Question about HP LaserJet 1200 Printer
Why does my printer sound like a jet engine still?
I have changed the toner, an original Hp toner and the noise still sounds like a jet engine. I the printer has to be turned off to stop it. The fuser has also been cleaned, there was no debris on it. Right now I have the the top and both sides opened up, what can I try next?
  • 778 Answers
Hello, It sounds like you need to get a maintenance kit and replace the parts in the kit, or the fuser is bad and needs too be replaced.
Posted on May 17, 2014
52.0 scanner error
Try the toner cartridge first, it could be not opening properly, after that it will be the laser scanner assembly.
Mar 02, 2015 | HP P2035N LaserJet Monochrome Printer
How we can solved the hp lj p2055dn printer noise
Hopefully one of the first four suggestions helped you. If not if you could post more detail as to what kind of noise is the machine making: a grinding noise, a squealing noise, how loud is it. descriptions such as that would be helpful in diagnosing the issue. Without a description of the noise any of those first four posts could be relevant. The easiest thing to try first would of course be a toner cartridge I have experienced them many times making noises especially if they're aftermarket cartridges. Other than that grinding noises are typically fuser related in that machine, with squealing and high pitch noises the description of the noise is very important because it could be a fuse or it could just be dirt in a gear cluster rubbing on a shaft or it could be the laser assembly. Ireally hate to post absolute diagnosis without enough detail especially when it comes to you having to spend more money. Hope this helps.
Sep 24, 2014 | HP P2035N LaserJet Monochrome Printer
Smearing on HP laser jet 2055dn
That sounds like a drum issue. Try replacing the toner or have you done that already? Give me a call if you ever need to replace the toner. I can beat out Staples and Office Depot. Damien @ iPrint Technologies - 818.700.7419 Dir.
Aug 28, 2014 | Office Equipment & Supplies
Hp laserjet 5200 grinding noise from left side
front, rear ? I'd say fuser assembly gears or drum on toner cartridge; check the gear teeth on the toner cartridge's drum.
Dec 20, 2012 | HP LaserJet 5200 Printer
My hp 2840 all in one laser jet printer squeaks when it is printing. How do I lubricate my 2840 HP laser jet printer?
Corosol technology is older,slower sounds also too high, it is not suggestible to lubricate the moving parts because of cartrides will move while printing result lot of toner particles raises in printer chamber,if this particles deposited on lubricated area will abstract the moving spares. If you can do the periodical maintenance, use silicon grease for moving parts..
Sep 28, 2011 | HP LaserJet 2840 All-In-One Printer
My HP m3035 printer is making noise in the toner cartridge compartment on the right grinding sounds. I changed the Toner, still amking the noise any ideas?
Open the rear door. Power on the printer. Watch and listen as the fuser rotates. Does the noise occur when the fuser rotates? if yes - replace it. If you still think it's coming from the toner, remove the toner, close the toner door. When the motors start turning the noise should be gone. Insert the toner and listen again
Jan 28, 2010 | HP LaserJet M3035 MFP Printer
Printer HP laserjet 3030
It sounds like a faulty toner cartridge.Try changing the cartridges and see if this solves the problem
Dec 29, 2008 | HP LaserJet 3030 All-In-One Printer
Toner marks down right side of page
hmmm...sounds like your toner cartridge is truly unhappy. I'd return it if I were you.
no worries..start by getting new driver for that here
Feb 28, 2008 | HP LaserJet 1320 Printer
HP LaserJet 1200 Printer Logo
Seeker5211
Seeker5211
