Question about Ace Hardware Ace; Table Saw with Stand
Where would the reset button be located on an Ace Hardware table saw model No. 60701073
2 Suggested Answers
eugbug
  • 479 Answers
SOURCE: I have a $120 10"
It's possible that the brushes may have worn out or a bad connection may have developed in them or at the brush holders. Open the motor, check the brushes and look for any overheating. One of the windings may have gone open circuit in the armature of the motor and in this case it probably isn't worth repairing.
Posted on Mar 12, 2011
Craftsman model 137.415030 10 in portable table saw won't turn on. It is getting power the switch sounds like it is working ok but it won't turn on. The reset button ,does not appear to do anything.
My table saw motor just stopped.. What do I do? - The WoodenBoat ...
forum.woodenboat.com/showthread.php?...table-saw...I...
WoodenBoat
Apr 6, 2013 - 23 posts - ‎20 authors
Does the motor have an internal thermal cutoff switch? ... Auto reset on a table saw, now that would be scary. ... A Craftsman, I think. ... The saw is a Grizzly 1022Z contractor-style saw about 10 years old. .... After the motor cools down the switchneeds to be pressed to restart the motor, it won't start suddenly ...
My table saw stopped, the reset button won't reset. What ...
www.shopyourway.com > Manage My Life > Questions
It is a Craftsman Table Saw Model 137.248880. ... I pressed the reset button and the saw restarted. I continued ... My table saw stopped, the reset button won't reset. ... One was just the switch the other the rocker switch, identical except in cost.
Craftsman 10 table saw motor stalled - Yesterday's Tractors
www.yesterdaystractors.com > Discussion Forums > Tool Talk
Dec 25, 2015 | Craftsman 21802 10-inch 13-amp Portable...
My ace 27193B table saw won't start. I have blown all the dust out but the reset button dosen't seem to work. Suggestions?
Just a guess...
Table saw motors' start-up amperage is pretty high and there's a lot of arcing that you can't see that happens between the ON/OFF switch contacts. The switche's contact points eventually get burnt away.
Sep 24, 2014 | Saws
I have a $120 10"
Mar 11, 2011 | Ace Hardware Ace; Table Saw with Stand
I haven`t used the saw in a year, should I lubricate the motor bearings? Something is making a sqweaky sound when I turn on the saw.
Unplug the saw. Look inside the blade housing for any foreighn objects. if it is clear, shoot some oil into the bearings and work it in well.
Feb 25, 2011 | Ace Hardware Ace; Table Saw with Stand
My very old Craftsman 10" Table Saw does not power on. While rip cutting some plywood, I errored and caused the blade to bind. Before I was able to power off the saw, the motor stopped. I thought I had...
Go to searspartsdirect.com and put in your model number. Look at the motor and wiring section. Look at item 16. The motor overload protector. (probably your reset button) WIth saw unplugged, unwire one sid of this switch and test with an ohm meter. You should read through the switch. If it is open then that's why the saw doesn't work. Many of this type of oveload requires quite a push to reset as you're flexing a klixon disc back to make contact. If is open and you can't reset, it's available there although a bit high priced.
Aug 13, 2010 | Craftsman 10" Table Saw
Hi, I'm look for a reset button for sears craftman table saw, model 113-298-051, or part number
Owners manual is available here.
Per page 15, reset button is just to the left of the on/off switch on the front of the saw chassis.
If this answer helped, please give it a vote.
Jun 12, 2010 | Craftsman Saws
Could not locate reset button. do all models have a reset button?
most do,however to be sure use a small mirror to look at the bottom.of unit.button is usually off center, and square.
Apr 26, 2010 | Ace Hardware InSinkErator Badger 5, 1/2 HP...
The saw wont cut all the way through the wood. Why?
first off what is the blade diameter and the wood thickness?? Also do you have the table adjusted for the maximum depth, It is one of the 3 items mentioned.
Jan 30, 2010 | Ace Hardware Power Glide Circular Saw with...
Where can I find a blade bolt for a Chicago Electric Power Tool Chop saw?
Take the model number and serial number to Ace Hardware. They should be able to look it up for you and get the correct bolt in.
Jan 16, 2010 | Ace Hardware Ace Chop Saw Cut - Off Blade
Ace Hardware Ace; Table Saw with Stand Logo
Top Ace Hardware Saws Experts
Bill Boyd
Tom Chichester
ray gallant
Are you an Ace Hardware Saw Expert? Answer questions, earn points and help others
