Question about Drills
My hand drill is not charging the indicater light is ok but the batrry is not charged what is the problem?
    Genius:
  • 1,342 Answers
You need a new battery.
Posted on May 17, 2014
SOURCE: Very little juice in freshly charged batteries
have you tried the batterys in any other tool?
you would also need to check the voltage of the batterys they should be at least 18 volts (19 prefered)
then if the batterys do not show charged you would need to make sure the battery charger is putting out voltage.
After that contact your closest Ryobi service center we would check that for free to let you know what you need, I am sure you local place would do the same.
Posted on Mar 20, 2009
harlan301
  • 205 Answers
SOURCE: Have a Fire Storm place battery in charger green
if you have one check the battery and charger with a meter. if there both fine check the prong's on the battery and the power tool. if charger is'nt charging check the fuss in the charger.. good luck let me know.
Posted on Oct 16, 2009
  • 832 Answers
SOURCE: wagner cordless drill ,the charger is not charging
If the charger is no longer working, then, take another
charger to charge the battery of your Wagner cordless
drill. If it charges, then, you have to replace your charger. It is already defective.
Posted on Nov 27, 2009
  • 130 Answers
SOURCE: The drill has stopped charging up. No obvious
It may be the charger, but most likely the battery can no longer hold a charge. This may happen if the battery drops below its holding charge. Example, left discharge for a couple months. There is little that can go wrong with a charger unless you start smelling burnt plastic from it.
Posted on Jun 08, 2010
puertobori
  • 7733 Answers
SOURCE: bosch drill has no power i have two batterys they
Need an overhaul of the brushes.
Posted on Nov 08, 2010
My Nutool battery charger NXCD18-KA does not charge the batteries, when a battery is inserted the red and green lights stay on and there is a buzzing noise.
No doubt the battery is dead and will no longer accept a charge . replacement is your only option .perhaps a batteries plus store can rebuild it . much cheaper than a new one if they can https://www.batteriesplus.com/store-locator
Aug 17, 2016 | Drills
Shoud light red light flash behind charge indicater when switched on on hurricane
hi, is this still a issue, this is a fault ....
Regards
Rob
www.gewizrepairs.co.uk
Mar 12, 2015 | Pride Hurricane 4 Wheel Personal Mobility...
PBS 18 li-2 bosch cordless drill lights on but no power.
You are sure the battery is charged OK? Bosch Li-Ion drills have a feature whereby they stop working when the battery is low but not discharged right out. This is to extend the battery life as it does not like being flattened altogether.
This happens quite suddenly, from one press of the trigger to the next. It can make you think the drill is faulty.
If the battery charge is OK, then maybe
- trigger faulty
- motor burnout
- broken contact on battery or in drill battery shoe
Oct 28, 2014 | Drills
Hi mine show fully charged drilled 1 6mm hole and went flat yet sometimes is ok
Try fully discharging the battery first and let it sit for a few days. Then fully recharge before use. What happens with battery operated drills is the batteries develop what is called memory of the charge level when they are recharged and will not charge past that point but the charge light will show full charge. It happens when the drill is used for a period of time and then the battery is placed in the charger ready for next time instead of using the drill until it is flat or leaving a partially used drill on the bench and not recharging it until it is flat
Jun 25, 2013 | Milwaukee Tool V18 Battery
CHARGER PROBLEMS
The flashing light indicates the charger is charging the battery (or attempting it) and if it never finishes charging you should try to charge a different battery, if the charger charges that one ok then the battery is bad.
Jun 18, 2010 | Dewalt 18 Volt Compact Drill Kit
I started charging the new motorola battery I bought and for the past six hours the phone has not indicated BATTERY FULL. Is there any problem ?
NO need to worry,the brand new motorola battery needs to be charged for atleast 14- 16 hours. After you see a green light on it charge it for another 1hour . Enjoy your new phone its a Good buy.
Apr 01, 2010 | Cell Phones
Charged it and it stopped working
Here is the link to Skil. http://www.skiltools.com/en/CustomerService/ServiceCenters/
Call them and see what they recommend that you do. They will want to keep you as a valued customer. Regards, Joe
Jan 25, 2010 | Skil 2362 02 7.2 Volt Lithium Ion...
Hi, my drill has just stopped working i have changed the battery but it seems dead ?? the drill is about 3 years old but has only been used a hand full of times as it a personal home diy tool ?????
When you put the battery in the charger, does the light go on? The charger has lights to indicate whether the battery is fully charged or not. If it is dead when you put it in the charger and remains that way after one hour, you can be pretty sure that the battery is dead. If there are NO lights on the charger, plug it into a different outlet and recheck. Not using the drill for long periods of time is really not good for the battery. The drill is probably ok, but the charger or battery could be the problem.
Nov 15, 2009 | Dewalt 18 Volt Compact Drill Kit
Drills Logo
Top Drills Experts
Are you a Drill Expert? Answer questions, earn points and help others
