Question about Kenmore 500 6952 Dryer
Why did my dryer gradually quit heating up - Kenmore 500 6952 Dryer
  • NCC-1701-D May 16, 2014
    Hi Kimberly McFadyen, I want to help you with your problem, but I need more information from you. Can you please add details in the comment box?
Kenmore HE5 Dryer.Can the heating element go out quickly or is it gradual?
It works or it doesn't if you have gradual loss check your vents
Jun 25, 2015 | Kenmore Dryers
My dryer (FER341AC) gradually quit heating. FIrst it only worked on timed dry now it wont heat at all. What could be the problem?
If you are having problems with your gas dryer not heating the most common problem is that the ignitor goes bad. Even though it glows sometimes it is still not working properly.
if you dryer is gas check out this gas no heat tip....
If you have an electric dryer, you can have many different things that can go wrong causing the dryer not to heat.
check out this electric no heat tip...
heatman101
Feb 15, 2011 | Frigidaire Dryers
Dryer is gradually stopped heating and drying
heatman101
=00
Jan 18, 2011 | Maytag Neptune MDE5500AY Electric Dryer
GE DBSR453GB Gas Dryer doesn't dry on 1st cycle.
Hi, If you have a gas dryer2_bing.gif.
The most common problem with a gas and no heat is the ignitor going bad...
Here is a tip that I wrote about that problem...
Gas Dryer2_bing.gif not Working Gas Dryer2_bing.gif Not Heating
http://www.fixya.com/support/r4398592-gas_dryer_not_working_gas_dryer_not
If your dryer2_bing.gif is electric2_bing.gif..
There could be a number of different problems...
Check out this tip that I wrote about this problem...
Dryer2_bing.gif Troubleshooting2_bing.gif Electric2_bing.gif Dryer2_bing.gif won t Heat
http://www.fixya.com/support/r3866345-dryer_troubleshooting_electric_dryer_won
heatman101
May 30, 2010 | GE DBSR453GB Gas Dryer
The dryer is hot to the touch inside the drum
two issues the heat thermal relay or the fan motor quit working you can go to www.appliancepros.com and look up the parts list for your model.
Apr 14, 2010 | Amana DLE330RAW Electric Dryer
1 year old Kenmore dryer tumbles but doesn't heat.
If it is 1 year old, call Kenmore , they will probably fix it as a courtesy call.
If not quote that the machine is not fit for purpose as it should not have gone wrong so quick
Sep 24, 2009 | Kenmore Dryers
Can't get any heat
If it's been gradually getting worse, it sounds like the heating element needs to be replaced. Electric dryers will be have this way when the element is wearing out. Gas dryers will do this when the burner becomes clogged.
Jul 11, 2009 | Dryers
The Dryer heats up at first---blows hot air through the exchange outside and then gets gradually cooler as the dryer runs......
Hi, If this is a gas dryer, there is a good chance the coils on top of the gas valve are going bad. They will over heat late in cycle and will not open the valve.
Please let me know if this helps or if I can assist you further.
Vic
Jul 02, 2009 | Maytag Neptune MDE5500AY Electric Dryer
Dryer has no heat
either your heating element or your thermostats are bad. on the heating element casing there are two thermostats. check the top one for continueity if it doesn't have continueity the change both thermostats. if they are good then check your heating element for continueity. after you get your dryer heating then clean out your vent system... if it's not venting properly then your dryer will take a long time to dry.
Jun 16, 2009 | Frigidaire Dryers
Gas Dryer quit heating today
Just click below;
If your dryer doesn't heat, check these:
Igniter
Gas valve coils
Thermal fuse
Hope it may help you;
Regards;
VOTIT
Jan 28, 2009 | Whirlpool LGR8648 Gas Dryer
Kenmore 500 6952 Dryer Logo
Top Kenmore Dryers Experts
Dan Webster
Dan Webster
Sal DeAngelo
Tim Whalen
Are you a Kenmore Dryer Expert? Answer questions, earn points and help others
