Question about Hayward SAND FILTER, PRO SERIES
My Hayward S200 is leaking from the bottom. What could be the reason?
  • 1 more comment
  • Tony
    Tony May 16, 2014
    If the tank is cracked, can it be fixed or does it have to be replaced? Same with the drain cap?
  • Osko Pool n Spa
    Osko Pool n Spa May 16, 2014
    The tank can be repaired by sanding the effected area with 80 grit sand paper, completely cleaning and drying the effected area and applying a TWO-Part epoxy resin. The cap can be replaced, but first try a few wraps of Teflon Pipe tape on the drain outlets' male thread and then re-tighten the cap.
  • Tony
    Tony May 16, 2014
    Thank you for the information!
    New Friend:
  • 45 Answers
Either the tank canister has cracked, (probably from ice damage), or your drain cap is missing, loose or cracked.
Posted on May 16, 2014
I have changed the o ring three time and I cant get it to stop leaking. Two new o rings installed....still leaks. large o ring sx200z7
Had problems with these types before also. As the filter ages it warps and thats a problem lol.
You said you cleaned the recesses Im hoping top and bottom and lubricated the recesses IN addition to the o-ring, don't hold back on that lube either. And lastly although it sounds odd, dont over-tighten the nuts, tighten them slightly over hand tight turn the pump on for a bit leaking everywher tighten everywhere, leaking in one spot, tighten only that one spot a little.
Putting on all that lube doesnt do too good when it spits it out from pressure.
Also pics next time, and good luck!
Nov 12, 2015 | Pool & Spa
Hayward filter and pump compatibility
https://www.hayward-pool.com
LATEST ANTIVIRUS AND SECURITY MUST BE ON YOUR SYSTEM BEFORE ACCESSING ANY WEBSITES!
Apr 28, 2014 | Hayward Pool & Spa
Bleed valve leaks
there are no bleed valves on hayward pumps. there are freeze plugs. one is at the front of the pump at the bottom and there is another located on the side where impeller is at bottom
Jan 05, 2014 | Hayward Pool & Spa
Hayward sand s166t. leaking from bottom
Are you sure it is leaking from a spot "Originating" at the bottom? Many times this is what is seen, but the water is actually traveling down the side.
If at the bottom, you either have a cracked tank, or the drain cap is loose, missing the cap gasket or it is on "Cross Threaded"?
But... most likely from experience, it leaking at the valve clamp.
Nov 17, 2012 | Hayward S166T Pool Filter System w1 HP...
I have a hayward s200 sand filter and there is no pressure build-up to indicate a backwash is needed why
Do you have a strong flow of water back to pool? If so, perhaps pressure gauge is defective, pool water is relatively clean or particles are too fine to be captured except through multiple turnovers.
Aug 17, 2012 | Hayward SAND FILTER, PRO SERIES
My filter has nuts and bolts attaching top to bottom. I have removed all of them. Does the top lift up or does it screw off?
Holding the tank together? I assume you have an S160, S200 or S240. If so the two halves just lift appart although they usually need a good pull or pry to break the air vacuum in them. If not, please verify the model number and if you mean the tank itself or the valve on top or off the side of the unit.
John
May 23, 2011 | Hayward SAND FILTER, PRO SERIES
Hayward SAND FILTER, PRO SERIES Logo
361 people viewed this question
Top Hayward Pool & Spa Experts
Jay Finke
Jay Finke
Craig Butler
Craig Butler
Charles T Nevin
Charles T Nevin
Are you a Hayward Pool and Spa Expert? Answer questions, earn points and help others
