My ipad will not take a charge - Audio Players & Recorders
  • 778 Answers
Hello, Take out the battery on the ipad and let set for 2 mins. Put back in and see if works. Either your power cord is bad or the battery is bad.
Posted on May 17, 2014
IPad will not charge even though battery and charge port both replaced.
Incorrect port part, Wrong polarity for wires connected to the port or poor connection of wires to the port.
Nov 30, 2015 | Apple iPad 64 GB 3G Tablet PC
My apple ipad is not reponding when iam charging it how do i reset it
If you charge your iPad on a power adapter, the iPad should respond while charging, except if your iPad battery is so low the apps need more power to run.
If you charge your iPad on the USB port of your computer, it is normal you cannot use your apps as the iPad is not only in battery charging mode but also in synchronizing mode with iTunes in the computer. You should lose the habit to charge the iPad on the PC and use a dedicated power adapter instead, as dedicated power adapters charge the iPad battery 2 to 4 times faster than the USB port of most computers.
USB port power: 2.5 Watts in general (5 volt x 0.5 A = 2.5 Watts)
iPhone charger: 5 watts
iPad charger: 10 or 12 watts
Jul 26, 2014 | Apple iPad 32 GB WiFi Tablet PC
Why wont my ipad charge
To charge an iPad you have to connect the USB cable to iPad power adapter (12W in power and is bigger in size compared to iPhone's). If you connect it to iPhone power adapter you might see that the iPad is not charging, but will take a very long time to charge. The same goes with connecting directly to computer.
Also, there is always a chance that either your cable, or adapter or the iPad itself has gone bad.
May 28, 2014 | Apple iPad Tablets & eReaders
Charger shortage
Hello Dominique,
I would make sure that the charger connection is not damaged on the Ipad.. also I would look into charging on a different outlet, the one you are using might be loose inside and not holding a charge when moving..
May 08, 2013 | Apple Ipad 3 16gb Wi-fi Only Md328ll/a...
Ipad 3 will not charge
To get Ipad to show as charging download Asus AiCharger from web and restart computer after install.Plug in usb from Ipad and should now show charging.
Nov 05, 2012 | Apple iPad (16 GB) WiFi Tablet PC
In mine ipad its charging?? is ther is any solution to charge my ipad??
You can charge your iPad with the default USB cable and power adaptor it came inside the box. Just note that if you were to connect your iPad to a computer it will show up stating 'Not Charging', this is expected product behaviour because the computer is not providing enough power to the iPad to charge it. And it will only charge if you use the USB cable it came with, not an iPhone cable or iPod cable. Hope this helps :)
Oct 30, 2012 | Coby MP-610 MP3 Player
My ipad wont charge , icon shows it's charging but it not ?
To get Ipad to show as charging download Asus AiCharger from web and restart computer after install.Plug in usb from Ipad and should now show charging http://event.asus.com/mb/2010/ai_charger/
Oct 12, 2012 | Apple iPad (16 GB) WiFi Tablet PC
How do I charge the iPad battery.
USB hubs typically don't generate the 10 watts necessary to charge an iPad when it's connected to your computer. This basically means you can't use your laptop to recharge your iPad.
Apple recommends finding an AC outlet and using 10-watt power adapter that came with your iPad.
Jan 08, 2012 | Apple iPad2 WiFi 64GB
Apple Ipad won't charge
the ipad will charge with the charger that comes with it
if you want to charge it with the cpu you have to turn off the ipod before it will charge
Press and hold sleep /wake button
til it says slide to power off
Feb 11, 2010 | Apple iPad (16 GB) WiFi Tablet PC
81 people viewed this question
 Grubhead
Grubhead
