Question about Craftsman 27cc 2 Cycle Crank Straight Shaft Weedwacker Gas Trimmer ()
Why does my weedeater over heat? - Craftsman 27cc 2 Cycle Crank Straight Shaft Weedwacker Gas Trimmer ()
    Sergeant:
  • 311 Answers
Clogged cylinder fins?
Too lean a mixture?
Define overheating.170-250* is OK.
Possible binding drive head or cable.(Working too hard).
Posted on May 19, 2014
Line on crafstman weedeater
wind it in the other direction.
Aug 10, 2017 | Weedeater Garden
Husqvarna weedeater overheating after unclogging exhaust
The only reason for a brush cutter to over heat is because the engine is running too lean, this may be because the fuel filter is blocked, or the fuel hose is leaking, or the carb is set to lean on the carb mixture screws,
Jul 19, 2012 | Husqvarna "Chain Saw - 16" Bar, 3 Hp
Need ear loop for lg hbm 730 blue tooth
used string for weedeater heated it with lighter to make loop works great
Nov 27, 2009 | LG HBM-730 Wireless Headset
I have a Weedeater FL1500. I just changed the
Once it heats up either the spark plug or the ignition module is breaking causing them not to work. I would first check on the price of the ignition module, Then decide it is to expensive to repair and send it to the scrap man.
Good Day.
Oct 30, 2009 | Poulan Featherlite Gas Blower, with Low...
Can't get weedeater spool head loose to change the line.
there is three types of heads push, screw, and snap. The screw type have a big ball looking thing on the bottom that when pressed lets the line out. the snap kind are verry distinctive they slid in and two tongs snap in to place you will be able to see them on the out side. the push head just push in and turn.
Jul 23, 2009 | Garden
My weedeater edger over heats and freezes up. it gets very hot, smokes around the spark plug, the spark plug is coverd with soot and it won't start again
Are you using mixed gas? The gas needs to be mixed 50:1
You will have to use 2 cycle oil. If you are using mixed gas, than you can buy a cooler spark plug.
Sounds like the spark plug is not properly gapped.
May 23, 2009 | Poulan Weedeater/Electric Trimmer 4.1 Amp
Craftsman weedeater model # 358.796090
I would first clean the air filter, check fuel lines for cracks and check the fuel filter inside the tank, if those look good try adjusting then if necessary rebuilding the carburetor.
Also you might move your post to another section; it is under timers not trimmers. ;)
May 21, 2009 | Hardware & Accessories
Craftsman 27cc 2 Cycle Crank Straight Shaft Weedwacker Gas Trimmer () Logo
62 people viewed this question
Top Craftsman Garden Experts
Wade Mobley
Wade Mobley
Dean Gruber
Roland W VanLue
Roland W VanLue
Are you a Craftsman Garden Expert? Answer questions, earn points and help others
