Question about Onkyo Audio Players & Recorders
How to repair my Onkyo TX NR525 which is getting dead time and again
I bought Onkyo TX NR 525 receiver 3 months back from USA and took that to India. After few day all on a sudden it went off while I was watching a movie in a medium volume. I noticed it gets relatively very hot, I have Yamaha RX V795 which does not get so hot in comparison to Onkyo NR 525. There is no service center of Onkyo at India, so I had to send that to Singapore Onkyo service center for repair and got that back after a month. Today again same problem, it went off and dead, it is making repeated "click" kind of sound from inside the receiver. Can someone help me how to solve the problem, or give me a service manual of Onkyo NR 525. It is time consuming and costly for me to send it again to Singapore and repair. Thanks
  • 2427 Answers
SOURCE: receiver shuts off at times
Those recivers are usually preety good oones with little to no problems. Its just when it gets a certin age it extends its life. You can take it in to a technician to have it serviced, mostly you have cracked solders on the board which will accout for the problems you are having. there might be a few things that need changing but basically your recuver is good it just needs servicing thats all.
Or if you prefer you could get a new one.. BUT YOU CAN JUST HAVE THE CURRENT ONE YOU GOT SERVICED..
a service wil include
re-soldering cracked or loose solders on the board
changing a couple of stuff, maybe capicators or resistors and unlikely an ic.
dusting it
So just take it in to a technician for a service cause its reached it life span ,,
Posted on Jan 05, 2008
SOURCE: Onkyo TX-SR702 keeps going into speaker setup mode
Los amplificadores de audio del aparato estan a punto de danarse,checa las bocinas una por una a ver si no hay alguna mala.
Posted on Apr 14, 2008
  • 151 Answers
SOURCE: Yamaha RX-V800 - No audio on left and right channels
make sure the (a) speakers are switched on,this may be a switch on the front panel or in the main set up menu.
hope this helps.
cable guy.
Posted on Jun 04, 2008
VOTIT
  • 2071 Answers
SOURCE: JVC A/V Receiver RX 7042S - DSP NG
it seems the problem of your unit is in the power amplifier section,the IC chip there is defected that why only analog source .you better bring back to them the unit it is the only option, that is there back job...
Posted on Jul 03, 2008
artiedc
  • 35 Answers
SOURCE: Onkyo TX-SR705 shuts down suddenly
Onkyo receivers have a safety circuit in them to protect the Amplifier from blowing up:
If you listen closely when it shuts down ( after a loud scene ) there is likely a loud 'Relay Click'..
If this is what is happening you might be able to verify it by turning the volume all the way 'off' and waiting for the circuit ro reset ( releasing the safety relays & returning power to the internal Amplifier ) : you should hear another click, yhen you can bring the volume back up carefully and there will be sound again.
This safety circuit trips when then Onkyo receiver detects an 'Over Current' condition on the
' Power Supply ' that feeds the internal 'Audio Amplifier'..
Generally caused by:
1.
Improper load presented to the Amp outputs ( FL, LR, RL, RR, SUB, CENTER )
If you can ( one at a time ) turn off the SUB, Center, Fronts and Rears: trying to re-create the failure each time while you have one part of your system disabled or having their level turned way down..
You can isolate where the problem is coming from.
- any or all of these speakers being the wrong Impedence ( I.E. 4 Ohms instead of 8 Ohms )
Unless the receiver manual or the sticker near the 'speaker connetor' specifies a range or another value, you should assume 8 Ohms. Your speakers should say on the back of them.
- any of the speakers being connected in parallel ( 2 speakers to a single one speaker output ) .. Two 8 Ohm speakers connected in parallel make a 4 Ohm load to the amplifier.
- If the Suwoofer is Passive ( Not having its own power cord and amplifer ) it has a
Passive Crossover : this crossover can have its own power rating or limitation.. If it is constructed with capacitors that have too low of a working voltage, then they can saturate and the crossover itself can present a load to the amplifier that will case this 'Over Current Shut-Down'..
You user manual should detail this.
Ed
Posted on Apr 09, 2009
Onkyo tx nr656 showing. NR:LCRSLSRBLBR, Any idea. Not working at all.
Hello, I am sorry about your issue. The receiver may have detected a problem with a speaker or speaker wire. Please contact Onkyo at 800-229-1687 option #3 so that we can troubleshoot with you. Thank you, Onkyo USA
May 13, 2017 | Onkyo Audio Players & Recorders
Hi, I have my Onkyo amplifier since 3 years, model is TX NR 609 but the audio is not working out but video is ok. Where is your nearest service center in Dubai, picture attached.
Hi, please see the contact below. Thank you, Onkyo USA
Hi Fi City Electronics LLC
Distributor
Address
P.O. Box 7344, Next to HSBC Bank, Nasr Square Deira, Dubai, United Arab Emirates
Phone
+971-4-2218505
+971-4-3399167
Mobile:+971-5050-27555
Fax
+971-4-2215258
Oct 01, 2016 | Onkyo Audio Players & Recorders
My Onkyo TX-NR838 switches off when I turn the tv off. I can't switch the receiver back on for 2 days
sounds like a faulty cable or psu .... or some bad solders on the back of a scart socket if you use scart
if not its something to do with TV detection the TX-NR unit uses
Dec 04, 2014 | Onkyo 7.2 Channel Network A/V Receiver -...
I owned an onkyo tx-nr 414 ,i bought it in al danah mall dammam last one and half year ago and one day the the "NO STORAGE" came to the front screen of the display.
Hello, I am sorry about your issue. Have you tried changing sources after you plug it in. It sounds like you are in USB. Please try bd/dvd or cbl/sat. Thank you. Onkyo USA
Jun 13, 2017 | Onkyo Audio Players & Recorders
Receiver will not turn on and is making a clicking sound TX-NR 609
This is the same problem i've had with my POS nr609. I will never buy Onkyo again.. Everyone warned me about the poor quality.. This thing worked for a year and a half, blew the amp., replaced and now another year and a half, f'd again. Save your time, buy a Denon or a Harmon Kardon. Better quality, same features.. Boat anchor here
May 15, 2012 | Onkyo TX-NR609
I have an Onkyo TX-SR606 connected via hdmi to a Sony Bravia 52" lcd screen. My inputs are a Panasonic DMR-EX77 dvd Recorder and a PS3 via hdmi into the Onkyo. All worked well for a month but now it takes...
The problem is with the HDMI daughterboard in the AVR is bad. This is a well documented issue on this interweb! A general search in google can confirm. Here are some stuff cut and pasted frm their site and another forum. Onkyo USA Corporation (hereinafter referred to as Onkyo) hereby warrants all Onkyo products PURCHASED DIRECTLY FROM ONKYO OR AN ONKYO AUTHORIZED DEALER- WARRANTY PERIOD (from date of purchase) New Products: Receivers 2 years Parts & Labor-- You can go to the Onkyo webpage to find a n authorized service repairman.
*** I took mine to a service repair place today, the guy said that he had two that he just fixes yesterday. He said that this issue has given him a ton of work. Just make sure that you have your receipt from AN UNAUTHORIZED DEALER and that your still under warranty. Receivers 2 years Parts & Labor
Jul 02, 2010 | Onkyo TX-SR606 Receiver
Hdmi compatibility
Hello, how long is the cable from the receiver to the TV? Thank you, Onkyo USA
May 31, 2017 | Onkyo TX-SR706 Receiver
Problem with onkyo tx 919 unit
Hi...
If you've had it "fixed" 3 times and the problem comes back either you have the wrong impedance (ohms) speakers connected or the power supply in the unit is the actual problem.
Happy new years,
Scott
Jan 01, 2009 | Onkyo TX-DS939 Receiver
101 people viewed this question
Top Onkyo Audio Players & Recorders Experts
 Grubhead
Grubhead
Electro Med Services...
Are you an Onkyo Audio Player and Recorder Expert? Answer questions, earn points and help others
