Question about Canon PowerShot S5 IS Digital Camera
How do i get my camera to start up help?
I brought my camera off of a friend and it won't start up?!?! trie putting new batteries according to the manual on canon website HELP PLEASE ?!?!??!
    New Friend:
First, do you know for sure it was working when you bought it?
Second, are your batteries all good?
Third, make sure you have all the batteries installed the right direction.
Finally, make sure the compartment door is properly shut.
I really don't know much about cameras, just advising of some of the basic things I would double and triple check first.
Posted on May 16, 2014
t00nz
  • 4738 Answers
SOURCE: Problems with the battery and the flash on my canon powershot A530
Know this is an old post but... Some of The Canon Powershot A530 and A540 cameras are subject to an advisory recall. Seems that a small spring on the battery compartment door can short out the batteries. Suspect this of yours, in that you mentioned that your batteries weren't lasting long. If your camera is on the list, Canon should fix this for you for free, including free shipping both ways. This is regardless of your camera's warranty status. Please check the following link for more info:
http://camerarepair.blogspot.com/2007/12/canon-a530-a540-with-short-battery-life.html
Posted on Dec 16, 2007
darntoothysa
  • 489 Answers
SOURCE: Canon IXUS 75
Hi
I have never heard of a memory card shorting out a camera... but I guess anything is possible.
Your camera takes a proprietary battery, it can only be inserted in one direction and will not fit if inserted the wrong way so it is impossible to reverse the polarity.
There are several things that could be wrong, ill very briefly describe them.
1- There is a small switch under the battery door beside the memory card slot, if this is damaged the camera will not turn on. Is it damaged? I've seen cameras with the switch actually missing, so if there's no small black switch visible thats most likely the problem.
2- The fuse has shorted for whatever reason causing the camera to not power. If you're really handy you can replace it yourself; they are cheap and all you need is a soldering iron with a really small tip.
3- Something else on the PCB has shorted out the camera and you need to replace the PCB. You won't find one of these for cheap easily.
Solutions?
1- Buy a defective camera online and use the parts to make one good one.
2- Go to a store and they will tell you its $150+ to send it in for repair
3- Find an online repair business that charges REASONABLE amounts: (google: darntoothysam)
4- Sell the camera online for parts and get a replacement (not the best choice I dont think)
I think we should try and repair items like this whenever we can, please don't throw it in the trash, I hate to hear about it when people do that. You DON"T have to pay $200 to fix the camera, no matter what the "Geeks" at the "Squad" tell you.
Good luck from Darntoothysam com
Thomas
Posted on Oct 13, 2008
t00nz
  • 4738 Answers
SOURCE: The rechargeable batteries don't work
Some of The Canon Powershot A530 and A540 cameras are subject to an advisory recall. Seems that a small spring on the battery compartment door can short out the batteries. Suspect this of yours, in that you mention that your batteries aren't lasting long. If your camera is on the list, Canon should fix this for you for free, including free shipping both ways. This is regardless of your camera's warranty status. Please check the following link for more info:
Posted on Jan 15, 2009
t00nz
  • 4738 Answers
SOURCE: canon powershot A430 says batteries need changing constantly
Are you still using alkaline batteries? If so, alkaline batteries just don't have the power for more than a few pictures in a digital camera. Some may also have reached their shelf life, and though right out of the package may even have problems just powering startup of the camera. Digital cameras that use AA's for the most part should only be used with rechargeable NiMH batteries. If you read the camera's instruction manual concerning batteries, you may see the same recommendation. Keep in mind rechargeable NiMH batteries will save you money in the long run over alkalines, AND they'll last for at least 100 pictures per charge (and probably many many more). You'll be very pleased with their performance, and may be angry with yourself for not buying them sooner. When at the store, look on the package for a power rating of at least 2500 mah.
Posted on Jun 15, 2009
SOURCE: I have a Canon SD1000 battery pack issue.
I have a Canondigital ixusi which had the same problem and I purchased three new batteries, but found that all of them showed the "replace battery pack" message when fully charged. I have solved this problem by cleaning all the terminals on the batteries and in the camera very thoroughly with alcohol and Q-tips. Even though the terminals look completely clean, there must be a slight film which is preventing good contact. The contacts in the camera are spring loaded and I suspect they are not making a very good conection to the battery so any contamination is making a high resistance to the flow of electricity. Hope this helps - it worked for me.
Posted on Nov 27, 2009
1998 Honda Accord Won't Start
Park neutral safety switch maybe be the reason for the no crank ! Try putting the vehicle in park ,then try to crank the engine . Testing the electrical circuit is the best way to trouble shoot this problem , along with do a voltage drop test on the starter circuit ! This will test the battery cables an connections .
Starter Voltage Drop
How to voltage drop test starter motor circuit
Does it have a manual or automatic transmission ? Manual ? clutch switch . Looking at a wiring diagram I also see a starter cut relay !
http://www.bbbind.com/free_tsb.html Free wiring diagrams . Enter vehicle info. year , make , model and engine size . Under system click engine , under subsystem click starting . Then click the search button , then click the blue link ! Check the starter cut relay also . Videos on youtube showing how to test a relay controlled circuit !
May 29, 2017 | 1998 Honda Accord
Honda Accord keeps blowing fuse and won't start
Recently we had to put a new fuse in the starter ???????????? What fuse ? location , size . A fuse blowing means a electrical short to ground .
Put in new battery and it won't turn on
Hello, Hard to tell with info given, Try new battery to determine if it is battery related or a camera failure, Batteries are cheaper than camera repairs.
Hope this helps, Russell
Dec 10, 2012 | Kodak EasyShare Z612 Digital Camera
Why won't camera switch on and red light flashing all the time i have bought a new battery but still won;t switch on and light still flashing many thanks
hi, what type of batterys have you brought as most normal batterys you buy wont even switch the camera on you need hi power batterys such as lithium or even better go into a camera shop and they will have special high power bats, normal bats wont even switch mine on so give different batts a try
let me know how you get on or if you need fyrther assistance ok
Nov 10, 2009 | Kodak EasyShare Z730 Digital Camera
Camera turns off by itself after taking a picture
A friend of mine had the same prob after putting in brand new batteries, it was i bit wierd but i tried some different batteries and it started working , try some new batteries. hope this helps.
Feb 28, 2009 | Panasonic Cameras
Cant get power to Nikon N2000
I would try some CLR on the end of a Q tip and scrub down all of the contact points to clean off any corrosion. Then I'd use the eraser end of a pencial and remove any last bits of residue. Then reinstall batteries and try it. If iyt still doesn't work, then it is not a cost effective fix. You can get a replacement used, working N2000 (or F-301...its the same camera) on eBay for no more than $25.
Dec 03, 2008 | Photography
"lens error please restart camera"
Hello!!
Remove the batteries and keep pressed the power button for few seconds it will reset ur system!!
Oct 21, 2008 | Canon PowerShot A470 Digital Camera
2000 honda accord
Start with the simple first. Check the voltage in the battery. Some new batteries are not fully charged. Next, clean the battery cables. Make the connectors shine and put a little electrical grease on the connectors.
Aug 01, 2008 | 2000 Honda Accord
Canon PowerShot S5 IS Digital Camera Logo
51 people viewed this question
Top Canon Cameras Experts
TC CAMERA REPAIR.Com...
old marine
old marine
Are you a Canon Camera Expert? Answer questions, earn points and help others
