Question about Goodman CLQ36AR49 Air Conditioner
Any ideas as to why the panel breaker for my Goodman CPE24-1AB heat pump would immediately trip when the air conditioner is turned on?
The air handler (which is on a separate breaker) runs, but the heat pump does not. Something is causing the breaker to trip. As far as I know things were working fine when the heater was running. I am going to try the heater again to see if the heat pump breaker trips.
    Cheetah:
    An expert who has answered 20 or more questions within one hour.
    Night Owl:
    An expert who has answered 10 or more questions between 12 midnight and 6am on the same day.
  • 58 Answers
Could be bad compressor could be shorted causing breaker to trip. or could just be a capacitor or even a fan motor. try changing capacitor do you know how to use volt ohm meter and amp meter if so i can offer more help
Posted on May 16, 2014
  • Greg Benton
    Greg Benton May 21, 2014
    Thanks for your response. I do know how to use a volt-ohm-amp meter. I disconnected the fan from the capacitor, and the breaker still tripped. I disconnected the compressor, and the breaker still tripped. When the fan and compressor were disconnected from the capacitor the breaker didn't trip. There is some sort of relay on the controller board that supplies the voltage to the fan and compressor via the cap and a terminal block. The relay is functionally in two parts: LVDR and HVDR. I believe that stands for low-voltage and high-voltage driver(?) relay(?). I did replace the cap, but the results were the same. Thanks for your help.
  • Greg Benton
    I forgot to add that the breaker trips when the heat is on as well.
    Problem Solver:
  • 15 Answers
Without looking up the specifications for this heat pump, I cannot be certain, but I expect the operation to provide cooling may require more power than when heating. You probably can find the specifications online for this unit. As you probably know, power is measured in watts and is calculated by voltage times current. This also is likely to be 240 volts operation. If you take the specified power on cooling and divide by voltage (240), that will indicate the current in amperage that will be required to start it. Your circuit breaker is set for current and needs to be a higher current than is required. If that is the problem, you can buy circuit breakers at Home Depot or Lowes. You have to remove the front panel of your breaker box and snap out the circuit breaker. To be safe it would be good to turn off the main breaker switch before you open the front panel and remove the circuit breaker for the heat pump. Should your calculation of current required be less than the rating of the circuit breaker, that implies a malfunction of the heat pump in the cooling mode and would require a service call to the local representative of the heat pump manufacturer.
  • Greg Benton
    Thanks for your response. I disconnected the fan from the capacitor, and the breaker still tripped. I disconnected the compressor, and the breaker still tripped. When the fan and compressor were disconnected from the capacitor the breaker didn't trip. There is some sort of relay on the controller board that supplies the voltage to the fan and compressor via the cap and a terminal block. The relay is functionally in two parts: LVDR and HVDR. I believe that stands for low-voltage and high-voltage driver(?) relay(?). I did replace the cap, but the results were the same. The breaker trips when the heat is on as well. Again, thanks for your help.
5 Suggested Answers
koolbreezes
  • 540 Answers
SOURCE: AC breaker trips after 10 minutes
Whats the amp breaker? Is this for the inside unit or the outside condenser? If the inside and gas heat you have a bad fan motor, If its an electric furnace , the same, but if its the outside unit, the fan could be going bad, locking up and the compressor still runs and pulls high ampsand tripps breaker or the compressor is just pulling too many amps due to plugged coils with dirt , grass or weeds blocking airflow.(koolbreezes74401@yahoo.com)
Posted on Jun 09, 2008
jumptrout51
  • 3361 Answers
SOURCE: tripping breaker
There is a short circuit in the fan motor or compressor most likely. Disconnect the common wire to the compressor and try again. If the fan comes on and the breaker does not trip you have a bad compressor or a bad wire touching somewhere. Also,check the capacitor. Is it bulgded out or a burned wire? Could be a bad capacitor.
Posted on Aug 22, 2009
the dr
  • 447 Answers
SOURCE: my air conditioner air handler humsbut moter does
either bad motor ....or.... if you are lucky a bad run capacitor. you will need some sort of capacitor checker and multimeter to diagnose it further.
Posted on Oct 31, 2009
chiefmanmike
  • 10 Answers
SOURCE: I have a Goodman CKL
usually its a bad motor, compressor or even contactor like a dead short your breaker trips to tell you there is a problem
Posted on May 31, 2011
Why is my heat pump tripping circuit breaker continuously?
Probably a weak breaker. I would change it and see if it happens again. If the problem continues call a hvac guy out
Jan 10, 2016 | Rheem 2.5 Ton 13 Seer Heat Pump -...
Want to reinstall...split system heat pump and gas furnace both goodman
What is current refrigerant being used in the system being replaced? What are the sizes of the existing breakers for the Air Handler, and the outside unit? Do you plan on replacing cooper lines ? Use drain line already there?
o
Dec 05, 2015 | Goodman Heating & Cooling
What cause 3 amp fuse to keep blowing when power in turn on goodman air handler
The 3 amp fuse is in the red low voltage (24 volt) thermostat wire
and only gets power when the thermostat is set to turn on heat or a/c It should be connected to the red wire from the thermostat
Nov 13, 2014 | Goodman Manufacturing Goodman ARUF48D14...
The air handler does not come on
Check to see if breaker to unit has tripped.If it has you may have a bad motor. You may have a bad control transformer in the air handler,not sending 24 volts to tstat.
Nov 27, 2010 | Goodman CKL36AR36 Air Conditioner
My 5 ton Goodman Heat Pump won't go into heat or ac mode. Fan won't turn on. No noise from compressor. System is 1 1/2 yeras old.
Easy: Turn the "fan" switch to on at the thermostat and see if the blower starts. If no start, check breaker at breaker box. Check service disconnect at or near the air handler. With the breaker and/or service disconnect OFF check the 3 or 5 amp fuse inside the top cover in the air handler.
Not so easy: (You must know what you are doing for this part or let an HVAC Tech do it for you) Open thermostat and firmly jump the Y and R terminals to see if you get the compressor to start for no more than 30 seconds. (don't do it more than once.) Jump the G and R terminals to see if you get the blower to start. If so, u have a bad thermostat. If not, check the transformer inside the same cover in air handler for proper voltage. (24V. Make sure you also get 220 on the opposite side of the transformer)
If the blower comes on, but the heat pump doesnt start, open the side cover of the heat pump, with the thermostat on cool, and the temp. setting as low as possible for at least 10 minutes see if the contactor is pulled in. If so, check the capacitor and see if it's blown out. Be super careful these systems operate with 220v and the amperes are enough to kill you if you make a simple mistake.
May 20, 2010 | Goodman CLQ36AR49 Air Conditioner
Amana Heat Pump Tripping Breaker
My guess I would say, you either have a wire that is short to ground or if the contacter pulls in, then I would say the compresser is short to ground.There also could be some capacitors that could be short.
Apr 07, 2009 | Amana PTH123B25AJ Heat Pump Air...
Jun 08, 2008 | Goodman CLQ36AR49 Air Conditioner
40 amp breaker at panel to air handler trips when you turn the heat on but not when the air is turned on
You could have one of two problems.
One , heaters could be shorted out causing the breaker to trip from and overdraw of current.
Two, your breaker could be weak and tripping prematurely.
May 12, 2008 | Heating & Cooling
Heat pump trips circuit breaker
I seem to have the same problem. But when I reset the breakers, they won't stay in the on position. They go back to the off position. What gives? It is 95F inside the house.
Jan 18, 2006 | Haier Energy Star ESA3183 Air Conditioner
Goodman CLQ36AR49 Air Conditioner Logo
119 people viewed this question
Top Goodman Heating & Cooling Experts
Dan Webster
Dan Webster
paulcarew
Brandon Berry
Brandon Berry
Are you a Goodman Heating and Cooling Expert? Answer questions, earn points and help others
