank 2 Sensor 2)
P0061 HO2S Heated Oxygen Sensor -Resistance (Bank 2 Sensor 3)
P0062 HO2S Heated Oxygen Sensor -Control Circuit (Bank 2 Sensor 3)
P0063 HO2S Heated Oxygen Sensor -Control Circuit Low (Bank 2 Sensor 3)
P0064 HO2S Heated Oxygen Sensor -Control Circuit High (Bank 2 Sensor 3)
P0065 Air Assisted Injector -Range/Performance
P0066 Air Assisted Injector -Circuit Malfunction or Circuit Low
P0067 Air Assisted Injector -Circuit High
P0068 (MAP) Manifold Absolute Pressure /(MAF) Mass Air Flow - Throttle Position
Correlation
P0069 (MAP) Manifold Absolute Pressure / (BARO)Barometric Pressure Correlation
P0070 Ambient/Outside Air Temperature Sensor -Circuit Malfunction
P0071 Ambient/Outside Air Temperature Sensor -Range/Performance Problem
P0072 Ambient/Outside Air Temperature Sensor -Circuit Low Input
P0073 Ambient/Outside Air Temperature Sensor -Circuit High Input
P0074 Ambient/Outside Air Temperature Sensor -Circuit Intermittent
P0075 Intake Valve Control Solenoid Circuit Malfunction (Bank 1)
P0076 Intake Valve Control Solenoid Circuit Low (Bank 1)
P0077 Intake Valve Control Solenoid Circuit High (Bank 1)
P0078 Exhaust Valve Control Solenoid Circuit Malfunction (Bank 1)
P0079 Exhaust Valve Control Solenoid Circuit Low (Bank 1)
P0080 Exhaust Valve Control Solenoid Circuit High (Bank 1)
P0081 Intake valve Control Solenoid Circuit Malfunction (Bank 2)
P0082 Intake Valve Control Solenoid Circuit Low (Bank 2)
P0083 Intake Valve Control Solenoid Circuit High (Bank 2)
P0084 Exhaust Valve Control Solenoid Circuit Malfunction (Bank 2)
Mar 22, 2013 | 2002 Toyota Avalon
I have an 04 Kia spectra with a PO121 code. What domestic this mean
Well.... Here is a full list of the codes I can find that Kia list. Oddly it jumps from P0120 to P0122
I hope the attached will help, but you may need to talk to your dealer.
Diagnostic Codes
Kia
Without Onboard Diagnostics (OBD-II)
2 Distributor no Signal.
3 Distributor G Signal.
7 Fault on SGT Signal.
8 Mass Air Flow Sensor.
9 Engine Coolant Temperature Sensor.
10 Intake Air Temperature Sensor.
12 Throttle Position Sensor.
14 Atmospheric Pressure Sensor.
15 Oxygen Sensor.
16 EGR Valve Position Sensor.
17 Feedback System.
18 Injector No. 1 open or short.
19 Injector No. 2 open or short.
20 Injector No. 3 open or short.
21 Injector No. 4 open or short.
24 Fuel Pump Relay open or short.
25 Pressure Regulator Control Solenoid Valve.
26 Purge Control Solenoid Valve.
28 Solenoid Valve (EGR) open or short.
34 Idle Speed Control Solenoid Valve.
35 Deteriorated Injector.
36 Deteriorated Air Flow Sensor.
37 Intake System Air Leakage.
41 Variable Inertia Charging System Solenoid Valve.
46 A/C Cut Relay open or short.
48 Power Stage Group 1 Malfunction (inside ECM). Injector 1-4 Purge Solenoid Valve, EGR Solenoid Valve or Damaged Power Stage.
49 Power Stage Group 2 Malfunction (inside ECM). Idle Speed Control Valve Failure or Damaged Power Stage.
56 Idle Speed Control Valve Closing Coil open or short.
57 A/C Compressor Input Signal short.
73 Vehicle Speed Sensor open or short.
87 Malfunction Indicator Lamp short Circuit.
88 ECM Data.
99 Battery.
OBD-II
P0130 Oxygen Sensor Circuit Malfunction - Bank 1 Sensor 1.
P0420 Catalyst System Efficiency below Threshold - Bank 1.
P0706 A/T Range Sensor Circuit Range/ Performance.
P1307 Chassis Acceleration Sensor Signal Malfunction.
P1496 EGR Stepper Motor Malfunction - Circuit 1 (1.8L).
P1797 P or N Range Signal or Clutch Pedal Position Switch Open or Short.
Jun 21, 2011 | 2004 Kia Spectra
My Jeep Liberty Has a 3.7 L V6, it has problems starting. A code popped up that was P0325? What does this code mean?
CARB (California Air Resources Board) has a consistent policy regarding monitoring knock (Ks) sensors but vehicle manufacturers don't have a consistent way of using knock sensor circuitry. There are generally two methods that manufacturers have for using the knock sensor.
In the first design, which is found in most vehicles, the knock sensor plays an active role in controlling ignition timing. In this system, the PCM is advancing ignition timing until knock occurs and then retards timing slightly. This system runs on the verge of engine knock at all times. In this system the function of the knock sensor circuit is critical. If the sensor malfunctioned, precise ignition timing control could not be achieved.
A "dead" sensor circuit would not be able to detect actual knock, timing would be overly advanced, and NOX exhaust emissions would increase. For this reason, manufacturers that use the knock sensor in this manner are required to monitor this sensor and light the MIL light when a malfunction is detected.
In the second design, the knock sensor plays a very passive role and is really only on the engine for protection purposes. The various engine sensors send their information to the PCM to determine ignition timing. The PCM uses this information to control the ignition timing based on look-up tables stored in its memory. If ignition knock is detected, the PCM will take action and ****** the timing a few degrees. This type of control is generally used to control spark knock caused by changes in fuel octane.
Used in this way, the knock sensor is less critical to emissions and may not even have a measurable emission impact. Unlike the first design, a "dead" knock sensor in this system will have little to no effect on the operation of the engine. Manufacturers that use this design are not required to monitor the sensor under EPA OBDII regulations and will not turn on the MIL if the P0325 DTC is set.
Remember, this sensor does not change the operation of the engine. The customer will not notice any change in the way the vehicle operates. The knock sensor system has a one trip detection logic and WILL NOT turn on the MIL or store Freeze Frame data.
How to Diagnose P0325
Most technicians know how this type of sensor operates. Its element produces a voltage when the sensor picks up a vibration, usually caused by engine detonation.Technicians then check the ohmic value of the sensor.
Maybe this was of some help.Your valuable feedback would be appreciated.Thanks for choosing Fixya.
Jun 09, 2011 | 2003 Jeep Liberty
Check engine light comes on
A malfunction indicator lamp (MIL), commonly referred to as the "Check Engine Light" is an indicator of malfunction of the computerized engine management system. It is found on the instrument console of most automobiles. When illuminated, it is typically either an amber or red color. On vehicles equipped with OBD-II, the light has two stages: steady (indicating a minor fault such as a loose gas cap or failing oxygen sensor) and flashing (indicating a severe fault, that will eventually destroy the catalytic converter, such as a misfire). When the MIL is lit, the engine control unit stores a fault code related to the malfunction, which can be retrieved with a scan tool and used for further diagnosis. The malfunction indicator lamp is usually labeled with the text check engine, service engine soon, check engine soon, or a picture of an engine.
The MIL appeared in the early 80s along with computerized engine controls. Even the earliest systems, such as GM's CCC (Computer Command Carburetor) system had self diagnosis functionality. When the computer detected a fault, it illuminated the MIL. Up until OBDII, on most cars the MIL could output codes, when two pins on the ALDL are jumped, the light would flash the codes, for instance (blink) (pause) (blink) (blink) for code 12. Some manufacturers retained this feature even after OBDII, such as Honda.
Hope this help (remember comment and rated this). Good luck.
May 09, 2010 | 1995 Toyota Camry
Understanding trouble codes for my vehicles
first the quest, this is common for nissan, replace the knock sensor, this sensor is located under the intake manifold rear of engine, some models you can sneak sensor out without removing the intake, this will take care of that car. now the camry, im guessing this is a 4 cylinder engine, replace the air fuel sensor (oxygen sensor) thats on the exhaust manifold. this will solve that problem. hope this helped.
Jan 25, 2010 | 1999 Toyota Camry
I have problem with code 1126 (toyota 4 runner 2001
Manufacturer Specific Codes
P1100
BARO Sensor Circuit - Read Our Article on Automotive Circuit Testing For Help With This Toyota Check Engine Light Code
P1120 Accelerator Pedal Position Sensor Circuit - Read Our Article on Automotive Circuit Testing For Help With This Toyota Check Engine Light Code
P1121 Accelerator Pedal Position Sensor Range/Performance Problem
P1125 Throttle Control Motor Circuit - Read Our Article on Automotive Circuit Testing For Help With This Toyota Check Engine Light Code
P1126 Magnetic Clutch Circuit
P1127 ETCS Actuator Power Source Circuit
P1128 Throttle Control Motor Lock
P1129 Electric Throttle Control System
P1130 Air/Fuel Sensor Circuit Range/Performance (Bank 1 Sensor 1) - Read Our Article On Oxygen Sensor Codes For Help With This Toyota Check Engine Light Code - More Related Information
P1133 Air/Fuel Sensor Circuit Response (Bank 1 Sensor 1) - Read Our Article On Oxygen Sensor Codes For Help With This Toyota Check Engine Light Code
P1135 Air/Fuel Sensor Heater Circuit Response (Bank 1 Sensor 1) - Read Our Article On Oxygen Sensor Codes For Help With This Toyota Check Engine Light Code - More Related Information
P1150 Air/Fuel Sensor Circuit Range/Performance (Bank 1 Sensor 2)
P1153 Air/Fuel Sensor Circuit Response (Bank 1 Sensor 2) - Read Our Article On Oxygen Sensor Codes For Help With This Toyota Check Engine Light Code
P1155 Air/Fuel Sensor Heater Circuit. (Bank 1 Sensor 2)
P1200 Fuel Pump Relay Circuit
P1300 Igniter Circuit Malfunction - No. 1
P1305 Igniter Circuit Malfunction - No. 2
P1335 No Crankshaft Position Sensor Signal - Engine Running
P1349 VVT System
P1400 Sub-Throttle Position Sensor
P1401 Sub-Throttle Position Sensor Range/Performance Problem
P1405 Turbo Pressure Sensor Circuit
P1406 Turbo Pressure Sensor Range/Performance Problem
P1410 EGR Valve Position Sensor Circuit Malfunction - Read Our Article on EGR Valve Codes For Help With This Toyota Check Engine Light Code
P1411 EGR Valve Position Sensor Circuit Range/Performance - Read Our Article on EGR Valve Codes For Help With This Toyota Check Engine Light Code
P1500 Starter Signal Circuit
P1510 Boost Pressure Control Circuit
P1511 Boost Pressure Low
P1512 Boost Pressure High
P1520 Stop Lamp Switch Signal Malfunction
P1565 Cruise Control Main Switch Circuit
P1600 ECM BATT Malfunction
P1605 Knock Control CPU
P1630 Traction Control System
P1633 ECM
P1652 Idle Air Control Valve Control Circuit
P1656 OCV Circuit
P1658 Wastegate Valve Control Circuit
P1661 EGR Circuit
P1662 EGR Bypass Valve Control Circuit
P1700 Vehicle Speed Sensor '2' Circuit Fault
P1705 Direct Clutch Speed Circuit Fault
P1765 Linear Shift Solenoid Circuit Fault
P1780 Park/Neutral Position Switch Malfunction (Only For A/T)
Back To Top Of Toyota Check Engine Light Codes Page
Mar 21, 2009 | 2002 Toyota 4Runner
Radio Communications Logo
46 people viewed this question
Top Radio Communications Experts
eradiostore
eradiostore
Are you a Radio Communication Expert? Answer questions, earn points and help others
