Question about Bosch Dishwasher Glass Rack Insert SGZ2004UC
Where is there a user guide for bosch dishwasher SG13002GB/10
The dishwasher is not cleaning the dishes very well and there is water left over under the plate
SOURCE: Bosch SHX46A dishwasher
I have a Bosch SHX46B05UC/14 and it stopped functioning right. It filled, it ran, it drained, it sounded okay, but I finally determined there wasn't enough circulation pump pressure to swing the spray arms. Turns out the problem was a pump pressure adjustment screw, accessible under the kick plate, had backed off--now if I can only figure out how to set it properly, low enough to clean the glassware, high enough not to break the pots and pans--or is it the other way around. I also found some beans in the drain sump (easy to remove cover plate from inside with a torx driver, large object trap not locked down properly and a riser for the upper spray arms not press fit sufficiently into pump outlet (I wonder if I blew the line while setting pump pressure. I AM looking for guidance on how to properly set the pump pressure, for the moment, I simply turned it into its spring loaded range and cranked it down a few turns.
Posted on Dec 02, 2007
  • 677 Answers
SOURCE: Dishes are not coming out fully clean
the is a new product out called the dishwasher filtration system. it actually filters the water going into your dishwasher and leaves your dishes spot free. after the first load i was amazed that the white film was gone and my dishes were sparkling. you can get it at www.dishwasherfilter.com.
Posted on May 21, 2008
SOURCE: Bosch dishwasher
Although I previously posted with the same problem of a film on the dishes after cleaning, I did find a section in the owner's manual which solved my problem. Lift up the rinse aid cap on the inside door - the factory setting is on "4". The rinse aid works in conjunction with your local water, which has variations in it's hardness or softness. When your dishes are streaky, lower the rinse aid setting to 1 or 2. If your dishes are spotted, raise the rinse aid setting higher.
Posted on Feb 20, 2009
here2helpBSH
  • 27 Answers
SOURCE: Bosch SHU53A dischwasher runs continuously without water
check and see if there is water in the base by removing the toe kick. if so then it activated your float micro switch. clear the water from the base. i use a wet vac, but if you don't have one just soak it up with towels. once that styrofoam piece on the left side of the base isnt submerged in water anymore then it should start. it could be a broken hose or bad part. check hoses if you have a rat or mouse lingering. otherwise i have also seen flexable cutting boards blocking the condensation hole on the inside of the tank on the right wall. if you think it was that then just keep those flexy cutting boards on the left side or top rack.
if no water is down there.. then where that styrofoam piece sets on the left side. find that red plastic rod and flip it upward a few times to un-stick the float switch with the dishwasher unplugged first of course.
Posted on Mar 19, 2009
  • 10865 Answers
SOURCE: Dishes and glasses being etched; looking dirty; embarrassing
First of all, if you're talking about actual glass as opposed to crystal, glass can etch easily. Why? Because like crystal, there are variations in its quality. Cheap glass will etch faster with the use of an electric dishwasher compared to higher quality glass.
Did you know that the main constituent in most automatic electric dishwasher detergents is sodium hydroxide (lye) and chlorine bleach (another caustic acid)
A Bosch dishwasher has very long wash cycles, further exposing your dishes to the possibility of etching damage. You should stop using the sani-rinse cycle if there is such an option and switch to a gel format detergent as opposed to a powder. Use a rinse agent such as Jet-Dry. This should solve your etching problem.
Posted on Apr 23, 2009
Runs through cycle, but dishes and glasses do not dry, they are soaking wet.
10 Tips to Help the Dishwasher Run Better - Cleaning Tips ...
www.thekitchn.com/10-tips-to-make-yo...
Apartment Therapy's The KitchnFeb 24, 2014 - Well, we're here to help, with 10 tips for making your dishwasher run its best. ... loading up to help reduce particles stuck on dishes once the cycle is over. ...water to flash dry and not roll off your dishes, taking the ends of the dirty bits with it..... but can lead to damage, particularly of any glasses you put in the ...
[PDF]Dishwashers - Frequently Asked Questions ... - Bosch
www.bosch-home.com/Files/Bosch/In/in/Document/Bosch.pdf
this cycle the dishwasher dries the dishes. 3. ... dishes. During this time, you do notneed to be around the dishwasher as it ... Does it also dry the dishes after the wash?... You can put utensils that are made out of steel, ceramic, glass, plastic which is ...No, the dishwasher runs the whole washing programme automatically.
Why is My Dishwasher Not Drying the Dishes? ' Dr ...
Dec 03, 2015 | Dishwashers
SG13002GB/07 bosch dishwasher: Water isn't getting
1. Water inlet valve is faulty = replace 2. Main motor (circulation pump) faulty = replace
Jun 23, 2017 | Dishwashers
My Bosch SHX56BO6UC14 is not getting the dishes clean at all. It's making a grinding sound. It is pumping water & spraying water, but not getting anything clean. help?
Hi
If you are noticing that the dishes are not clean, then there are a few things to check for. Check the soap powder if it's kept in a dry environment. Also try replacing the powder with something like a gel or liquid. Next thing to check for is the water pressure and fill valve. Check if the water is filling in and the spray arms are throwing the water with enough pressure. Try and listen to the sound if you hear a proper spraying action sound.
If it seems as a low water pressure then check the fill valve. Now, check if dishwasher is draining the water or not. While the dishwasher is working check whether the dishwasher is draining and there is not much left out water after the cycle is complete. Try cleaning the spray arm with a soft brush. The water temperature plays a major role in cleaning of dishes. The temp should be between 125 and 150 F for dishwasher to clean the dishes. Hope this helps...
Feb 09, 2011 | Bosch Dishwashers
My 4 1/2 year old Bosch dishwasher won't clean.
this tells me that you have a drainage problem chk. the hose for kinks and or plugs
Aug 23, 2009 | Bosch 24 in. SHU5305UC Built-in Dishwasher
Dishwasher Soap scum left on dishes
the problem is hard water. There is a new product out called The Dishwasher Filtration System. It filters the water going into your dishwasher leaving your dishes spot free with every load. It is very affordable and fits right under the sink. You will be amazed how sparkling your dishes look just after one load. You will love this product. Get it at www.dishwasherfilter.com.
Nov 01, 2008 | Bosch 24 in. SHU53 Built-in Dishwasher
Film on dishes and inside dishwasher
Hi debstone
This is a common problem. what you should do first is pick up some GLISTEN and run it through on a full wash with NO dishes. the use electasol POWDER detergent and turn your jet dry down to 1. that should fix your problem. hope this helped
brent
Aug 01, 2008 | Bosch 24 in. SHU43 Built-in Dishwasher
Dishes are not clean due to insufficient water. Arms are clean, strainer is clean, water supply is OK,some soap is still in opened dispenser
Disassembled solenoid, found plugged inline strainer (caused by water shut-down in building to replace recirc. pump) Pulled and flushed filter basket, problem solved. Solenoid must be removed to access filter which is in sol. body. I hope this can help anyone who does'nt have a tech manual or flow diagram.
Mar 29, 2008 | Bosch 24 in. SHU66C05 Stainless Steel...
Bosch Dishwasher
you have a 3 year warranty on bosch dishwashers
Jan 01, 2008 | Bosch 24 in. SHU43 Built-in Dishwasher
Bosch Dishwasher Glass Rack Insert SGZ2004UC Logo
104 people viewed this question
Top Bosch Dishwashers Experts
Gerry Harvey
Gerry Harvey
shaun taylor
Are you a Bosch Dishwasher Expert? Answer questions, earn points and help others
