Question about Hobart Dishwashers
Purchased a used Hobart XL30 dishwasher on Craig's list (silly me) I need help?
Plugged it in, hooked it up and it reaches temp of 160, but doesn't say READY or WASH. Replaced circuit breaker to 30 AMP, checked hoses and spin arms. Any suggestions?
SOURCE: Kenmore Ultra Wash Dishwasher
Thank you Catriver! You were in the zone! It's working like new! Many thanks!
Posted on Apr 02, 2007
SOURCE: Bosch Dishwasher SHV4303UC - Does not drain.
Try looking for slithers of glass etc under the impeller. Remove the sump covers (filters) and look into the bottom. There will probably be a small cover held down by a screw. Under this is the impeller. Roll up a hand towel into a cigarette shape and slide this under the impeller - that should clear anything out.
Posted on Apr 17, 2008
SOURCE: dishwasher is "tripping" the breaker & not draining.
I had the same problem with a Hobart AM8 passthru dishwasher. The electrician determined that some of the wires had become exposed and were wet, thus shorting things out and tripping the breaker.
Posted on Jan 09, 2009
SOURCE: Dishwasher tripped our main circuit breaker.
It may be that your water pump is leaking on to the motor...
Posted on Dec 09, 2009
  • 110 Answers
SOURCE: Hobart SR24H dishwasher will not spray, arm does not rotate
ck. flow press. of water , when fill solenoid opens press. should be @20 p.s.i because this is a time fill machine. this is important .not static press. flow press. also ck the screened washers in the fill hose to see if they are plugged .let me know what you find so i can futher assist. dont forget to vote tks
Posted on Jan 11, 2010
Hobart ml 130017
There is a temp booster on that unit. A rinse temp of 190 is not out of the range of specifications. If it is too hot, you should adjust the incoming water temp
May 30, 2013 | Dishwashers
I have a am-14 hobart washer. having problem with rinse temp indicator. it is fine for the wash then the temp gauge is jumping around, could it be the thermostat?
Your rinse temperature sensor that is a tiny probe in the water piping (top rear of machine) needs replaced. Hobart part # 00-294692. It costs about $84.
Oct 19, 2012 | Hobart Dishwasher Am-14 Commercial Dish...
Set-up for portable DVD player by Craig cmd420
Hello
[1] Insert the batteries into the Craig DVD player. Depending on the model you are using, the batteries are either rechargeable lithium-ion batteries or store-purchased AA batteries.
[2] Plug the 3.5mm cable into the headphone jack on the side of the Craig DVD player
[3] Insert the opposite end of the cable into the "Aux" connection on the car stereo. Without this audio-input option, you will be unable to hook the Craig DVD player up to your vehicle.
[4] Power on the Craig DVD player and insert the desired DVD. The video will load onto the display screen while the audio is played through the car's stereo system.
[3]
Oct 18, 2011 | Craig 731398407019 Portable DVD Player
I just purchased a used Electrolux 24" EDW5500DSS
Hello, joe
I was trying to help you out here. I was going back to some customers that asked questions in the past and it appeared that no one answered them, so I thought I would take some of my personal time to see if I can help. Even though this site may not have your exact model or brand, This link will help you tons. Here is a link to about everything you want to know about your dishwasher, from repair to trouble shooting it,pictures, video's. Just scroll around and you will see tons of information to almost any question you might have on your dishwasher. If you go to this link and click around, I am sure you will find out so much about your dishwasher, you will know more that the company that made it. Here Is the link for you to click on>>
http://home.howstuffworks.com/dishwasher.htm
Please if this helped you at all, if you can find the time to rate my help and some kind words written would be appreciated for my free help , I would appreciate it. Here is also my direct link to my own pages of other areas of my expertise for other problems you might have in Automotive,Appliance, and Electronics. Drop In anytime for my help. Thanks,Mike
http://beta.fixya.com/users/mc1bean
Sep 30, 2011 | Electrolux 24 in. EDW5500DSS Stainless...
Just purchased a used LXIh4 temp on diplay only goes to 155F
The incoming water determines how fast the DW is ready for another cycle. For running continuous cycles, the incoming water will need to be 140 degrees. If you pause 2 minutes between cycles, the temp should remain consistent with a 120 degree supply.
Jun 16, 2009 | Hobart 25 in. LXIH-4 Built-in Dishwasher
Looking for a hobart amx dishwasher wiring diagram from 3 phase converting to single phase
sr. we are using Hobart dish /w but not working this properly .when i start d/w display red light coming but not green light also heater working water coming can you help me
Jun 04, 2009 | Hobart Dishwashers
Need to hook up the small pipes for sanitazing agent
The other pipe is for detergent.Any other questions let me know i'm a hobart tech.
Apr 12, 2009 | Hobart 24 in. LXIH-3 Built-in Dishwasher
Temperature Problem
Whats the model?lxih,lx30h,lx18,lx40?What temps are low,wash or rinse?Im a hobart tech and service these units.Let me know.
Jan 19, 2009 | Hobart 24 in. LXIC-5 Built-in Dishwasher
Tank temp
check to see if your element is scaled up or your element may be damaged
Nov 21, 2008 | Hobart AM15T Dishwasher
Dishwashers Logo
Top Hobart Dishwashers Experts
Jason
Garth Jackson
Are you a Hobart Dishwasher Expert? Answer questions, earn points and help others
