Question about Refrigerators
Kenmore 106 56703500 Freeze is cold refrigerator is not
Unit is only a 5 years old and has an on and off problem with the temp of the fridge side rising - 60 degrees while the freezer side is at 1-2 degrees. If I unplug the unit for a day or so it will work fine for 6 months and them does it again. Puzzling.
    Top Expert:
  • Refrigerators Master
  • 45,144 Answers
The problem could be an intermittently defective temperature control.
Posted on May 16, 2014
5 Suggested Answers
VANMAN69
  • 23 Answers
SOURCE: freezer works ok.refrigerator temp varies from 39 deg.to 60 deg.
check to see if there is frost in the back of the freezer if so you have a defrost prob..
Posted on Jun 29, 2007
WALNUTS420
  • 3 Answers
SOURCE: Fridge not staying cold, periodically
CHECK FAN OPERATION   MOST OF THE TIME IT IS THE THERMOSTAT
Posted on Aug 12, 2009
Testimonial: "Seems this comfirms what I am hearing. sounds like I should change the thermostate and go from there. Thank you. "
dmftrucker
  • 1922 Answers
SOURCE: My Ge monogram side by side refrigerator is about
could be the defrost sensor or timer circuit that is malfunctioning or a combination of both parts
Posted on Oct 28, 2009
Testimonial: "Thanks for the feedback. I agree with you!"
imufo2
  • 3773 Answers
SOURCE: Our Whirlpool Bottom Freezer Refrigerator
I'm Leo
This is a common defrost problem, The ice
is not being melted by the defrost system. he fan can't blow into ref.
Take out back panel of freezer to check for ice buildup. The coils should be clean.
There are three components to a defrost system- a heater,heater thermostat, and a timer unless you have a defrost electronic card.
Its best handled by a Technician but you could possibly do it by taking your model number to the nearest appliance parts store and asking for the parts. They are mostly located in freezer ,behind back panel on freezer coils.except the card which is usually located in ref The parts store will have info
Also check evaporator fan in freezer
Also check fan undernearh Ref in the rear
Clean condenser coils underneath
If this was helpful please rate me
Thanks for using fixya
Leo Ponder
imufo2
Thank you for using fixya
Leo Ponder
Please VOTE FOR ME IF THIS WAS HELPFUL.
I'm including my article on Refrigerator Repair for your help and convenience.;
Please click for article
http://www.fixya.com/support/r5816737-fix_refrigerator_psychologically
Posted on Jul 26, 2011
Issue with Kenmore Refrigerator/Freezer
ok,1st check on fridge side toward upper back of the top and feel for air coming thru, and there is another one down possibly behind crisper .I had this same deal. Had to do total defrost,, put food in cooler,, theres two blower fans in these types of fridges,,one in the bottom back,, and one in the back of the frezzer,, I used an old hair dryer and let it blow warm to top interior of frezzer,, careful not to let any cords hang/drop in any water!!,ok once done dry out as much water as possible, turn fridge on set both controls to 4,when fridge kicks on do the feel test,, you may need to close the frezzer door, air should be felt near top inside of fridge,if so than shut fridge side and feel inside frezzer near bottom and air should be felt,, side-by-side need to circulate air from frezzer to fridge, then back to frezzer
Jan 23, 2013 | Refrigerators
Kenmore 596 - temp control panel not responding when up or down buttons selected. Fridge too cold. Freezing items in fridge after power outage last night.
Most times this is a bad cold control, but there are other things to check for. Make sure the condenser fan is working and the coils are not covered with dust. A separated heat exchanger ( small capillary tubing soldered to the large suction line ) can separate from one another and make the fridge run too long. - tape tubing back together. A poor working evaporator fan motor could also make the fridge run too long and freeze - replace the fan motor. An inefficient compressor or refrigeration system could make the fridge run too long and freeze - have a service tech check this out. A misaligned control settings, make sure the air damper and cold control have not been bumped and are out of normal settings. Stuck open air diffusers or air dampers are becoming more and more common for allowing too much air to be blown into the fresh food section and freezing things. On all frost free fridge's the freezer temp air is blown into the fresh food section, if you have "easy" to freeze items ( eggs, veggies in water, etc ) in front of or under where the freezer temp air comes out, they could freeze - store them in a different spot. Doors not closing properly making the fridge run too long is something else to check for.
Okay, hope this will help in solving problem
Aug 07, 2011 | Kenmore 26.0 cu. ft. Side-By-Side...
I have a Maytag side by side, MSD2434GEW, about 8 years old, the fridge side appears to be working fine, the freezer side is about the same temp as the fridge and not cold enough to freeze anything. It...
the clicking sound is the compressor trying to start . i belive that you need to reolace the relay start on the compressor . the part that maytag has on ther websight is 12002794 about 34.00 .. mm hope this helps feed back pls ..
Dec 03, 2010 | Maytag MSD2434GE Side by Side Refrigerator
Kenmore Side By Side- Water Dispensed from door not cold
That is not a complete model# so it is hard to know exactly what you have but the old fridges (kenmore and others) had a pretty straight shot from the water holding tank to the tube that shot water in your glass so it was typically colder.
The newer ones have extra plumbing for filters along with tiny holding tanks. Most manufactures have gone out of their way to make the tanks not freeze but in doing so have made the water more "cool" instead of "cold".
It is not in the way you set it but more of the way things have become. Please give a complete model# (from inside the unit on the sticker and not off the owners manual) if you need more assistance.
Feb 18, 2018 | Whirlpool ED2FHSS Side by Side...
Frigidaire is freezing everything!
Possible defrost timer or thermostat failure.
Jul 11, 2017 | Frigidaire FRS26H5AS Side by Side...
Kenmore Elite 106-74202402 Freezes food ice solid in the fridge
Hi
Please do rate the solution as FixYa and revert for further assistance.
Thanks
Rylee
Jun 03, 2009 | Kenmore 73502 / 73504 / 73509 Bottom...
Not cooling
did you unplug it for about 8 hours to make sure that it is completely defrosted? These new side by sides use cold air to cool them unlike the good old freon tubes running aroung the inside like the fridge your grandmother had for 50 years. They freeze up easy and take for ever to thaw out. check the seal around the bottom of the door to make sure it is not broken or hanging loose.
Mar 05, 2009 | Kenmore 53642 / 53644 Side by Side...
AC,DC, gas RV fridge Dometic
You more than likely need to replace the control cable between the upper and lower board. It comes as a kit with the upper board. You can also do a bypass test by unplugging your thermoster from the circuit board. The thermoster is the temperature control for the refrigerator nothing to do with the freezer.
rvtech@myway.com
www.coachtech.info
734 777 6432
Jul 26, 2008 | Dometic NDR 1292 Refrigerator
Refridgerator freezing food
dm, I'm not sure if the thermostat is mechanical or electronic. Assuming mechanical...and I do...turn it to the lowest number...does it turn off? If this works properly, the problem is likely not the control. Does the compressor turn off at any time? If not after an hour or so of operation, the stat could be defective. That's my first guess. Oh, have you made sure that you don't have the ducts in the freezer blocked? The would deflect too much cold air to the fridge section.
Next, defrost the unit and clean the condenser coils. This will help the unit work properly. Then, wait awhile with the unit off. Meanwhile, access the compressor in the rear of the unit. Find the largest pipe coming out of the compressor. Turn the unit on. The largest pipe should frost and then, in about 5 minutes or so...either cause condensation or dry out. If neither happens and the line is either not COLD to the touch or frosty, you're low on gas. If the unit is less than 5 years old, you may get warranty coverage on the sealed unit from the mfgr. Believe it or not, too little gas will cause freezing in some cases!
Nov 28, 2007 | Kenmore 53212 / 53214 / 53219 Side by Side...
Refrigerators Logo
57 people viewed this question
Top Refrigerators Experts
Charles T Nevin
Charles T Nevin
John Tripp
John Tripp
