Question about HP Photosmart C4580 All-in-One InkJet Printer
HP J4680 says "printing" but doesn't print
Printer was working fine one day, now displays "printing" forever without printing. Only scanner works. Won't copy either. Does move paper.
  • 85 Answers
Turn it off and pull the plug. Now turn it on and off twice. Now plug it back in and try it.
Posted on May 16, 2014
Printerguy
  • 31 Answers
SOURCE: HP LaserJet 2420dn prints twice
You may have checked this already, but make sure your printer driver is not set up to print two copies per print job if it is then that's the easiest place to change settings. Or you can print out your printer's menu by doing the following: To print a menu map 1. Press (SELECT button) to open the menus. 2. Use (UP button) or (DOWN button) to scroll to INFORMATION, and then press (SELECT button). 3. Use (UP button) or (DOWN button) to scroll to PRINT MENU MAP, and then press (SELECT button) Look for anything that says "copies" and usually that will let you know what is set on the printer. To change a control-panel setting 1. Press MENU to open the menus. 2. Use (UP button) or (DOWN button) to scroll to the menu that you want, and then press (SELECT button). 3. Some menus might have several submenus. Use (UP button) or (DOWN button) to scroll to the submenu item that you want, and then press (SELECT button). 4. Use (UP button) or (DOWN button) to scroll to the setting, and then press (SELECT button). Some settings change rapidly if (UP button) or (DOWN button) is held down. An asterisk (*) appears next to the selection on the display, indicating that it is now the default. 5. Press MENU to exit the menu Good Luck.
Posted on Aug 24, 2007
SOURCE: HP 1320 duplex printing paper jam
Managed to solve this myself: I disassembled the printer and noticed there was a paper jammed in the duplex tray. Rolls were all ok, but the paper blocked the use of the duplex pathway. For disassembly help check the HP 1320 service manual, which you can find on the net as a PDF.
Posted on Jul 15, 2008
mspcrepair
  • 169 Answers
SOURCE: hp psc 1350 all-in-one
Source: HP support
( Click link above to read complete article and instructions )
Introduction A full feature software and driver package for Windows Vista is not available for your product. However, the Windows Vista operating system installed on your computer contains a basic driver solution for your product. With the basic driver, the buttons on the product do not function and some of the advanced product features are not available. But you can still print, scan, and import and view images on a memory card, using the workaround procedures in this document. Use the following instructions to install the basic driver in Windows Vista, and then review the workaround procedures to use the available features for your product. Installing the printer driver When you connect the product to the computer, Windows Vista detects the hardware and automatically installs the correct driver. A notification lets you know when installation begins and when it is complete. You do not have to download any software or insert the product CD.
  1. Turn the product on.
  2. Connect the Universal Serial Bus (USB) cable to the printer and to the computer.
  3. A Your devices are ready to use window might display on the screen. If the window displays and does not close automatically, close the window.
Workaround procedures The basic driver in Windows Vista is sufficient for several functions. You can print from a software program, scan documents, and import and view images on a memory card. Printing Use these steps to print from a software program.
  1. Open the document to be printed in the software application in which it was created.
  2. Click File , and then click Print .
Scanning Use one of the following three methods to scan a document. Method one: Scanning with Windows Photo Gallery
  1. Click the Windows (c01367391.gif ) icon.
Posted on Oct 06, 2008
nalin_elliot
  • 224 Answers
SOURCE: Suddenly cannot scan with HP J4680 All in one
Issue When using the Scan To function on the control panel of a USB-connected product, ' No Scan Options: Refer to device documentation to troubleshoot ' appears on the control panel display.
NOTE: Follow these steps in the order presented to resolve the issue. It is not necessary to continue to further steps once the issue is resolved. Solution one: Make sure that the Digital Imaging Monitor is ready The Digital Imaging Monitor must be running in order for the Scan To function to work. If it is running, the DIM icon (c01404188.gif ) is present in the notification area. The notification area is located in the lower-right corner of the computer by the clock. Figure 1: Notification area c01404189.gifIf the DIM icon is in the system tray, you do not need to complete this procedure. Skip to the next solution. Follow these steps to set the computer to run the DIM.
  1. On the Windows taskbar, click the Windows icon (c01364735.gif ).
  2. In the Start Search text box, type msconfig , and then press Enter .
  3. On the User Account Control window, click Continue . The System Configuration Utility window appears.
  4. Click the Startup tab.
  5. Select the HP Digital Imaging Monitor check box. If HP Digital Imaging Monitor is not on the list, the driver was not correctly installed or a custom install was used. Reinstall the software to resolve this issue.
  6. Click Apply , and then click Close .
  7. Click Yes to restart the computer.
  8. Attempt the scan again.
Solution two: Populate the destination list You must populate the destination list in HP Solution Center for the Scan To function to work. Follow these steps to populate the destination list.
NOTE: HP Solution Center is the software that came with the product. You must make sure the software is installed on the computer for all the product functions to work correctly. The software is also necessary for completing this procedure. Install HP Solution Center if it is not already installed.
  1. On the Windows taskbar, click the Windows icon (c01364735.gif ), click All Programs , click HP , and then click HP Solution Center . HP Solution Center opens.
  2. Click Scan Settings .
  3. Click Scan to... Setup .
    NOTE: It might take several minutes for the list to populate. If the appropriate programs are already listed as scan destinations, discontinue this procedure. You must reinstall the software.
  4. Click each program to include on the Scan To Destination list. Figure 2: Add destinations c01404190.gif
  5. Click the Add arrow. The program listing moves from the left side of the screen to the right.
  6. Click OK .
  7. Attempt the scan again. Try to scan from Solution Center if scanning from the control panel is unsuccessful.
Now you should be able to scan from the printer
Posted on Jun 24, 2009
Testimonial: "Great answer!"
SOURCE: When I give print it pick up paper and out the
hi
your printer is A4 Size printer it will not print A3 size
if you fill to print A3 go to HP site and support page find your solution
Posted on Jul 29, 2010
Fails to print after paper jam fix
If you are still seeking assistance with your Officejet J4680 printer rosemarie gogarty I would be happy to help. Have you tried a hard reset? To do so, leave the printer on and unplug the power cable for 1 minute. While it is unplugged, hold down the power button on the printer for 10-15 seconds to release any built up power, then after the minute has passed, plug the printer back in.
If the issue persists, let me know, I will happily do all I can to help,
Thanks,
I work on behalf of HP.
Jun 02, 2015 | HP Officejet J4680 All-in-one Printer...
HP J4680 says "printing" but won't print
just check it weather it is detecting your pc or laptop. if it is detecting check it is scanning working fine or not, if it is scanning fine you need to update firmware and check it. still getting same issue you need to replace the main pca board.
May 16, 2014 | HP J4680 Office Jet All-In-One Printer
My J4680 only prints color, no black. Printer is
Your black cartridge is most definitely clogged. You can easily check that by removing the cartridge and press the print head on some tissue. If there is no mark, the print head on your black cartridge is clogged. Now, HP has some kind of software head cleaning. It doesn't always work, but you can try. Here is a link to HP site, referring to your problem: http://h10025.www1.hp.com/ewfrf/wc/document?docname=c01361894&cc=bg&lc=en&dlc=en&product=3692888
Read carefully and follow the instructions.
If that doesn't solve your problem, you should buy a new black cartridge.
Also, bear in mind that with ink-jet printers, you need to print something at least once in 10-15 days, otherwise the print head will again get clogged and you will be facing the same issue over and over again. If you do not print on a regular basis, make some kind of test page, that contains black, yellow, magenta and cyan. Print that page once in 2 weeks and your printer will always work fine.
Apr 04, 2010 | HP J4680 Office Jet All-In-One Printer
HP J4680 Printer worked fine then suddenly stopped.
Generally a reset or, unplug and re-plug in can clear the problem..
Jan 31, 2010 | HP J4680 Office Jet All-In-One Printer
Hp j4680 says "paper jam"
Try this. Sometimes you get that message because a previous jam was never fully fixed.
Sep 29, 2009 | HP J4680 Office Jet All-In-One Printer
It stopped printing, with
Try cleaning the cartridges after turing the printer off then try again.
Sep 08, 2009 | HP J4680 Office Jet All-In-One Printer
My HP J4680 printer/fax machine keeps displaying the error message "Print Cartridge Problem Tri-color". I have taken the cartridges out and put them back in to see if this will work. It did once and I went...
Try this...http://h10025.www1.hp.com/ewfrf/wc/document?docname=c01443507&cc=us&lc=en&dlc=en&product=3692888The message you're getting is a little different, but cleaning the cartridges and the contacts inside the printer might help and might explain why it worked when you pulled them out and put them back in once before.
Jun 08, 2009 | HP J4680 Office Jet All-In-One Printer
Trying to install HP J4680 AIO printer and installation fails at
jim it is ur printer driver problem because ur software is damage u need to download the driver from net. or purchase a new driver.
Mar 24, 2009 | HP J4680 Office Jet All-In-One Printer
I have just got a new HP wireless printer, i have vista on my laptop and even though it said installation was complete it says error when i try and print and says printer offline. its a hp j4680
I had a similar problem,and after spending several hours on the phone with an HP tech yesterday, reinstalling the drivers over and over, we ended up manually creating a port with the printers IP address. Under "printers," right click on the 4680. Go to "properties," the "ports." We added a port, and named it the IP address. Then I could print. I STILL CANNOT SCAN, however!
I also have Vista.
Mar 20, 2009 | HP J4680 Office Jet All-In-One Printer
Scanner problem of hp laserjet 3030 all in one
Try unplugging the cord to the printer and wait a few seconds and re-plug the cord again , print what ya have to print again/hope this helps .
Dec 01, 2007 | HP ScanJet 3200C Flatbed Scanner
HP Photosmart C4580 All-in-One InkJet Printer Logo
Seeker5211
Seeker5211
