Setup panasonic viera
Its hard to set colour when the menu box is in the way and also what is the right colour i have a tc-l50b6 either the face to orange or colur to dark help step by step please is there a way of pushing the menu bar over thanks
    Genius:
  • 1,552 Answers
Yes, it should be possible to "move" the menu-box, by using the on-screen controls.
Posted on May 16, 2014
  • 109 Answers
SOURCE: distortion on people faces
What does a dvd look like played on it? If it's the same then there is something wrong with the TV. If a dvd looks good - no color problem - then it's the sat box that needs replaced.
Posted on Mar 25, 2009
  • 8457 Answers
SOURCE: Panasonic tx-32lx60a colour gone all red/dark
Ur Main Tuner signal board is dead.Replaced this board will fix this problems.Tries websites Shopjimmy.com,Ebay.com to buy a refurbish Tuner signal board for the replacement.
Posted on Mar 13, 2010
Lbogie68
  • 158 Answers
SOURCE: Panasonic TC-P42S1 42" 1080p: there are two wide
To remove the black bars from the left and right hand side, press the FORMAT button on the remote. The options available to remove the vertical bars are H-Fill, Just, and Zoom.
To remove the black bars from the top and bottom, press the FORMAT button on the remote. The option available to remove the horizontal bars is Zoom.
Hope this helps you!!
Posted on Mar 24, 2011
  • 7 Answers
SOURCE: My panasonic viera has a
Check the blue and green plugs on the component cable. Make sure the are pushed in all the way on the back of tv and device (cable box, dvd player, etc.)
Posted on Aug 06, 2011
  • 5265 Answers
SOURCE: I have a panasonic TC-P50ST30 and viera link will
Unfortunately, your charter HD DVR cable box is not a Viera link device that is compatible with the TC-P50ST30. Viera Link only works to control Panasonic HDAVI devices that are Viera Link ready (and that use the same Viera link coding) when using the HDMI cable. Thus some Viera link devices of different generations will not work with the same Viera link remote.
The manual for the TC-P50ST30 is available here: http://service.us.panasonic.com/OPERMANPDF/TCP42ST30.PDF . See page 32 for details on the Viera link controls.
I wish that I had better news for you. However, you will need to use separate remotes for your cable box and the TV.
Posted on Oct 22, 2011
Panasonic pt 52lcx66 flashes green turns on and then turns off after 2 min
Need to look at the menu on colur
It will indicate lining up of certain colours
Use the directional arrows to centre the colours
May 12, 2014 | Panasonic PT-52LCX66 Projection Television
My color is not right it`s dark i want to know the rights color my model is d1028l
Try the automatic-configuration on the monitor by using the software buttons on the bottom. You should be able to adjust the colours from there. There is no 'right' colour, but you can set it back to defaults on the menu.
Nov 04, 2012 | Dell Computers & Internet
Hp 2050 deskjet printer: colours are confused and orange is printing green.
Try checking you color settings on printer and computer. Also, check your ink cartridge and it's date of manufacture. Sometimes old cartridges behave like that.
Nov 02, 2012 | HP Deskjet 2050 All-in-One Printer
What is the proper calibration settings for a panasonic tc-p50s2n. I have used it for over a 100 hours
Do you have access to a test pattern or color bar ? .If you have a THX certified DVD ( some Walt Disney movies ) it will have calibration setup guide in the DVD menu.Or else you have to buy a calibration DVD if you are serious about your TV setup.
First you have to set the contrast and brightness using the Grey-scale pattern. Seven set of vertical bars slowly progressing from white to black. If set right you should be able to make out all the seven bars with out each merging ( or overlapping ) into the other. You will be able to see the line of demarcation between each vertical bars. Then set the color to taste.
If you do not want to purchase the above mentioned DVD disc a close setup figure for your Panasonic TV would be
Picture Mode = Standard ( Normal )
Picture ( Contrast ) ---- 50
Brightness ---------------- 50
Color ------------------------ 33
Sharpness ---------------- 50
Hue ------------------------- In the middle
This setting should give you a decent picture quality assuming your TV is new.
Apr 12, 2011 | Panasonic Televison & Video
Blue lines at the bottom of a coloured pictue I copied
try cleaning the print-heads from printers menu
you probably have a goggled print-head
Apr 27, 2010 | Lexmark X5150 All-In-One InkJet Printer
My contact on yahoo messenger is using a logitech web cam and today her image was not colured instead it was a bluey grey
She can launch the logitech webcam toolbar from her desktop or from 'All Programs' and adjust the colours etc using the 'Settings' menu ( the 2 gear wheels on the pictorial toolbar )
Nov 15, 2009 | Logitech Webcam
Dell m992 19"
Just press the menu button and you can adjust the colors there.
Mar 30, 2009 | LG Flatron F700P 17" CRT Monitor
Dark picture and shadows
Sounds like you've entered the "service mode" where you're seeing the chroma (color) signal only. What type of connectors are the F and S? RCA? F? This set is no longer made which makes it hard to research. By any chance, is there a small switch on the back that says "normal - service"?
Nov 06, 2006 | GE 25GT516 TV
Televison & Video Logo
22 people viewed this question
Top Televison & Video Experts
