Question about Emerson Im90 Portable Ice Maker
How do I fix a water leak on my Emerson IM90T portable Ice Maker
I have a leak coming from the inlet portion of the water holding tank where the little filter goes into. How can I replace the fitting or patch it so it will stop leaking. I have the back off of the unit and added water to the holding tank and discovered that this is where the leak is coming from.
3 Suggested Answers
SOURCE: We have an Emerson IM90 portable ice maker which has worked fine for months. Now it is only making 5 ice cubes per baych. Any ideas?
when mine did that i got out the air compressor and blew all of the dirty and stuff off of the moter and low and behold it worked great but be carefully I tore a blade off the fan and now it runs alittle noisey. still makes great ice now I gonna find another fan blades. you need to unscrew the back to do this.
Posted on Sep 11, 2012
  • 3 Answers
SOURCE: My Emerson Portable Ice Maker started makeing a loud grinding sound when pumping water -why?
Probably the bearing in the pump is shot depending on how old it is try getting it covered under warranty
Posted on Oct 29, 2012
Emerson icemaker gets hot checked it out it's the compressor can this be a reason why my machine want make ice
Heat cannot produce ice
How To Fix Refrigerator That's Not Making Ice ' Fridge Repair
www.partselect.com/Repair/Refrigerator/Not-Making-Ice/
Find out how to repair a refrigerator ice maker that's not making ice by troubleshooting common problems and parts like water inlet valves and water filters.
1 How to fix a portable ice machine part 1 of 3 - YouTube
? 8:44
https://www.youtube.com/watch?v=oyaO_Q6CBUM
Apr 18, 2009 - Uploaded by SteveJ619
Part 1 of 3 on how to fix your portable ice machine. ... Fanstopped working on mine, is it an easy repair? ... Dumping theice maker upside down can damage the refrigeration compressor ! .... Emerson Portable Ice Maker - Emerson Portable Ice MakerVideo Review -portable ice maker - Duration: 3:57.
Jan 07, 2016 | Emerson Refrigerators
Emerson icemaker im90t fan not working
if fan not working it is gone
replace it and if there are any filters within the inner panels, take advantage and replace them too
May 24, 2014 | Emerson Im90 Portable Ice Maker
Emerson repair manual
Repair manuals are in PDF, and cannot include it here by this window.
If you wish to get some details; check the site linked here. Viewing it in "Mosaic" or "Magazine" will make surf easy. Pull up older posts. Surf the site with patience. Do a search by type in the brand name of your device at its search box.
May 16, 2014 | Televison & Video
My Emerson IM90T is not making ice. It does not have the Add Water or Ice light on. It's not freezing. Help
This is the response from Victoria in the above response
Good afternoon,
In response to your email, this product does not belong to our company. Please contact the correct manufacture. Thank you.
Best Regards,
Customer Service Coordinator
Greenway Home
Nov 17, 2012 | Ice Cream Makers
Oct 29, 2012 | Emerson Im90 Portable Ice Maker
Ice-maker does not work. water valve seems to be working.
There are 3 things that can prevent an ice maker from not working.
1- Temperature of freezzer- Temp must be below 6 degrees on most ice makers.
2- Water inlet valve- Depending on how your ice maker cycles it calls for water for 7.2 seconds. If you have ice and water though the door you have a dual valve and the ice maker selinoid ine the inlet may be bad. Also make sure water is getting to valve. Just because water is coming through the door does not mean water is entering fridge. There is a reservoir in fringe that holds around 3 gallons of water that can still make water come out the door without water entering fridge.
3- Faulty Ice maker- over time the winding and other components can get worn out and fail.
First check the temperature in the freezer.
Next check the inlet valve. To do this you need to remove the hose going from the inlet valve to ice maker and switch with the hose leading to door. Push the actuator in the door to call for water and see if water enters the ice maker. If it does inlet is good. Replace Icemaker. If not replace inlet valve. There may be a problem with the icemaker still but wont know until inlet is fixed.
If you have anymore problems or you need further assistance please feel free to contact
Jul 19, 2011 | Kenmore Refrigerators
The water line that connects to the back top of the fridge busted loose. It looks like there is an adhesive pad that keeps it in place. How do I fix it? Scott
Hi Scott and welcome to FixYa, I am Kelly
The plastic line that connects to the ice maker rubber FILL tube is what came off. Check inside the freezer and squeeze the end of the rubber tube at the back of the ice maker. I would bet it is frozen with ice. (Hand held hiar dryer for quite a while to defrost the tube FYI and do NOT melt the plactic of the ice maker water funnel.) What causes the tube to freeze is the inlet water valve starts bypassing water when it is supposed to shut off. The result of this bypassed water is a frozen rubber tube and the plactic tube on the back of the refirgerator blows off or leaks. This inlet water valve is NOT repairable.
The Fix... Replace the inlet water valve and make sure the rubber ice maker fill tube is defrosted BEFORE re-inserting the plastic tube back into the rubber fill tube. It just pushes in and the adhesive pads for holding the plastic line in place are not critical even if they are lost. The rubber fill tube fitting will retain the plastic hose just fine as long as the ice maker end of the tube is not frozen from a leaking inlet water valve.
Thanks for choosing FixYa,
Kelly
Apr 14, 2011 | Refrigerators
My superba is leaking water from the white block where the water feed line goes into the ice maker how can this be fixed ??
Normal 0 MicrosoftInternetExplorer4 /* Style Definitions */ table.MsoNormalTable {mso-style-name:"Table Normal"; mso-tstyle-rowband-size:0; mso-tstyle-colband-size:0; mso-style-noshow:yes; mso-style-parent:""; mso-padding-alt:0in 5.4pt 0in 5.4pt; mso-para-margin:0in; mso-para-margin-bottom:.0001pt; mso-pagination:widow-orphan; font-size:10.0pt; font-family:"Times New Roman";} Normal 0 MicrosoftInternetExplorer4 /* Style Definitions */ table.MsoNormalTable {mso-style-name:"Table Normal"; mso-tstyle-rowband-size:0; mso-tstyle-colband-size:0; mso-style-noshow:yes; mso-style-parent:""; mso-padding-alt:0in 5.4pt 0in 5.4pt; mso-para-margin:0in; mso-para-margin-bottom:.0001pt; mso-pagination:widow-orphan; font-size:10.0pt; font-family:"Times New Roman";} The water inlet valve on the back of the unit where the water supply comes in can have a slow leak
The valve can leak because of sediment in the water preventing it from closing or low water pressure
. Disconnect the ice maker line from the water inlet valve valve(on the back where the water supply connects). and watch to see if it has a slow drip.
Nov 19, 2009 | KitchenAid Superba KSRG25FK Side by Side...
Water leak from ice dispenser line
hi..
Your water inlet valve on the back where the water supply comes in is probably leaking. disconnect the water line coming out of it and see if you have a slow drip. Try the dispenser to see if it's just drips after use.
For the ice maker problem, Try swapping the wires on the dual water inlet valve. Then try the water dispenser. The water should go to the ice maker. This will tell you weather or not the ice maker valve is working and if the line is clear.If it does, the problem is the ice maker and not the valve and line...
thank u
rate me!!
Jul 26, 2009 | GE Refrigerators
Emerson Im90 Portable Ice Maker Logo
108 people viewed this question
Top Emerson Refrigerators Experts
John Tripp
John Tripp
mike cooper
Johnny 1000
Level 1 Expert
Are you an Emerson Refrigerator Expert? Answer questions, earn points and help others
