Question about RCA RT2770 Theater System
RCA 2270 Makes Humming Noise when plugged and nothing else hooked up to it
Have a RCA 2770 that is making a humming noise, just started recently. I did what is suggested. Made sure it was grounded, speakers were not to close. Last thing I did was take all the cables out in the back of unit and than plugged it back in still getting a humming noise. Is this something that is inside of the unit and if so what?
SOURCE: rca d52w26 makes a long whistle noise
I have an RCA model D52W26. The green light comes on when powered on but turns off within seconds. No picture, no sound. Just a squealing noise then nothing. Any thoughts on a fix?
Posted on Mar 21, 2009
  • 159 Answers
SOURCE: when my rca 36F530 tv is plugged in it makes a high pitched buzzing noise picture does not come on
There is a short circuit in the high voltage circuit. the transformer who helps to create the high voltage or his power transistor is damage. replacement needed. the repair is not expensive, because the parts are average repair. Ask for an estimate.
Posted on May 02, 2009
konzzz
  • 255 Answers
SOURCE: my RCA projection tv makes a loud buzzing, humming
buzzing noise is cause by small electrical arc inside the unit or a problem in your audio circuit.if you can open the unit up and check if its an electrical arc.
Posted on Jun 21, 2009
  • 40 Answers
SOURCE: only humming sound from speakers, rca rt 2250
If its humming no matter what on all inputs, that means the internal electronics are worn out or damaged. This can be from a number of different things and isnt worth trying to have it fixed do the fact it would cost more than just buying a new one.
Posted on Jun 29, 2009
  • 195 Answers
SOURCE: the humming noise on my rca scenium starts just a
If this is a DLP set, which I suspect it is....you need a new color wheel. Common problem for these sets. If you don't have an extended service plan, about a 300--400 fix, in home.
Posted on Oct 10, 2009
Ive got power, hot and cold to my existing pump and shower, but the pump doesn't start, just makes a whirring noise.
Above Ground Pool Pump Won't Start or is Humming & How ...
? 6:16
https://www.youtube.com/watch?v=RH78q36liks
Apr 15, 2014 - Uploaded by Above Ground Pros
Above Ground Pool Pump Won't Start or is Humming & How to Fix It ... Pool Motor - Humming-Loud Noise ...
How to fix your pool pump from humming - YouTube
? 2:43
https://www.youtube.com/watch?v=3v2v6aDDq9A
Mar 25, 2013 - Uploaded by James Hayward
Do you have a pool pump not priming (pumping water) andmaking a humming noise ... not only give a ...
pool pump makes humming noise and does not pump - Trouble F
Dec 08, 2015 | Home
Loud humming noise from right front end of 99 blazer
the noise is coming from the wheel section, it's called air splash, humming varies with speed, main causes are wheel alignment due to loose ball joint, check if your tire erodes on one side, next check your disc brake for clogged air cooled vain and disc wearing
Feb 23, 2012 | 1999 Chevrolet Blazer
The freezer has not been used for over a year,
The humming noise is most likely from vibration, check to make sure the freezer is level.
If it is level look in the back lower area there is a compressor, black component about the size of a bowling ball, make sure nothing has fallen on it or touching it causing the noise.
Apr 23, 2010 | Whirlpool 19.6 cu. ft. Upright Freezer...
Dryer won't start but makes a humming / buzzing noise when you push the start button
If the humming noise is coming from the motor, (take the back panel off) remove the power plug and try to turn the motor by hand. If it seems free, look for a 'starter' capacitor on the motor which may be bad.
Oct 11, 2009 | Dryers
Makes a clicking noise and humming when starts up
If your unit is fixed with a high speed compressor and in case you are not using a votage stablizer when ever there is a fluctuation in voltage there could be a click noise from the compressor. Do not frequently open your fridge and slowly the noise will vanish. It tells you that the unit is functioning just like our heart making thud thum thud noise when it functions and nothing to be worried about. It is normal.
Jul 06, 2009 | Refrigerators
My whirlpool top load washer will not start when I pull the knob. It makes a humming noise.
Motor sounds like its not starting up strong
May need a motor....
Jun 02, 2009 | Washing Machines
Uniden 520xl makes humming noise when mike is keyed
if you have a power mic , you might have it turned up to high. next make sure you have a good ground on your antenna. if that is ok and you still have the same problem have the swr checked. this should fix the fm radio noise.
Apr 10, 2009 | Uniden PRO510XL 40-Channels Base CB Radio
Rca home theater system reciever makes noise when turn on
is it a humming noise, or a high pitch noise, and is coming from the speakers or the receiver?
Jul 21, 2008 | Audio Players & Recorders
Denon AVR-1601 Receiver
Check capacitors in power supply......also check for over-heated
resistors..all 1 ohm.....replace if cooked...................T.
Nov 21, 2007 | Denon AVR-1601 Receiver
RCA RT2770 Theater System Logo
56 people viewed this question
Top RCA Audio Players & Recorders Experts
Gyula Lacz
Are you a RCA Audio Player and Recorder Expert? Answer questions, earn points and help others
