Question about Yard Machines MTD Gold 20 HP Lawn Tractor 13AL795T004
I have a yard machine 46 inc deck i took the deck off and now i dont remember where the pto engage blades spring goes model number 13rn771h729 yr. 2007
I took the deck off to put a plow on this winter, now I put the deck back on, but I don't remember where the pto engage blade spring goes
    Habit-Forming:
  • 25 Answers
It will be near the rear of all the pulleys probably just above top of pulleys look for a simple hole where it hooks usually a 1 inch piece of stock
Posted on May 17, 2014
  • 760 Answers
SOURCE: Can I replace the blades on my 38in MTD/Yard
If its in good condition you might be able to but be careful so mower doesn't fall on you. I've used my car ramps and backed the mower up the ramp and was able to do it safely. If you have any difficulty removing the blades, then I'd take the deck off. It really isn't that hard to remove the deck.
Posted on Oct 04, 2010
budgie140
  • 501 Answers
SOURCE: cant get the nuts off the blades on my yard
use a six sided socket,or disc cut the nuts off ,split down one side,and renew
Posted on Apr 16, 2011
hunter19_46m
  • 7482 Answers
SOURCE: yard machine lawn mower, when i start it it runs
Hi ctrsnas...
Make sure you are using fresh fuel...and oil mix if your using a two cycle mower or weedeater with the oil to the right mixture and not too much oil as it can cause hard starting.
If the mower/weedeater is over a year old, then I recommend that you buy and install a new carburetor repair kit,because the diaphragm will get hard and that will cause it to be hard to crank.
Sounds like you will need to clean the carburetor or replace your carburetor internal rubber parts like the diaphgram and O rings.
Be sure to use compressed air to blow out all the fuel and air passages.
Be careful when blowing out the passages, because there are sometimes small rubber type seats in the bottom of some of the passages.
Sometimes you can get by with priming the carburetor or using starting fluid and letting it run a few times like that and it will flush the gunk out of the jets,but most of the time you will need to rebuild the carburetor.
Keep in mind that the float for the carburetor must be level when you go to reassemble the carburetor or follow the instrucitons you get with the carburetor kit.
When you clean your carburetor and remove the jet screws, you will first need to lightly seat the jet screws.
But before you lightly seat the jet screws count the number of turns it takes to seat the jet screws from their original position.
Be sure to mark the turns down on a piece of paper.
That way when you put the jets back in, you know to lightly seat them first and then turn them back out to their orginal position before you started.
This is a FREE answer,Please take time to rate me
Posted on May 17, 2011
  • 256 Answers
SOURCE: My riding lawnmower by Yard
Hi there. It sounds to me like you have a worn drive belt. Go to http://www.mtdproducts.com/webapp/wcs/stores/servlet/OwnersCenterView?storeId=10500&catalogId=20500&langId=-1 enter your model numbers in the center field and download your manual. It will show how to remove and re-fit a new belt. Take the old belt with you when purchasing the new one. Hope this helps
Posted on Jun 04, 2011
  • 603 Answers
SOURCE: I NEED TO LOCATE A DECK FOR A 46" YARD MACHINE
You probably have in your area a number of small engine repair shops. You will have to get on the phone and start calling around for a used mower deck. They usually have many old mowers in there yards. If you decide you only want new it could be very costly. GOOD LUCK.
Posted on Jul 05, 2011
Can I get a picture of a 46" deck layout for a black mtd yard machine so I can c how the deck engagement cable go
Only seen one or two H decks here.
if it is this cable
then it connects to the RH brake assembly and the PTO engagement plate. There is also a spring that connects at the same point on the engagement plate to the right hand frame.
Apr 18, 2015 | Mtd Garden
Where do 4 springs go on 46 inch deck? The deck diagram I have does not make sense.
Hi Nick,
This may be the same diagram you already have, but this is the manufacturer engineering drawing for that deck.
MTD 13RN771H729 Yard Machines Lawn Tractor 2007 Home Depot Deck Assembly...
Aug 17, 2014 | Mtd Garden
Pto on MTDMOWERVSLOW model 670 is slowxto engage
Do you hear it kick over immediately when you pull the pto switch? Is it slow to build up RPM's of blade? I need a little more info. Could be bearings on deck going bad causing a slow rise in RPM's of blade.
Aug 01, 2013 | Yard Machines Garden
I have a 20 hp MTD Yard Machine with a 46 inch deck. I was cutting some thick overgrown grass today and the belt started smoking. I immediately disengaged the PTO gave it a minute and tried to re-engage...
you should take a picture of how the belt is on there now so you will know how to put it back on. check to see if the blades will spin freely with it not running of course. put your hand under it and spin the blade. if they don't spin you may have something wrapped around the spindles causing the blades not to spin causing the belt to smoke. if the belt is cracked or missing any chunks you may want to replace it. take a picture so you will remember how it goes back on.
Sep 18, 2017 | Yard Machines MTD Gold 20 HP Lawn Tractor ...
Mower deck PTO switch will engage when pulled but stop when rele
The PTO switch has failed. There is an internal spring and plastic parts in toggle switches that keep them in the actuated position. It's not practical to take the switch apart to fix it, but replacement switches are readily available - probably $12 - $20. It's a good idea to disconnect the negative terminal from the battery before you do any electrical work. Be sure to put the wires on the corresponding terminals of the new switch. Good luck! Please rate if you find this helpful, thanks.
Jun 03, 2010 | Husqvarna 23 Hp 48" Deck Yard Tractor
I need a belt diagram for a ranch king king plus also i need to know the size for the main drive belt
Ranch King is a brand name of the manufacturer MTD.
Product manuals with part blow-up diagrams are available from MTD's web site,
Models are identified from the model number printed on a label under the mower seat.
The PTO and deck drive belts are shown on one diagram and the transmission drive belt is shown on another. The Form number on my printed Operator's Manual is 770-10526A (22HP, 46in cut) for Hydrostatic 817/818 models.
Parts can be ordered directly from MTD or other distributors on the web.
It is my experience that original brand name MTD belts work best.
The 22HP, 46" mower deck Ranch King Pro has 3 belts:
The drive belt which runs from the engine pulley back to the hydro drive unit to provide over-the-ground propulsion is part #754-0349.
A mower has either an electric PTO or a manual PTO, not both.
The electric PTO belt the provides power to the blade deck (runs around the electric clutch on the engine shaft (activated by electric switch, not the mechanical hand lever that engages the mower deck) is p/n 754-0476 for the 46" deck.
The manual PTO belt the provides power to the blade deck (runs off the pulley on the engine shaft (activated the mechanical hand lever to the left of the steering wheel that engages the mower deck) is p/n 754-0228 for the 46" deck.
The deck belt that goes around the 3 blade spindle assemblies on the mower deck, to drive the grass cutting blades is p/n 754-0349
In my experience, the PTO belt lasts about half a season, the other belts break about every other season when mowing 4 acres weekly.
Sep 07, 2009 | Mtd Garden
G-110 deck belt keeps jumping off pulleys
check for a broken belt tension er or maybe grass clippings under belt area, check for a broken or loose pulley bearing, even a bent shaft on the deck.
Aug 07, 2009 | Mtd 46" Dozer Blade, Fits All & Yard -...
Blades won't engage. OK-I need a pto clutch
A switch should only be about $25. Before you spring for a new PTO assembly, take your switch out and take it to a shop and have it tested. I may just be a bad switch. Don't bother taking it to Sears though. Take it to a shop that works on Husqvarna and/or Poulan Pro. (Both basically same as Craftsman). DO take the model number from under the seat with you.
Jun 24, 2009 | Craftsman 24 Hp 48" Deck Yard Tractor
I need a belt diagram for my lawn mower>
If you don't have the model number, I just found a diagram for mine by Google, by typing in "MTD 46 inch deck diagram" It took me to a Parts Tree site and right to the diagram I needed. There are slight model differences but for years, the 46 inch, three blade deck has been essentially the same.
Apr 26, 2009 | Mtd 46" Dozer Blade, Fits All & Yard -...
Yard Machines MTD Gold 20 HP Lawn Tractor  13AL795T004 Logo
196 people viewed this question
Top Yard Machines Garden Experts
dannydoesita
Phil Walker
Phil Walker
Dean Gruber
Are you a Yard Machines Garden Expert? Answer questions, earn points and help others
