Question about Goodman CKL60AR60 Air Conditioner
Good man out side unit fan motor not comming on
  • 24 Answers
Could be bad run capacitor or just bad motor.
Posted on Jun 24, 2009
I have good man heat and cool unit . When I put a/c on unit work 2 - 3 hour and burn fuse what is the problem
You have a short in the control circuit somewhere. Or a component on the secondary voltage side is intermittently shorting.
Or is the fuse that is burning on the line voltage? Then it could be dirty outdoor coil. Compressor going out. Run capacitor weak, or outside fan motor going out
May 28, 2015 | Heating & Cooling
Electrolux Icon side-by-side E23CS75DSS - repair man replaced the defrost thermostat and now the digital temp display flashes. The freezer temp display flashes "E" and the fridge display flashes...
Sounds like you have a evaporator fan motor. That is what the error code you have indicates, the fan blade could be stalled to.
I work on these units every day and know them very well, I can walk you through any repair on this refrigerator.
http://www.appliancerepairlesson.com/
Mar 01, 2011 | Electrolux 25.9 Cu. Ft. Side-by-Side...
#GLHS35E4SB6 Frigidaire side by side. evaporator motor area becomes extremely noisy and eventually shuts off. The fan could be floating on the motor shaft and engaging the shroud. Apparently the...
be sure maybe the sound coming from evaporator fan some times it accumulate ice near it do not open for long time both doors or put hot things inside the fridge or freezer .
Sep 11, 2010 | Frigidaire Gallery Series GLHS269ZDB 36"...
Electric fan
the purpose of an elec. fan vs man belt driven is a man. belt driven fan robs the motor of power. electric does not. and yes it does turn on and off via a signal from the temp sending unit, located close to your thermostat housing, either on the intake manifold itself or the side of eng. block or head, it will have only 1 or 2 wires to it.
Apr 06, 2010 | 1994 Toyota 4Runner
My GE 48 inch built in fridge began making a strange noise.
fan motor problem ge has the solucion replacement fan motor around $350 plus mine still makes the noise
Jun 19, 2009 | GE Monogram ZISS480DRSS Stainless Steel
Outside unit come on for ac but inside won't come on for ac or heat
Turn Tsat to fan to see if inside unit will come on. If it does Tstat needs replaced. If not it is fan motor or fan relay. Possible cap. Do you here the fan relay come in. If it is a Good man unit it is time delay and you wont here it. Need to know your make of unit. Rusty
Apr 25, 2009 | Heating & Cooling
Ge 36" MONOGRAM with bottom freezer, very hot on back inside wall
Make sure that the condenser coil is not dirty. If so clean it. Have you actually seen the fan in the back of the unit running? It has 2 fan motors. One on the inside of the freezer and one on the back of the unit. The one on the back not working will cause it to get very hot and so will dirty coils.
Apr 10, 2009 | GE (PSS26MSRSS) Side by Side Refrigerator
Ice build up out side hitting fan
pop out drain plug heat up pan with heat gun to melt ice
Nov 24, 2008 | GE Zoneline AZ38H12DAD Split System Air...
A/c unit is very hot and the fan stop working
start with the fan motor capacitor, check it . usually 5, 7.5 or 10 microfareds.check it with a meter on the uf scale, or label wires pull it and take to electric motor shop and they can check it. if cap is good then trace wires from motor to sources of power and see if you have 230 volts to motor . if you do then motors shot. label all wires and note exactly where the fan blade is located in relation to the grill guard. sand motor shaft smooth. oil loosen bolts on blade hub and gently remove. take old motor to motor shop and buy exact replacement motor. or have motor shop man show you where to place wires. usually black and white to power, brown and brown with white stripe to the capacitor. some motors wired up with three wires. see side of motor or directions in box or ask motor man to explain. resecure new motor exactly as removed , reinstall hub and blade. if you think blade is to rusted to get off or you mess it up just take it to the motor shop. he sells blades to! just be sure you have good clearance when you get done, cap off or tape off any unused leads. i usually use little bits if stat wire to secure wires up and out of the way of the fan blade if needed. they last longer than plasties and are not effected by the sun etc. check rotation of blade. cupped or curved side into the wind . check amps on new motor. should pull less than rated . a 2.9 may pull 2.1 etc. a new motor always deserves and usually uses a different size capacitor than an old one. they are cheap anyway and not worth skipping and having a redo. good luck........
Nov 12, 2008 | Carrier Heating & Cooling
I REPLACED ICE MAKER UNIT BECAUSE REPAIR MAN TOLD ME THAT THE HUMMINING NOISE WAS DUE TO ICE MAKER BEING STUCK IN A CYCLE. AFTER REPLACEMENT THE NOISE IS STILL THERE. WHEN I SHUT THE ICE MAKER OFF NOISE...
theres ice in the fan propelar, if you see no ice blocking the propellers its the fan motor itself,if you unplug the fridge and stick something thin between the vents where you feel the air blowing thru and try turning the fan,gently and it spins smooth its the fan motor,if you dont wish to do this turn freezer off,open the door and let it defrost,then plug it in if buzz still there its the fan motor
Jul 08, 2008 | Hotpoint Refrigerators
Goodman CKL60AR60 Air Conditioner Logo
106 people viewed this question
Top Goodman Heating & Cooling Experts
Paul Carew
Tim Whalen
christian nielsen
Are you a Goodman Heating and Cooling Expert? Answer questions, earn points and help others
