Question about Whirlwind FH-778 Air Conditioner
Ac unit is leaking alot of water. Freinds say I have to drain the system. They also told me how. I don't know if my system is different, but is not easy like they say.
    Sergeant:
  • 340 Answers
Yes if its what i think they told you . Tom
Posted on Jun 23, 2009
Goodman ac/heater drain pan leaking since instillation 3 years
sounds like the unit needs to be elevated and leveled.
Aug 10, 2012 | Goodman Heating & Cooling
Why is my lg portable ac leaking water from bottom of unit
There should be a drain pipe at the side or bottom of unit to run a drain line. Locate drain and clean it out .
Feb 26, 2018 | LG Heating & Cooling
I have water in the glove compartment i don't know where come from
check the hoses coming from the heater core, also,, if you have an ac unit, it could be leaking from a plugged drain tube,, check both of those
Aug 06, 2011 | 2000 Dodge Durango
Leaking on the right side under the car they told me it might be the evaporator but I don't know where that is in my car I have a 1997 Ford Expedition, I don't even know what it looks like
The evaporator is located in the heater box, it is the AC's equivalent of a heater core. Water is a NORMAL by product of refrigeration, and the clear water must leak out to the ground.
Jun 28, 2011 | Ford Expedition Cars & Trucks
I don't know if there is a place to drain the air conditioner unit.
jbuck, Since your unit is a multifunction unit (AC, Heat & Dehumidifier) you don't have to darin any water. It uses an evaporative system, that exhaust the water/moisture thru the exhaust hose to the outside. With that said, there may be a rare occasion, that the condensation pan under the unit, needs to be drained. In which case, you will find the drain hole, covered by a plastic screw off cap, on the left rear of the unit (as you face the rear of the unit), next to the cord keeper. A small plastic bowl or pan that will fit under the drain hole will suffice. As, there shouldn't be that much water to drain.
Hope this helped you. Please let me know. Thanks.
Jun 12, 2011 | Haier CPN12XH9 Portable Air Conditioner
Water leaking from indoor unit against the wall.
It's probably the insulation around your refrigerant pipes. If it is too thin or missing in a section they will condensate.
Jan 16, 2010 | GE Quiet-Aire Ductless Split System Air...
Water leak on passenger side on 99 chevy s 10 not anterfreeze, leaks when not being driven
there is only one thing that leaks water there, that is the AC condensation drain, water forms as part of the AC cooling the evaporator core, this water must be drained away or it will flood onto passenger area, so there is a drain on the passenger side at bottom of firewall, will leak allot of water depending on how humid the air is.
May 05, 2009 | 1999 Chevrolet S-10 Pickup
2000 dodge grand caravan AC stinks
I don;t know who told you the coils would leak and let leaves in but don;t let them work on your car.
2 things to do.
1 make sure the drip tube is not clogged up. If it is water will build up and could mold. Should be a small hose coming off the firewall under the car. Just make sur eit is open and clean.
The next thing is to remove the AC/Heat fan and look in there. You can look in there and smell and remove any leaves/dirt you fine.
Mar 27, 2009 | 2000 Dodge Grand Caravan
Leak under car
if it's water, and not gas it's not your fuel pump. if it's water and not a sweet smelling green or red liquid it's not your cooling system. it's probally condensation from your ac, have you been using your ac alot? if so no worries. or a bad window or door seal and it's letting in water onto your floor. and yous aid under the door, so it's on the ground or on the floor of the vechile? if on the ground, more then likely it's just your weep drain from your ac system.
Mar 14, 2009 | 2000 Kia Sportage
Mothers AC unit
That has nothing to do with the water. Sounds to me like it needs cleanning, (the water is not drainning toward the back of the unit) ,,(dirty filter, which its trying to **** air anywhere it can even thru the drain hole, or not enough slope, leanning toward the back so gravity can flow the water to the back of the coil! Thank you-very-much!
Aug 28, 2008 | GE Zoneline AZ38H12DAD Split System Air...
Heating & Cooling Logo
145 people viewed this question
Top Whirlwind Heating & Cooling Experts
AJMAL KHAN
Dennis Boxerman
Bill Long
Are you a Whirlwind Heating and Cooling Expert? Answer questions, earn points and help others
