Question about NEC Lands Phones
NEED HELP WITH NEC DT700 PHONE - NEC Lands Phones
2 Suggested Answers
neerajp489
SOURCE: how to ping an nec phone system from an ip phone
Try disabling/enabling the SIP helper. (this change requires a reboot I think because it changes the kernel modules)
www.businesstelephonesystem.org/
Posted on Aug 22, 2012
Wanting to extend ring time - changed by itself - only ringing 5-6 times before going to message bank.
5-6 rings I think that is the best you can get
link to a manual for it
SV8100 DT310/DT330/DT710/DT730 User Guide - NEC Corporation ...
https://www.necam.com/Docs/?id=5601ae16-b7e2-4e8c-a769...
NEC-10645 UNIVERGE SV8300 DT300 DT700 USER GUIDE
au.nec.com/.../SV8300_Handset_Manual-ce03fb6c-32af-4991-9bd5-8ec.
Sep 09, 2016 | NEC Dtl-12d dt330 12-button Digital...
How do I change the extension name on the display of NEC DT700?
Default code on an SV8100 system for name is SPEAKER, 700, takes you to extension label, press HOLD to bypass and get to name, type name using dial pad with * and # as move left or right, then SPEAKER to write and exit. These phones work on several systems. The codes for the 8300 and 8500 are different. Hope this was yours.
Aug 29, 2014 | NEC Lands Phones
NEC DT700 series message: SIP Server Not Found
The phone is not being routed to the SV8000 Series SIP server. You could try to reset the phone to default in case it is holding a previous setup and attempt to allow it to pick up the new settings. While the phone is searching for DHCP press Hold, transfer, *,# The display should show ADMIN Put in the password 6633222 (Admin default) You should gain access to to the phone system Press 3 then Press 3 to access factory default. Ok that and the phone will preform a memory wipe. It should then do a restart and try to pick up the settings. If you cant access Admin (Have they changed the PW?) or it doesn't work then the phone needs deleting and resetting from the SV8000 series server, the ports for Voip need passing through the firewall or your phone needs to join a VLAN. None of these things you can do if you don't have access to these systems or the knowledge to program.
Nov 23, 2012 | Lands Phones
NEC DT700 phone lock
just lift the handset and put password. 0000 is default password.
Aug 14, 2012 | NEC DT330 - - Phone
How to ping an nec phone system from an ip phone
Jun 21, 2012 | NEC Sv8100/sv8300 Itl-12de-1 bk Tel new
My cordless phone in my restaurant is finally had it. NEC wants $300 for a new cordless! If I buy a different cordless made by a different company, will it be compatible with my NEC corded phone?
No, You must use an Nec telephone, thus the price. If you need it on one line only you could connect any cordless phone on the dial tone before the NEC system. This will ring and also you can call out but you will not be able to transfer from or to it and you cannot use any NEC system features.
NEC $279.45 from me gregdownes@verizon.net
Jan 11, 2011 | NEC DSX Systems NEC-780020 DTR-1-1 BLACK...
Nec help
speaker 42 from operator phone
dial x to be forwarded than x to forward to
hang up
Apr 05, 2009 | NEC Dterm DTP 16D-1 Corded Phone
NEC Dterm 80
NEC Dterm 80 phone, 1 ext. is blinking and we can't get it to turn off. It shows a busy signal when you try to call it.
Help it is the owners phone!!!
Sep 29, 2007 | NEC Dterm DTP 16D-1 Corded Phone
Lands Phones Logo
13 people viewed this question
Top NEC Lands Phones Experts
Brian LaDuca
george  peters
george peters
Are you a NEC Lands Phone Expert? Answer questions, earn points and help others
