Question about Provo Craft Cricut Expression 2 Machine
What is wrong with mt Cricut Expession 2 machine? I go through the process of selecting and sizing the images, and loading the paper. But when I hit cut, a timer icon comes on for about a minute, and then the screen clears, anf my paper is kicked out. It's a brand new machine...is it defective?
    New Friend:
    Problem Solver:
  • 5 Answers
  • Turn on the machine, with no cartridge installed. Roll the Speed, Size and Pressure dials all the way down to the lowest possible setting on each.
  • Grab the blade assembly with two fingers and pull the carriage gently all the way to the left. Behind where the carriage usually sits is a red button. Press and hold the button for three to five seconds and release.
  • Go back to the three dials marked Speed, Size and Pressure, and roll each one all the way up and down three or four times.
  • Press the Cut button, then turn off the machine. Let the machine sit for 15 to 20 minutes to clear the memory.
  • Load a cartridge, turn the machine back on and try it out. If you are still experiencing problems, you may have a defective machine. Return it to the manufacturer with the original receipt.
Posted on Jan 28, 2017
    Top Expert:
  • Provo Craft Master
  • 41,839 Answers
If it is brandf new, return it to the point of purchase as defective.
Posted on May 16, 2014
When using a design in Cricut Craft Room, and select cut, my Expression 2 begins, but does not complete, the cut. The arm moves to the paper and then makes a croaking sound and then nothing.
Search cricut.com for support faq go to expression 2 search format and reset. Watch the video on format and reset and do as it says. Calibrate when it's finished. If this doesn't work re download ccr after deleting it from your computer.
Jan 10, 2016 | Provo Craft Cricut Expression 2 Electronic...
I have the original Cricut and have never had a problem. Now it won't cut. Nothing happens when I hit the Cut button. Is there a way to fix it?
Hi you could try's phoning cricut. It's free to the states. The number is on the website. You may have to wait on hold for a while but they will answer and you will definitely get an answer.
Feb 28, 2015 | Provo Craft Cricut Expression Personal...
How do I use the Artbooking cartridge on the cricut design studio?
Cricut design studio is no longer supported by Cricut but if you mean Cricut Design Space then this is how you do it. Open and sign in to Design Space select insert images and in the box on the right select my Image sets and then type in Artbooking. Artbooking cartridge will then come up for you to select what you want. all images come onto the mat at 2.5 inches they havent fixed this yet so you have to resize your images. If you want to download the image numbers from the artbooking book which go with design space go to http://thenon-craftycrafter.blogspot.co.nz/p/image-codes.html and download the artbooking book from this lady please join her blog and leave her a message as she does a lot of work all of which she does for free. Also if you youtube cricut design space. or go onto design space in cricut.com
Aug 20, 2014 | Cricut Expression Cutting Machine
Why does my paper move out of place when the cricut expression is cutting? Is somethhing wrong with the roller bar?
I would just use a new cutting mat if the mat your using isn't sticky enough your paper will move.
Mar 25, 2012 | Cricut Expression Cutting Machine
The cricut does not cut through the paper, it only scores it enough to see the outline of the image to be cut. I have checked on line and the blade housing is installed correctly. Does the cutter have a...
Yes, there are three rollers that one adjusts your size of the image you are cutting that is on the right hand side of the machine. The other two are on the left side of the machine. The top one is your speed control and the bottom is your pressure. I would move it up to medium when cutting with cardstock or even up to high if it is thick cardstock. Hope this helps, any further questions feel free to ask me.
Dec 30, 2009 | Provo Craft Cricut Disney Font Cartridge
Auto head alignment
#1 of 2
Carryout a Manual Print Head Alignment If Possible.
If the results of Automatic Print Head Alignment are not satisfactory, follow the procedure below to perform Manual Print
Head Alignment.
1 Make sure that the machine is turned on, and then load three sheets of A4 or Letter-sized plain paper in the Auto Sheet Feeder or the Cassette.
Important. You cannot print the print head alignment pattern if paper of size other than A4 or Letter is loaded. Be sure to use A4 or Letter-sized plain paper.
2 Open the Paper Output Tray, and then open the Output Tray Extension.
(1) Put your finger in the rounded indent of the Paper Output Tray and open it gently.
(2) Open the Output Tray Extension.
3 Press the Paper Feed Switch to select the paper source where you have loaded paper.
4 Select Settings on the HOME screen.
5 Select Maintenance, then press the OK button.
The Maintenance screen is displayed.
6 Select Manual head align, then press the OK button.
The confirmation screen is displayed.
Note. If you select Head alignment print, the machine exits the process after printing the current head position adjustment values.
7 Select Yes, then press the OK button.
8 When the Print Head alignment pattern is printed, select Yes, then press the OK button.
9 Look at the printout. From the patterns, select the most even, least irregular patterns for each column and input their numbers. Press the OK button.
(1) Select a column to input the pattern number.
(2) Use the or button to input the number of the pattern.
(3) Repeat the steps (1) and (2) until you finish inputting all pattern numbers, press the OK button.
Oct 08, 2009 | Canon PIXMA MP600 all-In-One InkJet...
The text of a document will not print. The
Print From Your Computer : Windows Printing Select Basic Options Click the Main tab on the top of the printer settings window to select your basic print options. 1. Select a Quality Option that matches your document or photo, and the print quality you want. Quality Option settings WebWorks_WriteArrow(WebWorksRootPath, "wwdd1032347", false); WebWorks_WriteDIVOpen("wwdd1032347", false); • Draft: for rough drafts with reduced quality • Text: for documents containing only text • Text & Image: for documents with text and images • Photo: for photos and graphics with good quality and print speed • Best Photo: for photos or graphics with high print quality WebWorks_WriteDIVClose(); 2. Select the paper Type setting that matches the paper you loaded. 3. Select the paper Size setting for the paper you loaded. Paper size settings WebWorks_WriteArrow(WebWorksRootPath, "wwdd1032380", false); WebWorks_WriteDIVOpen("wwdd1032380", false); You can load paper in these sizes and select the size in the printer software. (Wider papers are for use only when reducing large images with the Reduce/Enlarge Document option.) A User Defined option is also available so you can create a custom size. A4 (8.3 × 11.7 inches) A6 (4.1 × 5.8 inches) Letter (8.5 × 11 inches) Legal (8.5 × 14 inches) Half Letter (5.5 × 8.5 inches) 3.5 × 5 inches 4 × 6 inches 5 × 7 inches 8 × 10 inches 16:9 wide (4 × 7.11 inches) Envelope #10 (4 1/8 × 9 1/2 inches) WebWorks_WriteDIVClose(); 4. If you’re printing borderless photos, click the Borderless checkbox. For documents or photos with borders, select Borders. Note:
For borderless photos, make sure you loaded a compatible borderless paper size and type. 5. Choose Portrait or Landscape orientation for your document or photo. You can also:Select Print Options Select Basic Options Click the Main tab on the top of the printer settings window to select your basic print options. Select graphics & text. USER'S MANUAL EPSON WEBSITE: http://files.support.epson.com/htmldocs/cx44__/cx44__ug/wwhelp/wwhimpl/js/html/wwhelp.htm
Jul 22, 2009 | Epson Stylus CX4400 All-In-One InkJet...
I dont get prints when I give print command but when I use the
What does it say in the display?..load paper plain letter....load MP feeder? I think the problem is the following. On the menu right arrow over to the paper menu. Hit select...it then gives you sub menus...paper type...paper size. Go to paper size...specify the tray your using...most likely tray one. Hit select and see what size paper its set on. I'm assuming your trying to print on letter size. If it says something else like legal...executive..A4...change it in the menu to letter. If it changes to letter hit select to save the setting. Now if it won't change in the menu pull open the paper tray. The back paper guide is real sensitive on these machines. You have to make sure the geen/blue tab on the back is set exactly into the letter size slot on the tray. That slot will be slightly bigger than the rest of the teeth you see on the bottom of the tray. If you have it set right then there should only be the 2 bottom tabs extending on the outside left side of the tray. Those tell the printer what size paper is in the tray. If theres 3 sticking out...you still don't have it set right for letter size. Okay..the last thing. Something that goes bad on those machines is the tray card. Its where those 2 tabs on the side of the machine I mentioned interface with the printer. They can go bad. You can either replace that card..or trick it. To trick it go back to the paper menu...paper size tray 1. Open the tray...and close it again. The setting on the screen will change to another size...do that again or until it changes to letter size. The leave it alone. You may have to do that everytime you add paper an reinsert the draw unless you replace that card. Hope this helps!
Mar 24, 2009 | Lexmark Optra S 1855 Laser Printer
Dials not working
You may want to try resetting your Cricut to see if that fixes the problem. To reset the Cricut machine, turn the unit off for five minutes. Roll all the dials all the way up and all the way down five times each. Turn the Cricut back on. This is the manufacturer's reset process. Good luck!
Mar 13, 2009 | Provo Craft Cricut Disney Font Cartridge
Cannot print from Tray 1 in Gestetner 6002
First make sure that the machine is reading/ seeing the paper size of the paper that is in the tray ( select tray 1 from the touch screen and see what the paper size reads). If the machine sees a different size then that in the tray, use the 'user tools' and change the paper for that tray. Also, go into your printer settings on/in your computer and make sure that the proper paper size is selected ( the size that is in the tray you want to print from). If the orientation of the paper size is different from the tray -- will not print and give you the error.
May 06, 2008 | Gestetner - 6002 Digital Imaging System...
Provo Craft Cricut Expression 2 Machine Logo
236 people viewed this question
Top Provo Craft Office Equipment & Supplies Experts
Tom Chichester
Warren Roth
Warren Roth
Level 1 Expert
Flo Hill-Rennie
Flo Hill-Rennie
Level 1 Expert
Are you a Provo Craft Office Equipment and Supply Expert? Answer questions, earn points and help others
