I can not receive or make calls my phone repeatedly says ck.tel line done condition remains the same
How can i take care of the matter please i need my phone
    New Friend:
  • 24 Answers
Pull the battery out , replace battery after 30 seconds , then reboot the phone , it is a software glitch, my phone was doing the same thing
Posted on May 16, 2014
Pls i need configuration settings for nokia 7210 supernova
you have to call customer care of your service provider(airtel,attnt, and much more ) to receive the configuration setting for your model 7210 supernova like mms , gprs and mail service, just you have to infrom them i need configuration setting for mms or gprs , they will ask your phone model, just tel your phone model they will send setting through msg, r else they can tel manual setting option too.
Good luck ! if your problem is solved don't forget to rate
Dec 30, 2010 | Computers & Internet
How do i set up fax to automaticely receive faxes after several rings
For a phone line dedicated only to the fax machine, the process is as follows:
  1. Press Menu/Set, 0, 1.
  2. You will see the Fax Receive window
  3. Use UP and DOWN arrows to change the setting to FAX ONLY
  4. Press Menu/Set.
  5. Press STOP/EXIT
Your fax machine will now answer every incoming call.
If the fax machine is sharing the phone line with a telephone, repeat the above steps and change from FAX ONLY to FAX/TEL This option will allow you to share the line with a phone only, not an answering machine. Once in FAX/TEL mode, the fax machine will still grab every incoming FAX call, and give a special ring (slightly different than a regular telephone ring) when it's a regular incoming phone call signaling you to answer the phone. I hope this helps with your problem. Best of luck!
Greg
Nov 11, 2009 | Brother IntelliFax-2820 Laser Fax
Brother fax 4750e can not receive or send fax. sender said the line just ring and ring endlessly
To set up for receiving Fax, do the following:
Press Mode button repeatedly untin Fax and Fax/Tel lights are lit.
Faxes will automatically print and answering machine will take the calls. If you have a dedicated fax line, do the following:
Press Mode button repeatedly until just the FAX light is lit. Then the machine will answer every call as a fax.
Apr 23, 2009 | Brother IntelliFAX 4100 Laser Fax
We can send faxes but we can not receive faxes. The fax machine that sends the fax tell it that our line is busy. Is that a machine problem or a phone line problem?
Problem lies in your Receive Mode setting. If you don't have a dedicated phone line for the fax machine, you need to set it up for either Manual where you answer every call or Fax/Tel whereby the Fax machine determines if the incoming call is a fax or phone call. Instructions per Intellifax 4100 Manual.
Select a Receive Mode
Choose the mode that best suits your needs by pressing the Mode button
repeatedly until the FAX and FAX/TEL lights show the setting you want to use.
Manual
You must answer every call yourself.
The Brother machine must be started manually
to receive faxes.
Fax
For use with a dedicated fax line.
Every call is answered as a fax.
Fax/Tel
For receiving fax and voice calls on one line.
The FAX answers every call and receives a fax or
double rings for you to pick up a voice call.
TAD
For use with an answering device.
The TAD answers every call and stores voice messages.
Fax messages are printed.
Apr 20, 2009 | Brother IntelliFAX 4100 Laser Fax
Receiving and sending faxes
if the fax is connected to the same line and you have a phone connected to the fax you need to make sure you connect the line from the socket at wall to the correct socket on the fax you can check this by looking at the point the line is connected on fax there should be two connectors one says line and one says tel.. the line in goes to the line socket and your telephone goes into the tel socket.. if you have them the other way round it cant connect properly..on the front display panel make sure you have it set to the auto setting or tel fax mode for receive.. if you have it to auto it will check the incoming call if it is a fax it will send it through if not it will ring till you answer.. if set to tel/fax mode when it rings you will have to answer the phone and manually press start if you hear it is a fax.. Good luck A
Mar 04, 2009 | OKIFAX 4580 Plain Paper LED Fax
Connecting problems
Is it set to auto receive, is the tel line plug into socket marked line not tel. Is it used on a dedicated line, no extensions, if using ADSL you must have filter on line. If plugging standard phone in place of fax is dial tone heard and line is noise free, can you ring and speak fine on line using a phone. Is machine set to correct dial format for your country ie pulse or tone. When did it stop, have you had storms, phone work done, has it worked on this line before? I take it it copys ok is that correct.
My bet is A noisy phone line or B set to manual answer. More info equels better help, but I am short of free time now..
Feb 02, 2009 | HP LaserJet 2840 All-In-One Printer
Can't receive a fax but can send one. My machine model number is MFC-9700
There are three different receive modes for your MFC. You may choose the mode that best suits your needs by pressing the receive mode repeatedly until the LCD shows the setting you want to use
if the setup is only for faxing no other telephone lines on the line then select fax only.
if there is a telephone on the same line your gonna want to select Ext.Tel/Tad
if you are wanting to control the phone line and must answer every call yourself by uing a external phone select manual
manual you can use with distinctive ring as well so you can know what is a fax and what is a phone call.
let me know if this works or not please describe your setup if further troubleshooting is needed.
Aug 08, 2008 | Brother Office Equipment & Supplies
Brother 575
set the reception mode button to fax not fax/tel
Aug 29, 2007 | Brother FAX-575 Plain Paper Thermal
Computers & Internet Logo
24 people viewed this question
David Payne
David Payne
