Question about Hayward H250FDN Low NOx Natural Gas Pool or Spa Heater
Hayward H250FDN blue temperature control will not respond (MODE and RED up button are OK)
Hello brainy people! I have a Hayward H250FDN heater which the temperature controls are stuck and will not respond. I can see the pool temp (84deg) on the display, I can use the MODE button to flick between the pool and the spa temperature displays ok, but the BLUE temperature button is stuck at (102 Spa) (73 pool) and will not go down if I press them. (The UP button works just fine!) I purchased a new display, thinking it was the button that had been burned out as per other posts on here.. but sadly, exactly the same problem is occuring with the new one I just fitted. Is there a master reset button anywhere that may help me? Has anyone else experienced this issue? I'm now worried that when winter comes and the temperatures drop, if anyone turns the heater gas on... I'll have a 102 degree spa day and night! $$$$$$ HELP!!! Should I just order a new EMERSON circuit board? Any ideas helpful. Thank you.
    Top Expert:
  • Hayward Master
  • 5,062 Answers
Up and down button at same time with either mode or enter at same time for seven seconds that should unlock
Posted on Sep 05, 2017
3 Suggested Answers
  • 246 Answers
SOURCE: I have a Hayward HM2400 pool heater. The control
i bet you have a automatic control ? if yes the sensor is bad if not some one set the heater not to go over 96
Posted on Aug 31, 2009
  • 990 Answers
SOURCE: I have all Hayward equipment on my pool and have a
You will have a small wire comming from the main box by the equiptment that will go to the pipe between the pump and the filter. It will connect to a piece in the pipe that is held in place with a stanless steel clamp. This is the heat sensor for the control and has gone bad. It is simple to replace and farley inexpensive. That should fix you up, good luck.
Posted on Feb 14, 2010
Why does my hayward h250fd have and if error code? it is a brand new heater
If the control exceeds the maximum number of ignition retries or recycles the heater will shut down and go into lockout. Automatic reset is 60 minutes.
There are a few reasons that this might be happening. They range from air in the gas line to inadequate gas flow. Start by checking the installation
Aug 08, 2014 | Hayward H250FDN Low NOx Natural Gas Pool...
Is there an alternative control panel I could use for a H259FDN?
Unless you have rigged your unit for remote control, this control panel is the only one listed.
You can check this link for contact information
http://www.hayward-pool.com/prd/In-Ground-Pool-Heaters-Universal-H-Series-Low-NOx_10201_10551_14002_-1_14003__I.htm
May 12, 2014 | Hayward H250FDN Low NOx Natural Gas Pool...
How do I drain an h250fdn heater
There is a drain plug on the inlet/outlet header.
Oct 23, 2013 | Hayward H Series Electronic Ignition...
When heater is running smell way to much gas
have gas pressure checked if ok check pressure on back side of gas valve also check connections after gas valve
Aug 15, 2013 | Hayward H250FDN Low NOx Natural Gas Pool...
I want to go over 104 degrees
cannot just can go to calibration and cheat 4 degrees
Jan 12, 2012 | Hayward H250FDN Low NOx Natural Gas Pool...
Header cracked on hayward pool lo nox h250fdn heater. need to replace the header. Please help?!
Headers on hayward heaters are usually warranted for 10 years, except for freeze or chemical damage. You may want to contact a local warranty station to see if you can get it replaced under warranty.
May 07, 2010 | Hayward H250FDN Low NOx Natural Gas Pool...
Heater temperature control buttons
The board is bad. The part number is IDXLCPA1930. Expect about a $400 replacement cost.
Dec 04, 2008 | Pool & Spa
Hayward H250FDN Low NOx Natural Gas Pool or Spa Heater Logo
215 people viewed this question
Top Hayward Pool & Spa Experts
Jay Finke
Jay Finke
Bill Jordan
john h
Are you a Hayward Pool and Spa Expert? Answer questions, earn points and help others
