How do I get my samsung syncmaster sa350 out of eco mode?
When I was adjusting something or other somehow I put it in eco mode and that option doesn't light up for me to select it to get out of it. The screen is very dim. I've just moved so I can't find my manual (which I don't think was very detailed anyhow). Thanks for any ideas!
    Problem Solver:
  • 3 Answers
You should have some buttons at the bottom of your screen go on mode and try finding the way back (hope that'll work)
Posted on May 16, 2014
mercom2
  • 3 Answers
SOURCE: samsung syncmaster 713bm
This problem is caused by a fault with IC200 on the main board, this seems to be a common failure with the Novatek chip and can only be replaced by a repair company as the new chip needs to be reprogammed and it is also surface mounted.
Posted on Jul 17, 2008
SOURCE: Error message on Samsung SyncMaster Monitor 19"
Hi There!
I had the same problem some time ago and I have managed to find a very useful website where explains how to fix it!
The solution comes from a Spanish Forum site, originally written in Spanish! Using Google translator you can have the step by step solution in English, although sometimes the translation is not too accurate!
I have managed to get my screen back to life with a total expense of 25p and 15 minutes of my Life!
Just cut and paste this link!
http://translate.google.com/translate?hl=en&sl=es&u=http://www.dtforum.net/index.php%3Ftopic%3D55304.msg1010695085%3Btopicseen&prev=/search%3Fq%3DNT68F63LG%2B50%2Bohm%26hl%3Den%26rlz%3D1T4SUNA_enUS219US220
I hope this helps!
Good Luck!
Frankie
Posted on Jan 29, 2009
SOURCE: Samsung SyncMaster 720N ...
OK, I've figured it out! There's something wrong with the control chip, so if you don't have it under warranty, here's what you can do:
1. Turn off the monitor
2. Unscrew the face of the monitor
3. Remove the bottom part of the face from the backside, so you can see the chip
(the control chip is located on the face of the monitor, under the buttons)
4. You will see a small white connector about 5mm wide, UNPLUGG it
5. Put the small cable that you've unconnected under the front, so you can close the monitor back
6. Close the monitor and plug it back in
That's it. You won't be able to change your settings (they autoadjust anyway), but you won't have to throw the monitor away!
Peace.
Posted on Dec 01, 2009
avnish1011
  • 253 Answers
SOURCE: my Samsung syncmaster 730a monitor wont come on.
Hi friend,
You need you check your display cable. it should be connected in your CPU. sometime cable lose in CPU..then monitor not given any display ...
Posted on Dec 20, 2009
SOURCE: syncmaster 913v not optimum mode
I just resolved this problem for my SyncMaster 913N.
It seems to be a known issue, however it can take quite some time for the problem to occur. In my case about 3,5 years, so well out of warranty.
Short term solution: unplug your monitor from power. The switch on the front is not good enough. Pull the plug and leave it for an hour or so (all night if you can). Good chance the monitor will work next time you power it up.
The problem will is likely to come back..
Permant fix requires some basic soldering as per this video:
I just managed it and it has been ages since I soldered a resistor so you may very well be able to do it. I spent $25 on tool and part and saved me from buying a new monitor.
Posted on May 01, 2010
Does my Android Arise have MHL compatibility? Trying to connect to a Samsung SyncMaster SA350 monitor
You can use this converter
http://www.tokosigma.com/?1136,en_mhl-micro-usb-to-vga-f-with-audio-cable-adapter
Mar 18, 2016 | Samsung Computers & Internet
Height adjustment on monitor stand is stuck. This stand is used on the Samsung SyncMaster 213T and the Dell 2001FP monitor.
I'd call or email samsung. They actually want to know about product problems so the next edition is an improvement. Their Owner's manual should have contact info, or the install cd or google. Tomshardware.com
always seems to be very helpful and may have a "fix".
Mar 13, 2015 | Samsung SyncMaster 213T 21.3" LCD Monitor
Update the firmware for a samsung syncmaster monitor model sa350
You should only have to install the drivers for it to work. Have you tried Samsung's website?
Nov 14, 2014 | Samsung SyncMaster S23A350H
Samsung syncmaster sa350 start computer up then in the top left corner it shows a graphic that says hdmi, then the computer screen goes blank and the power button just blinks red continueously with a blank...
Is your computer connected via the HDMI cable? If not pull up menu and change to another input type. If it is HDMI, check cable ends. You can test by plugging into a Blue ray player and see if video plays on monitor as a test method to verify video coming from computer incase your video card has died for some reason..
Your monitor is going into sleep mode since it can not see an HDMI signal coming across the input. Check your cable though.. sounds like the biggest culprit to me.
Jan 29, 2014 | Smart Modular SV3170A
Samsung Syncmaster SA350
go to the website and download sync master
May 06, 2013 | Computers & Internet
Adjust brightness on Samsung S22A100N
From the samsung Answer in "How to adjust the brightness on your LED Monitor", There is written on the LIMITATION
Limitations:
This menu is not available when Samsung Magic Bright is set to Dynamic Contrast.
This menu is not available when Eco Saving Plus is set.
This menu is not available when Eye Saver Mode is enabled.
So with those condition matched, This menu(menu for adjustment) will not be available.
UPDATE WITH SOLUTION:
For windows user samsung is only giving link up to windows 7. For windows 8,10 use magicTune lite instead of magicTune premium.
Link for magicTune lite:
http://www.techplusme.com/software/download-samsung-magictune-widnows-8-1
Dec 01, 2012 | Samsung S22A100N SyncMaster Widescreen LCD...
NO SOUND ON MY SAMSUNG SA 350
The Samsung SyncMaster SA350 does not have speakers so you will not get sound on hdmi input.
May 23, 2012 | Computers & Internet
HOW TO DELETE BRIGHTNESS BOX FROM MONITOR ON SAMSUNG SYNCMASTER 720n
If your trying to get out from the brightness option. Please follow this steps...
Go and click this manual, then at the left side of the manual look option that says for "Adjusting your monitor" then look for user controls.
I hope it helps you a lot :)
Feb 03, 2011 | Samsung SyncMaster 720N Monitor
No sound when on pc mode
Check if your PC can play audio on some other speakers or headphone. If yes, check your monitor audio cable connections. If no something's wrong with your PC audio drivers. Try re-installing them or could be a hardware issue with your PC. Get it checked.
Sep 29, 2007 | Samsung SyncMaster 940MW 19" LCD Monitor
Computers & Internet Logo
69 people viewed this question
David Payne
David Payne
