Question about Sears Craftsman LiftMaster Chamberlain Garage Door Opener Wireless Keypad Model 976LM Security+
Why does garage door opener only move a few inches?
Garage door opener will only move a few inches back and forth even with the door disconnected from the rail. I already replaced the sensors and checked the switches on the rail.
    New Friend:
    Welcome Back:
    Visited the website for 2 consecutive days.
  • 16 Answers
Dealing with a garage door opener that doesn't open all the way sounds a bit frustrating. I feel like it could be helpful to consult with a professional, especially since you've checked the switches and replaced the sensors. I imagine that it even might be a good precaution since there could be something else causing the problem. http://www.advancedoorservice.com/residential
Posted on Oct 04, 2017
    New Friend:
  • 3 Answers
Check the spring above the door, mine would go up a couple of inches and we found that the spring had broke.
Posted on May 16, 2014
SOURCE: Craftsman Garage Opener /
door will not go down unless you hold down the inside botton.
Posted on Oct 14, 2008
  • 244 Answers
SOURCE: GARAGE DOOR OPENS BUT WILL NOT CLOSE AUTOMATICALLY
is bulb on motor flashing 10 times. then you have electric eye problem. otherwise, sounds like you need to increase down force a hair. adjustement is on logic board, right knob.
Posted on Jan 15, 2009
  • 244 Answers
SOURCE: liftmaster garage door opener problem
stop adjusting. you are doing right thing. unit will not run down w/o eyes so removing wiring did nothing. you gave clue when yu said they were folloded. buy new set of eyes.
ltfrc
  • 227 Answers
SOURCE: New Craftsman 95320 1/2 hp chain drive only opens door ~6"
Try this link
http://www.garagedooropeners.us/helpgifs/chamberlain_troubleshooting.html
Posted on May 25, 2009
rulds2008
  • 3866 Answers
SOURCE: Problem with Sears Garage Door Opener
The motors is cought on something check the motor if it moves inches it will move a yard the question is the motor is it getting power? if so is it stuck on its own drive chain? Check these things you be glad you did.
Btw, I’m available to help over the phone in case u need at https://www.6ya.com/expert/edwy_1a56970cf1ea4620
Garage door opener
Check photo eyes. Shut off power to units and try again
Aug 21, 2016 | Building Materials
My door closes fine, but when opening, it only
Remove the cover from the motor unit and check the drive gear. It is a white nylon gear just in front of the motor and may be stripped. If so you will also find what looks like white sawdust inside the motor unit.
May 15, 2010 | Sears Craftsman LiftMaster Chamberlain...
It moves up a few in. then stops. Then you push the button again it closes hard aginst the floor. I disconneted the dr andf it still dose the same thing.
The opener has lost track of what is open and closed. This MIGHT be due to damaged gears, but first get a manual and do the initial setup work.
You could disconnect the motor and manually move the carriage back to where is should be, then engage the motor again.
If this is a chain drive, the chain may have slipped cogs until it thinks the door is up when it is only inches up.
Jan 09, 2010 | Sears Craftsman LiftMaster Chamberlain...
Power shuts down when I try to close or open
Your motor may be working too hard anad ripping the reset button on the garage door,
Try increasing the power on the unit ( should be some type of dial.) or the door may be jamming up somewhere, Try disconnecting the opener from the door and see if it goes up easily, the door might need service
Jun 13, 2009 | Sears Craftsman LiftMaster Chamberlain...
My garage door opener moves about 8" then reverses direction before touching the limits
Remove the cover and take a look at the drive gear. It is white nylon and is just in front of the motor. It is most likely stripped. You can purchase a new one at Sears or any good door opener company. It comes with instructions.
May 31, 2009 | Sears Craftsman LiftMaster Chamberlain...
May 25, 2009 | Sears Craftsman LiftMaster Chamberlain...
Sears Craftsman LiftMaster Chamberlain Garage Door Opener Wireless Keypad Model 976LM Security+ Logo
400 people viewed this question
Top Sears Building Materials Experts
Glenn Mayer
Glenn Mayer
Mike
Are you a Sears Building Material Expert? Answer questions, earn points and help others
