Question about MSI G41m-p26 Desktop Motherboard - Intel Chipset Micro Atx Socket T
MSI G41M-P26 jpwr2? if i disconnect it no power. if i connect it there is a power but no display.
Power of mother board "jpwr2" diffected
    Problem Solver:
  • 6 Answers
You don't give enough information. You need to decide if motherboard is starting up - and you can hear hard disk(s) running and accessing data, or if everything is totally dead.
If the former the lack of a display could be a fault with your graphics card.
You need to see if the power supply is running, look and see if its fan is going and then listen to see if hard disk motor is running. If these are dead try a replacement Power Supply.
If you get some text or graphics on the screen when you first turn on, and before screen goes blank, that suggests it is running and the blank screen can be due to a software problem.
If you need more help, supply more info about the fault.
Cheers.
Posted on May 27, 2014
Hi good day,i have a samsung tv un40f5500afxzp has audio but no video on the screen. i would like to find out from ur experience is it the mainboard, the t-con board or the power supply is diffective
Chances of it being the tcon are slim if you don't have sound, to find out what one it is defective remove the back and look on the power supply board pins for one that says PSON (Samsung is usually good at marking the pin voltages) measure that with the set off and then turn it on and see if that voltage changes, for example if its at 3 with it off and goes to 5volts with it on the main is working...or of its at 5 with it off and goes to a couple volts with it on its working, you need to see a change in that voltage...If that voltage is at 0 the PS is bad, also if that voltage changes the power board is bad.
Nov 10, 2017 | Samsung Televison & Video
Posiblle diffect sharp 14 L70M stand by power
Fault with main board. Damaged component/s at it. Contact any service technician; or the authorized service center. If you wish to get some details; check the site linked here. Surf the site with patience. Pull up older posts. http://electronicshelponline.blogspot.com/
Check and replace damaged component/s at its horizontal scan output section circuit. Check the LOT (Line Output Transformer) too for damage. Replace the horizontal scan output transistor. Check the input voltage to LOT. If the voltage is absent check the feeder resistor; if any.
Oct 03, 2014 | Televison & Video
When i press power switch, mother boards power became off.
mother board problem.. u have to change ur mother board or u can do 1 thing just open the restart connection.form the mother board.
Mar 29, 2011 | Intel D845GVSR Motherboard
WHERE TO PUT HARD DISK POWER PIN IN MOTHER BOARD
The hard disk power cable is to be connected to the power cables that comes from the SMBS. And only the data cable is plugged on to the Mother board
Mar 11, 2010 | Intel PENTIUM-4 865GV CHIP MOTHER BOARD...
Not able to switch on the mothere board. Green led on the board glows but the system is not powering on.
1. Check the mother board user manual 1st. To see how to properly install this mother boar to your PC cabinet or tower.
2. Check to see if you have the power from the power supply correctly connected
3. You may not have the proper watts or power from the power supply to power said mother board.
4. check the mother board battery it may not have proper voltage it should be 3.9 volts or more with a voltage meter check.
usually a 2025 button battery on the board
Feb 02, 2010 | Intel Computers & Internet
Dell Dimension 4600C will not power up
Sounds like the power supply is faulting. If not it is your mother board that has failed.
Mar 06, 2008 | Dell Dimension™ 4600C PC Desktop
Computer shuts down y by itself
remove ur power supply socket from the mother board short the pin green and black in the connector if the smps start no problen with the power supply then the problems lies with ur mother board wiring or fault in your mother board if your mother board has secondry power fix it correctly to mother board sock et with has 4 pin if its not working cousult a chiplel engineer the fault lies in the power supply of the motherboard
Dec 02, 2007 | EliteGroup 945GZT-M (V1.0) Motherboard
MSI G41m-p26 Desktop Motherboard - Intel Chipset Micro Atx Socket T Logo
89 people viewed this question
Top MSI Computers & Internet Experts
vsri9
Alun Cox
David
David
Are you a MSI Computer and Internet Expert? Answer questions, earn points and help others
