Question about Sharp Aquos Televison & Video
Lc 46x8e I can not sort dvb-t channels in channels list. I can not to get into Channel Set...Can you help me pls?
My options in Menu-Settings are blocked...I think.First available option in Menu-Settings is Children Lock. First two options(Automatic Tune and Channels Set) are not available-are grey.
  • Sharp Master
  • 1,527 Answers
Hi try 0000 hope it works if it don't come back to me thanks
regards
shaun
Posted on May 18, 2014
SOURCE: tuning option on menu is greyed out. cannot retune channels
If the channel icon is greyed out and you cannot tune the channels press the TV/DTV button on the remote control unit the icon is not greyed out and tuning is possible.
Posted on Oct 01, 2009
  • 6 Answers
SOURCE: Samsung LE32R74BDX 32 in......
just spoke to Samsung support and it turns out that the freeview tuner had froze and needed resetting. To do this put TV on standby and then push in series these buttons on the remote: 'info, menu, mute, power' the TV will then turn itself on and display a menu. Press the 'down arrow' untill you've highlighted option 12 - 'reset' and then press the 'right arrow' to enter the option. TV will turn off and when you turn back on it will start in 'plug & play' mode as if new. Set the time and country options and then it will perform a complete scan. I've just retuned mine and all back to normal. Hoorah!!!! :-)
Posted on Oct 05, 2009
  • 6 Answers
SOURCE: no digital yet tried to retune but greyed out.
Just got through to Samsung support. Turns out the freeview card had frozen and needed a reset. To do this put tv on standby. then press in serries these buttons on the remote: 'info' 'menu' 'mute' 'power' TV will then turn on with a default screen. Press 'arrow down' button untill you reach option 12 'reset' . then push the 'right arrow' and tv will reset and start in plug and play mode and commence a scan when you've set the time. Just retuned mine and its back to normal. Hoorah!!! :-)
SOURCE: Auto Tuning Channels on LC20B2MA Aquos TV
 Automatically tunes in and preset
receivable TV stations.
Make sure the antenna cable is
properly connected.
1 Press MENU (PRESET-1) on the
upper part of the LCD TV set for
more than two seconds. The
AUTO mode screen appears.
2 Press VOL (–)/(+) (PRESET-2)
on the upper part of the LCD TV
set.
All the TV stations in your area
that can be received by the LCD
TV set are automatically preset.
3 The screen shows whatever is on
channel 1 when full auto channel
preset is finished.
Posted on Oct 09, 2009
SOURCE: I need to do a
During power up and first time use, there should have been an option for channel scanning as the initial setup wizard began.
Alternatively, there should be a way to navigate to the channel scanning menu by selecting, Menu>TV>Auto Channel Search. I couldn't get the exact info from the model you listed, but I gathered this info from a similar owner's manual (lc-32sb28ut) from the Sharp webpage: http://www.sharpusa.com/CustomerSupport/ProductDownloads.aspx
Hope this helps.
Posted on Oct 18, 2010
Sharp LC-32SH130K always goes back to same Channel
go to the menu option and restart your TV settings to the factory settings. If you event can not use the menu and same thing happens, there is something wrong with the remote; maybe a button is being pressed all the time or there is some conductive material stick to the electric board.
Feb 04, 2014 | Sharp LC-32SB21U 32 in. LCD TV
I have a Panasonic DVD recorder with hard drive (DMR-EX769). EVERY time I switch it on the following message pops up on screen : "A new DVB channel has been found. Start DVB Auto-Setup? Selective...
I believe there is an option to stop that. It's just finding out on what menu it is on. Some Panasonic machines have it on the FUNCTION MENU then press SETUP then press DIGITAL TV TUNING. It's often listed as NEW CHANNEL MESSAGE.
Selecting that will switch it off or at least the options for it.
It's probably caused by weak stations that get detected then drop out again.
Jun 16, 2017 | Panasonic Televison & Video
How do I change the resolution on my Sharp Aquos LC-69E88UN from 480i to 1080p. My satellite box is HD and the tv says its on 480i. Any help would certainly be appreciated
Do you mean the LC-60E88UN? The LC-69E88UN isn't listed at Sharp's USA web site.
Try a different channel; different programs will have different resolutions provided (particularly the local stations). How are you connecting the TV to the satellite box? If you are not using component or HDMI, then get the appropriate cable for whichever of those is compatible with your satellite box. Then change switch the output of the satellite box and switch the input if needed for the TV.
With DirectTV, there is a setup menu option to change the output resolution to the native resolution of the TV. So check that. Menu > Fav's and Setup (press Select) go to HDTV > Video tab. Set Native option to On. The only issue will be that channel changes will be slow as the receiver checks the native resolution. Dish Network probably has a similar feature but it may be in a different menu area. Check your documentation. Both companies have manuals online when you look up the equipment.
I hope this helps.
Jan 22, 2011 | Sharp LC-32D64U LCD TV
I need to do a channel scan on my tv to get the service working but i cannot find channel scan options on the menu. Where is the channel scan option on the sharp LC-32SB24?
Hope this helps.
Oct 17, 2010 | Sharp LC-32SB24U 32 in. LCD TV
I live in Pretoria South Africa using Windows 7 I have installed the drivers for DVB S 100 however I cannot find signal scanning with Media center and my Theater please help
Follow this steps and try
in windows 7
On the start screen, scroll to Tasks, click settings, click TV, and then click Set Up TV Signal.
Follow the steps to connect a TV signal, depending on the type of tuner or tuners that the cable is connected to
else try
The Windows Media Center TV Pack has an "Auto Select" option which removes channels that have a weak signal from the EPG. To run the "Auto Select" option to check the list of available channels and to evaluate the signal strength for each channel, follow these steps:
  1. Start Windows Media Center.
  2. In the Start window, scroll to Tasks, click Settings, and then click TV.
  3. Click Guide.
  4. Click Edit Channels.
  5. Click Auto Select.
The "Auto Select" option tests each channel. Based on whether a strong or a weak signal is found, the "Auto Select" option puts a check mark in the box next to the channel. As soon as the detection process is complete, you have to click the "Save" option to save the newly selected channels to the EPG.
esle if the problem still persists
have a look aon the microsofts support in the following link
http://support.microsoft.com/kb/955485/en-us
Feb 19, 2010 | KWorld DVB-S 100 (DVBS100) Video Capture
Infrared Remote codes
try to go threw all codes when you turn on and off the tv after each code and try to change channel after each code then the one that changes the code is the correct code!!! this might help.
Mar 25, 2009 | One For All URC-3021 Remote Control
I have to keep resetting the channels or unchecking the skip option on my Element FLX32FHDH tv. Is there a way where I can set this and not have to keep resetting it?
My Element FLX32FHDH seems to lose it's channel list if it is off for 6-8 hours. The channel up and down buttons don't work, and I can't key in a channel. In my case, if I hit "enter" before any other key on the remote, after turning on the set, the channel list menu will appear, with all the missing scanned channels showing. Pick any one, and the set jumps to that channel, and all functions are restored. The stored channels were not lost, but some sort of access flag or variable has been corrupted and the chip won't access the database. Not a fix, but potentially a work-around for you.
Mar 04, 2009 | Televison & Video
properly connected.
set.
preset is finished.
Aug 07, 2008 | Sharp Aquos LC-20B2U 20 in. LCD Television
Why do I always have the message:" A new DVB service has been found" when I switch my television on, and yet there are no new updates?
its not your TV its your free view box telling you its found more channels. DVB means 'digital video broadcast.' go into menu and select search or update channel list
Jul 22, 2008 | Panasonic Televison & Video
Televison & Video Logo
46 people viewed this question
Top Sharp Televison & Video Experts
Jaime Hernandez
Are you a Sharp Televison and Video Expert? Answer questions, earn points and help others
