Question about Exercise & Fitness
Startrac mod 5632 have power but no display - Exercise & Fitness
If I understand you correctly you have power going to the machine but the console does not light up?
Check the wiring harness for any loose connections or pinched wires. Treadmill Repair Fitness Equipment Repair Parts Services Fitness...
Posted on May 16, 2014
Star trac 4500 display board does not come on
You should first check the power from the wall outlet and then follow the power going into the machine -- once you find the place where the power stops, you will find the problem.
Jul 31, 2013 | Startrac Fitness Products Star Trac 4500...
Ee error list init
It' s full sheet .You can start with reloading the software with Fisps
You will need to Load Primary 8.10 and Secondary 3.30
Software and instructions can be found at:
http://support.startrac.com/index.cfm?fuseaction=software.Software
If this does not work it will require a complete new display electronics:
http://support.startrac.com/index.cfm?fuseaction=diagrams.Dia02b&typ=1&sty=1&srs=11&mdl=28&prd=1028&stc=1033&sku=9-7632-SUSAP0&dia=624&dlk=&wsr=&sid=
715-3604
May 09, 2013 | Startrac Fitness Products Star Trac Pro S...
Star trac 3901 no rpm
A complete description along with a solution can be found at the following link.
NO RPM Error and Why it Displays on StarTrac treadmill
Jan 21, 2013 | Startrac Fitness Products Star Trac 3900...
My horizon treadmill immediately stops after 2 seconds
StarTrac 4500 Treadmill NO RPM Error Probable Cause A) Damaged or misaligned RPM sensor
B) Display Cable
C) MCB
D) Filter Network
Corrective Action A) Check the connection of the RPM sensor to the lower control board. Inspect RPM sensor and disc for build up of dirt, dust, or debris. Clean if necessary. Verify RPM sensor and disc are properly aligned. Units equipped with an "optical" RPM sensor (uses plastic RPM disc) should have the disc evenly spaced between the walls of the RPM sensor. Adjust if necessary. Units equipped with a magnetic "cherry" RPM sensor (uses a metal RPM disc) should have the sensor spaced 1/8" away from the flywheel. Adjust if necessary. B) Inspect the display cable for any nicks or breaks. Replace if necessary. If there is no visible damage to the display cable, wiggle the display cable to verify intermittent connection. If by wiggling the display cable, the PWM LED on the lower control board does not flash or intermittently respond, replace the display cable.
C) Refer to the NO RPM Flowchart from the service manual for MCB testing.
D) Refer to the NO RPM Flowchart from the service manual for testing of Filter Network.
Star Trac 4500 Treadmill NO RPM Error Code
Jun 28, 2012 | Startrac Fitness Products Exercise &...
Clean or repair sticking buttons on TR4500 display
This should be a warranty issue. Sometimes the keypads fail and need to be replaced, they are not repairable. Generally you need to remove the console covers to get at them upper control board. Then you need to peel off the keypad (usually this is like a bumper sticker. There will be slots and electrical ribbons from the keypad which are inserted (pushed into) the control board. with the replacement keypad carefully insert the ribbons into the slots and stick the new pad on the console (remember you get one shot), so carefully push it down, reattach the ribbons and put the console back togethyer
Feb 13, 2009 | Startrac Fitness Products Star Trac 4500...
Star Trac TR4500 Treadmill. Need help connecting the display
I recently took mine apart if you still need the exact details.
Jan 17, 2009 | Startrac Fitness Products Star Trac 4500...
CyberXLink CXL-EBR-W router - can't open ports 5631/5632 for pcAnywhere
Hi dave, I'm not familiar with that router at all and I didn't find any doc's online for it so I'm running blind here but... If the router has it make sure "Block WAN Request" is disabled or you won't get anywhere. Also I don't know if the print server has anything to do with your problem. Have you tried mapping those ports directly to the host in the router? TCP PCanywhere port 5631 Inbound 192.168.1.[host IP] port 5631 UDP PCanywhere port 5632 Inbound 192.168.1.[host IP] port 5632 I'm also assuming that you're using a static IP on the host. You don't want to use a dynamic IP. Hope this helps. Let me know how you make out, Duder
Nov 17, 2006 | cyberxlink (CXLEBRW) Wireless Router
Exercise & Fitness Logo
Top Exercise & Fitness Experts
Electro Med Services...
Howard
Howard
Tom Chichester
Are you an Exercise and Fitnes Expert? Answer questions, earn points and help others
