Question about Braun Tassimo Espresso Machine/Coffee Maker
Piercing unit for tassimo 3170 - Braun Tassimo Espresso Machine/Coffee Maker
2 Suggested Answers
  • 679 Answers
SOURCE: where in Canada can I find a parts store to find a
hers are the service centers you could try
WESTERN SHAVER CENTRE
544-6TH ST.
V3L 3B5 NEW WESTMINSTER
DOROTHY'S APPL. CTR. LTD.
6930-104TH ST.
T6H 2L7 EDMONTON
Phone: (780)436-8393
Fax: (780)436-8340
R & E HOME SERVICES
Box 1058, 345 CARGILL ROAD
R6W 4B1 WINKLER
Phone: (204)325-9736
Fax: (204)325-086900 MAPLE AVENUE, UNIT A-32
MAPLE VIEW CENTRE
L7S 2J8 BURLINGTON
Phone: (905)631-75610
Posted on Jan 05, 2011
Tassimo low volume
may also have a clogged water line filter..change that also..
Jan 11, 2014 | Bosch Coffee Makers & Espresso Machines
Tassimo repair
Is your Tassimo dripping? Mine was. Coincidently, I ordered a new piercing unit as the rubber gasket on mine was torn. When I got it, I had to take the old one off. When I pushed from the bottom of the tube upwards to remove the piercing unit, I found that the tube was full of little metal pieces from the top of the coffee disks. They were likely trapping in moisture. I cleaned out the tube and washed everything and now I am getting far fewer drips.
Sep 13, 2013 | Coffee Makers & Espresso Machines
Where in Canada can I find a parts store to find a piercing unit for my Braun Tassimo unit Braun Tassimo-type 3107 serial # 9006bc10128774 - machine code 10000189 part # c2 piercing unit This part we...
544-6TH ST.
6930-104TH ST.
T6H 2L7 EDMONTON
Fax: (780)436-8340
R & E HOME SERVICES
R6W 4B1 WINKLER
MAPLE VIEW CENTRE
L7S 2J8 BURLINGTON
Jan 05, 2011 | Braun Tassimo Espresso Machine/Coffee...
Where can I locate the part of the Tassimo coffee maker that makes the hole in the coffee product?
You need the piercing unit, and you can find them here at Braun's parts site. Thanks for using Fixya!
Feb 22, 2010 | Braun Tassimo Espresso Machine/Coffee...
Tassimo coffee maker part replacement
If your machine is made by Bosch then go to www.bosch-eshop.com where you can order spare parts online. I think the part number is 616231:Jet and is called a Tassimo piercing unit.
Nov 20, 2009 | Braun Tassimo Espresso Machine/Coffee...
Every light blinks and it won't heat water a braun tassimo coffee maker
just posted this solution to another problem. there is something on the glass bar code reader up where you insert the t-disc - or the water vessel is not properly seated in the base of the coffee maker.
Check both.
Nov 04, 2009 | Braun Tassimo Coffee Maker
The motor just keeps running after the coffee has completed it's cycle. The only way to shut if down is to turn off the unit. I've tried descaling the unit but that has not helped.
I've had the same problem and found no documented solution or cause. Calling Tassimo was no help. However I've noticed that it usually happens after trying to close the unit when the T disc was not lined up correctly. This pierces the foil in the wrong place. If you run it like that, OR if you open it back up, line the T disc up and reclose; it will spray water and coffee grounds all over. It seems some of the coffee grounds or a piece of foil from the T disc can get stuck in the little switch on the left side bottom of the closing mechanism. This switch indicates to the machine that it is closed. So if the switch gets stuck closed, the machine can think it is closed when it is really open. This prevents a failsafe interrupt from operating which would normally stop the pump and reset the stuck faulty logic in the machine. So the solution is to clean the machine very well in the area around the T discs. This includes removing, cleaning(inside and under), and replacing the part that pierces the T discs. It may look like it is all one piece, but you can pry it up with a butter knife.
Aug 29, 2008 | Braun Tassimo Hot Beverage System - T-DISC...
Coffee Doesn't Brew
You may have gotten a unit that is minus the piercing apparatus. The little plastic piece with the piercer may come off with the used pod. This never happened to us but my daughter-in-law did, and apparently threw the piercer out with a used pod. They were able to order the part which seems to be easily removable - actually they ordered two while they were at it. Their coffee maker is working just fine.
Mar 18, 2008 | Braun Tassimo Espresso Machine/Coffee...
Tassimo coffee machine doesn't brew automatically
You have to clean the barcode-reader window. Very easy, just wipe it with a cloth. (It's the window just under the piercing unit thingy.)
Oct 07, 2007 | Braun Tassimo Espresso Machine/Coffee...
Braun Tassimo Espresso Machine/Coffee Maker Logo
Top Braun Coffee Makers & Espresso Machines Experts
Henry  Thomas
Henry Thomas
Are you a Braun Coffee Maker and Espresso Machine Expert? Answer questions, earn points and help others
