Question about Garden
The 2 cycle mix goes separatly from the gas - Garden
  • 778 Answers
Hello on 2 cycle the oil is mixed with the gas. Users manual tell how to mix ratio.
Posted on May 17, 2014
Troy-bilt TB525ET 4 cycle??
no you do not mix gas but there is a type of oil that goes in the back of your engine called the houle and im not sure if its 4 meaning regular oil or 2cycle im thinking its 2 because as the engine runs it mixes on its own to create a so called 4 cycle which to everone ive talked to on the outside is a week engine im being told that 2cycle engine has alot more tourque if you want to get a job done quick and it look good
Feb 21, 2012 | Troy-Bilt 4-Cycle Curve Shaft Gas String...
Excess white smoke coming from exhaust of TB 75SS string trimmer
This model is a four cycle engine meaning that it does not a mix of gas and 2 cycle oil. You just fill it like your lawn mower, gas and fill the crank case with oil
May 25, 2009 | Troy Bilt Tb425cs 26cc 4 - Cycle Curved -...
Gas and oil mixed in 4 cycle backpack leaf blower
If it is a 4 cycle blower, you do not mix oil with the fuel....It takes straight Gas. there is an oil cap to put engine oil in crankcase, this only usually takes 2,3,4 oz. of oil. Sounds like your Spark Plug probably fouled out from having oil mixed in your gas. I would recomend changing your Spark Plug and put some Fresh GAS only in the blower, dump the old stuff out !!! You should be on your way Blowing in No Time !
Nov 27, 2011 | Troy-Bilt 32cc 4Cycle Backpack Blower
What kind of gas
Regular unleaded gas mixed with 2 cycle oil. (You need to check your model for mixture ratio but 30:1 (thirty parts gas to one part oil mix) is usually a good place to start) You can find mixing instructions on the back of the 2 cycle oil container
Dec 08, 2010 | Garden
Do you run straight gas through it
No, gas chain saws use a 2 cycle oil gas mix, it should say on the chain saw fill or on a bottle of 2 cycle oil the mix or ratio of oil to gas mix.
Dec 03, 2010 | Garden
PP 22inch 625 series 190cc - What Gas/Oil mix should i be using?
I think your mower has a 4 cycle engine. That means the oil goes in the crankcase and the gas goes in the gas tank. No oil mixing needed! If you look at the top of the mower you should see two caps. Each one will be marked with what goes in them.
The oil should be 30 weight non-detergent oil. Available at your local car parts store or Lowes or Home Depot.
Gas is just plain old pump regular.
Oct 09, 2010 | Poulan Pro 22inch 625 Series Briggs ...
Gas mix?
Straight Gas no mix for a 4 cycle.
May 16, 2010 | Troy-Bilt 4-Cycle Curve Shaft Gas String...
Need to know gas mixture
Yours is not a current model and I did not find a manual. The following is an excerpt from a 26cc MightyLite Blower/Vac UT08550/UT08951 "Operator's Manual":
This product is powered by a 2-cycle engine and requires pre-mixing gasoline and 2-cycle lubricant. Pre-mix unleaded gasoline and 2-cycle engine lubricant in a clean 1 gallon container approved for gasoline.
Recommended fuel: This engine is certified to operate on unleaded gasoline intended for automotive use.
Mix Homelite Premium Exact Mix lubricant with gasoline according to the instructions on the package. If Premium Exact Mix lubricant is not available, use a high quality synthetic 2-cycle engine lubricant, mixed at 2.6 oz. per gallon (US).
Do not use automotive lubricant or 2-cycle outboard lubricant.
NOTE: Premium Exact Mix fuel mix will stay fresh up to 30 days. DO NOT mix quantities larger than usable in a 30 day period.
PREMIUM EXACT MIX (50:1)
GasolineLubricant
1 gallon (US) 2.6 oz.
1 Liter 20 cc (20 ml)
If properly adjusted your blower will operate fine on 50:1 regardles of what the manual reads. HTH
Lou
Jan 29, 2010 | Homelite Consumer Products Backpack...
I guess he needs to know what kind of oil he needs also
you shouldn't need to mix oil with gas on a four cycle engine. this is for two strokes.
Aug 23, 2009 | Garden
Garden Logo
26 people viewed this question
Top Garden Experts
Dennis Key
Dennis Key
roeb
john h
