Question about Sta Rite Sta-Rite Max-E-Therm High Effiency - Propane Heater - 333,000 BTU
How to change a thermal regulator in sta rite heater
3 Suggested Answers
  • 246 Answers
SOURCE: sta rite heater won't start
TURN THE BREAKERS OFF FO R 20 SEC IF PROBLEMS PERSIST SEE CODE A POST
Posted on Dec 07, 2009
  • 990 Answers
SOURCE: Sta-rite pool heater shuts down as soon as the
Between the two water pipes on the left side of the manifold is a two inch plug. When you take this plug out the thermal regulator assembly will come with it.It consists of "O" rings, a spring and what looks like a thermostat in a car. This is the probal bad part although it could be the spring also. You can get these parts seperatly or in a kit. If this is an older heater the kit is the way to go so you get all the nessary "O" rings and you will be covered on everything you need.
Posted on Dec 08, 2009
I have a sta rite 200 gas pool heater. Heater ignites and runs for about 1 minute and shuts off. After another minute it restarts.
Try removing the Thermal regulator. also make sure you have adequate water flow thru the heater. If the heater seems to run OK with the Thermal Reg removed then order a new one.
Pentair / Sta-Rite 77707-0010 Thermal Regulator Kit for MasterTemp / Max-E-Therm
Jul 16, 2016 | Sta Rite Pool & Spa
Heater won't stay lit
could be caused by many things. could be an flame sensor error, open saftey switch, stack flue error, etc look on back of circuit board and tell me what errors are lit up
Mar 08, 2014 | Sta Rite Sta-Rite Max-E-Therm High...
My heater star and works fine for about 5 to 7 minutes and shut off and said r-6 the service light in on now
You have a bad thermal regulator. It is located in the inlet/outlet header. It looks just like a car thermostat.
Oct 15, 2013 | Sta Rite Sta-Rite Max-E-Therm High...
Heater fires runs for 2min.service heater lite comes on has code 8 shuts down
This issue sounds tricky. I recommend you callthe Sta Rite technical support at 888-782-7483 and they should be able to helpyou figure this issue out.
I hope this helps.
Sep 12, 2011 | Sta Rite Sta-Rite Max-E-Therm High...
Oct 16, 2009 | Sta Rite Maxi Therm 400k Btu Propane...
Sta-rite pool heater SR333LP
This heater has a thermal regulator and a high limit that could be the problems. If it were a high limit that was bad, the display would show the error when the heater goes off. In the absence of an error, one would look to the regulator. A bad regulator would cause the water flow to bypass the exchanger and cause a slow heat. The part is easily replaced and runs about $90. It sort of looks like a car thermostat and also has a spring. It is accessed by removing the large black plug near the plumbing inlet/outlet.
Dec 16, 2008 | Sta Rite Sta-Rite Max-E-Therm High...
Sta Rite Sta-Rite Max-E-Therm High Effiency - Propane Heater - 333,000 BTU Logo
114 people viewed this question
Top Sta Rite Pool & Spa Experts
Jay Finke
Jay Finke
Oloyede Monsuru
john h
Are you a Sta Rite Pool and Spa Expert? Answer questions, earn points and help others
