Question about Thermaltake Liquid Cooling System Bigwater UV Sensitive Coolant - liquid cooling system fluid (S7430417)
Why is 2011 chevy aveo lt profusely leaking coolant
Over the past 6 months smeeling antifreeze, now leaking prfousely; resevoir is not cracked. was told it was the themostat.
  • NCC-1701-D May 16, 2014
    Hi tris grant, I want to help you with your problem, but I need more information from you. Can you please add details in the comment box?
    New Friend:
  • 127 Answers
Because Its A Piece Of Junk! If I Where You I Would Buy A Kia Sedona Wich Is A Mini Van!
Posted on May 16, 2014
I have a 2011 Chevrolet impala and my coolant in the reservoir is evaporating within a months time of being filled. What could be the problem? Water pump?
Start with a "professional" coolant system flush. Sounds like there's a blockage somewhere. If you're putting coolant in the resevoir and not directly in the radiator, and it's disapearing, check the radiator. If radiator is full it's a blockage, if it's low/empty there's a leak.
Feb 27, 2015 | 2011 Chevrolet Impala
Why would a 2007 chevy aveo radiatour be leaking when no accidents or over heating had occured ?
Small rock..stick...just crack..pot hole hits can even cause bad vibration that can crack a aging radiator..
Aug 19, 2014 | 2007 Chevrolet Aveo5
Coolant leaking from 2011 chevy aveo
Stop using it & have it repaired
May 16, 2014 | 1999 Oldsmobile Alero
Coolant leak
have a coolant pressure system test done. have a compression test done to check for head gasket problems or cracked head. have the radiator cap tested for correct operation.
Aug 03, 2013 | 2011 Chevrolet Aveo 1.4
2006 Aveo with antifreeze leak
put it in resovour if theres no cap
May 12, 2013 | 2006 Chevrolet Aveo
I just need the steps in putting new coolant in a 2006 chevy cobalt LT do i need to purge any thing or what?
Your owners manual should have step-by-step instructions. If that is not available this is what I would do: With the engine "overnight cold", that is to say after sitting all night, locate the coolant resevoir (forgive my speeling please), you will notice on the side of the resevoir notches telling you where the level should be when, cold fill the resevior to this level, if you over fill it don't worry. Never put coolant in a radiator with a hot engine you can crack the engine block, and/or burn yourself badly, also make sure you use not only the proper coolant but a good quality one as well.
I hope this has helped you. :-)
Jul 30, 2011 | 2006 Chevrolet Cobalt
Leak of antifreeze coming from somewhere, can't see it from above. Not leaking profusely, but still leaking a day later.
The easiest way to find a coolant leak, is to take it to
your mechanic and have him/her do a pressure test
on it.(5 min) The way coolant can run across the engine and engine compartment means the fluid on the ground may not even be close to the leak.
Under pressure the leak will show itself more clearly.
Hope this helps.
Feb 28, 2010 | 1998 Chevrolet Cavalier
2004 Freelander Coolant Leak
check the reserviour bottle itself underneath for any cracks cause I had a taurus once looked all over for antifreeze leaks and I found it by putting a pressure tester on it
Jan 22, 2009 | 2000 Honda Civic
Chevy tahoe 2002 low coolant light is on. where do you add it
Chevy as most GM cars usually needs Dex-cool antefreeze
But Peak is OK as it can be used to top-off any color of automotive antifreeze including green, yellow, orange, fuschia, blue and red
More info here
http://www.peakantifreeze.com/peak_global_lifetime_5050.html
Also check the system for leaks. If you need to add coolant at least once a month there is a leak.
Good Luck
Jan 18, 2009 | 2002 Chevrolet Tahoe
Thermaltake Liquid Cooling System Bigwater UV Sensitive Coolant - liquid cooling system fluid (S7430417) Logo
46 people viewed this question
Top Thermaltake Computers & Internet Experts
Martin Clarke
Martin Clarke
Lawrence Oravetz
Are you a Thermaltake Computer and Internet Expert? Answer questions, earn points and help others
