Question about Samsung HPT5054 50 in. HD-Ready Plasma Television
No Video on Samsung HPT5054
Bought used last week, used no problem for 20 hrs. Then no vid. Sometimes when turning on I see a very brief flash, sometimes just black. Hooked up a DVD player - audio but no vid. As I've not used a DVD player before, I assume the vid part was active while the audio ran. Hard to see what's going on when there's no vid. Also started the TV not attached to anything. No display menu. Nothing. Anyone know the next step? I could remove the back panel... but I'm really not a technician.
    Top Expert:
  • Samsung Master
  • 44,133 Answers
Could be power supply failure
Posted on May 16, 2014
SOURCE: Samsung HP-R5052 50 bottom hallf screen turns black
its the lower buffer card.. (y buffer lower board) they cost about $90.. i changed mine myself on my samsung hpr-4262 42 inch plasma.. pretty easy,, took approz 20 minutes.. the card has 3 ribbon cables and 3 other connectors and 1 screw.. removing all the screws out of the back pannel took the most time.. i found the repair manual for my tv on line for $13 (download PDF file) the manual had a trouble shooting section and what board to replace for each problem.. got the manual from here http://store.payloadz.com/ ordered the replacement board from www.partstore.com
good luck
troy
Posted on Sep 24, 2008
  • 362 Answers
SOURCE: remot not working for Sens TV/DVD 19''
Hi sifrid,
Program the RCA remote with the instructions below, this will tell us if the problem is with the remote or the tv.
  1. Turn tv on.
  2. Press and hold tv button on remote
  3. While holding tv button press and hold power(on/off) button, led light shold go off then back on after a coupke of seconds.
  4. Release both buttons.
  5. Aim remote at tv and press the power(on/off) button every 5 seconds until tv turns off.
  6. When tv turns off press the stop button at bottom of remote, that will lock in the code.
  7. Turn tv back on with remote and test all buttons.
Let me know if this helps and please rate this solution.
Lone99star
Posted on Jan 27, 2009
circuitworld
  • 335 Answers
SOURCE: sound but no video HPT5054 Samsung
One of your transformers on the inverter board are failing to sustain regulated power to the florescent lamps resulting in a dark picture. Also check the SMD fuses on the inverter board(s) see if they have blown. You will need a continuity meter to check them. You can get one from radio shack and be sure to get one with audible sound....you don't have to replace boards when you can fix them.
Posted on Jul 10, 2009
SOURCE: Fault with Samsung PS42S5H
sounds like the lower y-sus buffer! take off the back and give me the pcb number should start with Lj92
Posted on Aug 30, 2009
SOURCE: Samsung LN-R408D - No Picture
My Mom's LNR408D also had sound but no picture. I was able to fix it by soldering in a jumper wire across a blown (1.5A ???) SMD picofuse on the "T-Con" board.
Consider attempting this ONLY if you: 0) Know enough to avoid the potentially fatal High Voltage parts of the power supply board!!!
1) Are a fearless hackazoid 2) know what you're doing with a soldering iron and teensie SMD parts 3) are gonna throw the busted thing out anyway so you have nothing to lose and won't be sad if you screw something up.
4) Know enough to avoid the potentially FATAL High Voltage parts of the power supply board!!!!!
This board is at the top center under a close fitting RF shield. The suspect part was labeled "CP" on the board and marked with "P" on the part. It is visible above the right-center of the connector from the main board. An ohmmeter showed it as open, so I bypassed it with a jumper wire from connector VIN to the hot side of C13. One image shows the suspect part and the jumper in place.
The other shows the TCON board placement top-center (under its RF shield). With care, it seems possible to test the fuse and put the jumper in place without removing the shield. (Obviously don't touch anything else with the VOM leads!)
Thanks to ZORBUS and Steve's TV and Electronics for the idea.
http://www.avforums.com/forums/lcd-televisions/892447-no-picture-but-got-sound-my-samsung-lcd.html
http://www.gesda.com/transformer/Fall08_files/Page336.htm
Steve C
Posted on Sep 22, 2009
I was working 25 hrs but had 30 on wage slips so I asked to put my hrs to 25 to rectify this then I only got 20 hrs but 25 on wage slips now I'm down to 10/18 hrs but 20 on slips I've had tax credits...
join a union or get legal advice as you should get paid the hours that you work--nothing more --nothing less and you boss is required records to reflect that fact
Jul 30, 2017 | The Computers & Internet
Samsung ps51d550c1k will not turn on
If the red light flashes for a while, with a clicking noise while trying to turn on. It's either the ysus or xsus board, they are both easy to replace, my xsus board has blown twice, last board I bought off ebay £35 lasted 2 years. Just bought another for £16 + free postage.
If you can use a screwdriver & disconnect/connect a few ribbon cables & connectors, you'll save yourself £££s
google or search youtube for video guides, you won't be disappointed ;)
telltale signs are when the tv starts to make a clicking off/on sound while watching tv, without actually turning off, That's the time to look for a spare ysus or xsus board, before it blows. It could last months or weeks but better to be safe.
Takes me 15mins to take the back off, replace the board & put the back back on. & I'm a novice.
Mar 27, 2014 | Televison & Video
Samsung HPT5054 no video only audio
On the board next to the y-sus - that is the board that the y-sus plugs into there is a blown cap- mostly the 680uf 25v 105c cap is the one that goes on that board - to identify the board number is LJ-921490A.
Sep 12, 2011 | Samsung HPT5054 50 in. HD-Ready Plasma...
I bought a used samsung galaxy tab last week from bangkok and the lady told me its only 1 month used and therefore has 11 months of warranty left. Now after coming back to India i've realized that there is...
You may want to visit Samsung's website to check the warranty coverage of the tablet. Usually, since they are slightly used, it should still be covered by warranty.
Mar 06, 2011 | Samsung Galaxy S GTI9000 Smartphone
I bought Samsung c6112 sliding dual sim mobile. I have transfer mp4 video file to memory card. But its not playing but showing as "not support content" .Please confirm whether iC6112 plays mp4...
samsung gt-c6112 sports to mp4 vids. check ur vids detail properly if problem not solvs then convert video in 3gp video using 3gp video converter.
regards,
shiv c. shekhar
Jan 16, 2011 | Samsung C6112 Cell Phone
Vizio 50" plasma, 3yrs old out of warranty, has a
If you wish to get some details; visit the site linked here. Pull up older posts. http://electronicshelponline.blogspot.com/
Mar 05, 2017 | Vizio P50HDTV10A 50 in. Plasma HDTV
Can't turn on TV
Since when does 2 years equate from purchase date of 2008 and the date at present 2017.
Probably a power supply issue caused by leaky capacitors.
Apr 04, 2017 | Samsung HPT5054 50 in. HD-Ready Plasma...
Sound but no video HPT5054 Samsung
Jul 10, 2009 | Samsung HPT5054 50 in. HD-Ready Plasma...
Samsung S5687 w/hl shuts off after 20 seconds
Those blinks [flashes] are fault indication (Error Codes). From the number of blinks occur at one time switch ON, you can get an idea about the faulty circuit section inside it. This will make repair easy. These are called blinking codes. Make sure about the exact number of blinking of the standby/power LED, by switching On & OFF the set, for at least two times. Count it carefully. If you wish to get some details, check the site linked here. It has details about blinking codes, and fault locating procedure, to many popular brand TVs and other devices.
http://electro-medical.blogspot.com/
http://homenol.blogspot.com/
If blinks continue without any pause, the main board is faulty.
Search the site by type in the "brand name" to your device, in the "Search box at the top right of the display window of the Homepage" to get gathered related posts.
Apr 29, 2017 | Samsung DLP HL-P5663W 56" TV
Samsung HPT5054 50 in. HD-Ready Plasma Television Logo
71 people viewed this question
Jerry Greenberg
Jerry Greenberg
