Question about Cell Phones
I accidentally removed the navigation dvd in my Toyota Sienna. now my screen is frozen. Says no data available. is there a way to reset it?
    Scholar:
  • 73 Answers
First, take a look at the dvd on another device and make sure you didn't erase the data. If something is there it will (most likely) be in a map type of extension for the file. If there is data then I'd try to reestablish communication by inserting the disk then remove the fuse that powers that system. Let it set without power for at least an hour then re-power by replacing the fuse and power the system back up using the key in the 'on' position. If this doesn't work contact your local Toyota service rep., this can't be the first time this has happened...Good luck!
Posted on May 16, 2014
Overhead DVD player in 2008 Toyota Sienna does not show the picture. Sound works.
Hello, I hope this helps. If no change then you probably have a hardware/ wiring issue and the dvd player may need to come out. Please advise
1. Confirm the DVD RSE system is inoperative. (blank screen) 2. For vehicles with Toyota navigation system: Perform the following procedure to turn OFF the RSE Lock function. A. Press the INFO switch on the navigation unit. B. Press the "Screen Setting" touch button on the navigation display. C. Under the "Rear Lock" option, press the "OFF" touch button and then press "OK" in the upper right part of the display. D. Press the DVD switch on the RSE system (if a DVD is NOT already in the player, insert one) and confirm screen is ON and the system will play DVDs. 3. For vehicles without Toyota navigation system: Perform the following procedure to turn OFF the RSE Lock function. A. Push the Audio Control knob multiple times to cycle through the various options (Bass, Mid, Treble, etc.) until "REAR LOCK" is shown on the screen. B. Turn the Audio Control knob so the display says "OFF" next to "REAR LOCK". C. Press the DVD switch on the RSE (if a DVD is NOT already in the player, insert one) and confirm screen is ON and the system will play DVDs. 4. If the above procedure resolves the concern, explain the system operation to the customer.This procedure is described in the Audio/Video" section of the vehicle Owner's Manual. 5. If the above procedure does NOT resolve the concern, perform RSE diagnosis using the Technical Information System (TIS), 2006 model year applicable vehicle Repair Manual.
Jun 29, 2015 | 2008 Toyota Sienna
Hot to reset password dvd toyota sienna
Is this a stock unit? If so the codes are only available through a dealer. And may cost up to $200.
If it is after market a search on the model number will help you find a manual.
Aug 06, 2014 | Televison & Video
2006 Sienna battery went dead. After charging, navigation and radio don't work. Screen works and says "NO MAP DVD - Insert Disc" Checked Radio fuses 1,2 and 3 are good, as well as 12v...
System memory may have been erased/lost due to extended loss of power. System may have to be reprogrammed to effectively work. Do you have the programming CD? If so, check owners manual for programming procedures
Sep 20, 2011 | 2006 Toyota Sienna
I am getting Power (fuses ok) to my Radio and Navigation on my 2006 Sienna but the power button will not work so no sound or Navigation screen? What could be wrong? Thanks
Check to make sure all fuse associate to the radio/navigation is good, sometime like the acc socket fuse being blown could cause the thing to not work also, so make sure you get to all the fuse to make sure they are not blown. After that, there maybe a fuse located with the navigation unit behind the radio/navigation unit that may be blown. If there isn't or is still good, check all connection to it. If all is good then your unit could be history and you may need to take it to a dealship to actaully see what is going on.
Jan 30, 2011 | 2006 Toyota Sienna
Navigation system wont work
You will have to buy a new navigation unit @ about $2,000. I have a 2006 Sienna XLE Limited with Navi. Mine broke by having no display, had a clicking noise, and the lights would come on and off about every 5 seconds. www.radiomedics.com told me they found the problem with the toyota navigation units (they had seen a lot of them) and could fix them for around $300 if Denso (the co. who makes the units) would sell them the part. But Denso will not sell the part so we are forced to buy a used unit (who knows how long that will last) or new. Toyota reliability, yeah right.
Nov 17, 2010 | 2006 Toyota Sienna
I have a 2005 Toyota Sienna. Recently I lost the
All of those are tied into the same fuses or they are tied in somewhere under the dash, You can get a fuse tester for a couple of dollars if you dont have a meter to see if th fuses are good you should be able to pull the fuses and see if they are bad. Dont forget when you check the fuses in the car, make sure and check the fuses and the relays in the fuse box under the hood.
Apr 11, 2010 | 2008 Toyota Sienna
Toyota sienna 2004 rear seats
I have had a similar problem on my 2004 Siena 2 times - strap you pull to release the seat has no tension. Dealer fixed under war both times (I watched the second time). If your problem is the same, the cable that controls the release may not be in position. As I recall, you remove about six screws, remove the plastic housing, find the cable and reset then test the release.
Apr 23, 2009 | 2004 Toyota Sienna
I do not have a sound .
put ur fm radio to channel 88.3
Dec 07, 2008 | 2004 Toyota Sienna
Sanyo nvm 4050 problem
I ended up in the same situation and called (800) 421-5013 for help. The gentelman who assisted me said that how the DVD holds the same data as factory Sanyo 4050 GPS and upgrading has locked your device. To resolve the discussed issue one have to delete everything (plug-in your device via USB cable --> My Computer --> Removable disk) and install fresh copy onto your navigation device via that DVD.
Tried it with NO @!@ JOY
Nov 16, 2008 | Sanyo NVM-4050 GPS Receiver
Cell Phones Logo
32 people viewed this question
Top Cell Phones Experts
Computer Repairing
Computer Repairing
William Alequin
Are you a Cell Phone Expert? Answer questions, earn points and help others
