Question about Onkyo Audio Players & Recorders
Onkyo TX NR525 is dead
I bought this AV receiver Onkyo Tx NR 525 just 3 months back form USA and took that to India. During playing the receiver it gets very hot. Suddenly without any reason it went off while playing a movie. I live at India and there is no service center of Onkyo here in India. Finding no other way I sent that to Onkyo service center, Singapore and got that back after a month. It was running well and today again the same problem, suddenly it went off and making a repeated "click" kind of sound inside the receiver. It is time consuming and costly for me to again send it to Singapore and repair. Totally frustrating performance by Onkyo,can anyone give a service manual of onkyo so that I can repair in here? Thanks
SOURCE: Onkyo TX-8522 stuck on standby
This is Not a real Fix, However it stops the problem!
Do not plug any power cords into the Receiver.  I have found that using the "switched or unswitched" plugs in the back cause the trouble.
Posted on May 12, 2008
SOURCE: Onkyo receiver audio problem
I have Found two problem which cause NO AUDIO 27-07-08
  1. 1.Failed connection between top &bottom of circuit board NCDG-6575 (Dolby --DTS) processing board.
Near & under IC Q710
2.Failed componet IC Q710 part # LC372100PT
IF you disconnet CKT board NCDG-6575
you will get audio on speaker B left & right CH only
SOLUTION have CKT board NCDG-6575 Repaired or REPLACED
Posted on Jul 28, 2008
  • 3 Answers
SOURCE: Onkyo - direct tv code for tx-ds 787
does anyone knows the code to control the onkyo TXDS 787 through the comcast.remote.?
Posted on Aug 21, 2008
  • 17 Answers
SOURCE: My Onkyo tx-sr606 7.1 receiver turns off by itself
hi, when the unit shuts off by itself, it means that the protection circuity inside has been activated. it can be a problem with the receiver itself or it is just detecting something hooked up to it that can cause possible damage so it shuts off.
you would need to disconnect everything from the back and by itself, try to turn it on, see if it will stay on and then crank the volume way up to max. if it stays on, the receiver is ok and you then need to rehook your devices one by one starting with the speakers until you determine the one causing the receiver to shut off.
however, if the receiver shuts off and won't turn on even by itself, it means that the problem is internal and it either has to go back to your dealer for an exchange or it has to be sent to a repair center for servicing.
hope this helps a bit.. ^_^
Posted on Mar 09, 2009
  • 35 Answers
SOURCE: Onkyo TX-SR705 shuts down suddenly
Onkyo receivers have a safety circuit in them to protect the Amplifier from blowing up:
If you listen closely when it shuts down ( after a loud scene ) there is likely a loud 'Relay Click'..
If this is what is happening you might be able to verify it by turning the volume all the way 'off' and waiting for the circuit ro reset ( releasing the safety relays & returning power to the internal Amplifier ) : you should hear another click, yhen you can bring the volume back up carefully and there will be sound again.
This safety circuit trips when then Onkyo receiver detects an 'Over Current' condition on the
' Power Supply ' that feeds the internal 'Audio Amplifier'..
Generally caused by:
Improper load presented to the Amp outputs ( FL, LR, RL, RR, SUB, CENTER )
If you can ( one at a time ) turn off the SUB, Center, Fronts and Rears: trying to re-create the failure each time while you have one part of your system disabled or having their level turned way down..
You can isolate where the problem is coming from.
- any or all of these speakers being the wrong Impedence ( I.E. 4 Ohms instead of 8 Ohms )
Unless the receiver manual or the sticker near the 'speaker connetor' specifies a range or another value, you should assume 8 Ohms. Your speakers should say on the back of them.
- any of the speakers being connected in parallel ( 2 speakers to a single one speaker output ) .. Two 8 Ohm speakers connected in parallel make a 4 Ohm load to the amplifier.
- If the Suwoofer is Passive ( Not having its own power cord and amplifer ) it has a
Passive Crossover : this crossover can have its own power rating or limitation.. If it is constructed with capacitors that have too low of a working voltage, then they can saturate and the crossover itself can present a load to the amplifier that will case this 'Over Current Shut-Down'..
You user manual should detail this.
Posted on Apr 09, 2009
Onkyo tx nr656 showing. NR:LCRSLSRBLBR, Any idea. Not working at all.
Hello, I am sorry about your issue. The receiver may have detected a problem with a speaker or speaker wire. Please contact Onkyo at 800-229-1687 option #3 so that we can troubleshoot with you. Thank you, Onkyo USA
May 13, 2017 | Onkyo Audio Players & Recorders
How do you connect the skw 360 subwoofer to the onkyo tx-sr505 av receiver
Hi Kenny, sorry you can't. The TX=SR505 requires a powered subwoofer. The SKW-360 is passive. Thank you, Onkyo USA
Dec 02, 2016 | Onkyo Audio Players & Recorders
My Onkyo TX-NR838 switches off when I turn the tv off. I can't switch the receiver back on for 2 days
sounds like a faulty cable or psu .... or some bad solders on the back of a scart socket if you use scart
if not its something to do with TV detection the TX-NR unit uses
Dec 04, 2014 | Onkyo 7.2 Channel Network A/V Receiver -...
I owned an onkyo tx-nr 414 ,i bought it in al danah mall dammam last one and half year ago and one day the the "NO STORAGE" came to the front screen of the display.
Hello, I am sorry about your issue. Have you tried changing sources after you plug it in. It sounds like you are in USB. Please try bd/dvd or cbl/sat. Thank you. Onkyo USA
Jun 13, 2017 | Onkyo Audio Players & Recorders
I would like to connect onkyo TX-DS474 to my television to play the television sound thru the receiver
you will need a Analog audio cable (RCA) connect one end to Game/TV on the back of the onkyo and the other end to the TV audio out then just press the game button on the front of the onkyo you my have to go into the menu on the av to set the Analog out-put for game/
Oct 16, 2011 | Onkyo TX-DS474 Receiver
Amp always entering protection mode/ on and off it self
Hello, I am sorry about your issue. I f the receiver does not stay on with nothing connected it would need to be serviced. Thank you, Onkyo USA
May 26, 2017 | Onkyo TX-DS787 Receiver
141 people viewed this question
Top Onkyo Audio Players & Recorders Experts
Are you an Onkyo Audio Player and Recorder Expert? Answer questions, earn points and help others
