Question about ADPK Dual Mode Camera
Dual mode camera driver windows xp
Driver Windows xp
    Sergeant:
  • 171 Answers
Download drivereasy and search for missing or updated drivers
Posted on May 30, 2014
Is the Pandigital SCN02 Photolink One-Touch Scanner compatible with Windows 8?
Are you using it currentrly? What is your current Operating System? I've been searching and can't see anywhate a windows 8 driver for this scanner.
Bu let me tell you, I'm using currently a Genius ColorPage, originally released for windows 98. Installed windows 2000 driver in compatibility mode for findows XP. There is no driver for Windows XP nor for Windows 7 and coldn't make it work in Windows 7. So I run it on a computer with dual bootWindows XP / Windows 7.
When I need to scan, I simply start up as windows XP. When finished scanning, reboot to windows 7
I Have Windows 7 on a 2 Tb HD SATA and Windows XP on 200 Mb IDE. Is more economical to have a dual boot then buy a new Scanner.
If your scanner won't run on windows 8, install on another HD or a partiton, Windows 7. doual boot Windows 7 / 8 work like a dream.
See comments for this scanner in Amazon;
Amazon com Customer Reviews Pandigital SCN02 Photolink One Touch Scanner...
Jun 11, 2015 | PANDIGITAL Office Equipment & Supplies
Driver for traveller is 12 digital camera.My computer has now Windows 7 OS, but i cannot find a driver vor my digital camera "Traveller IS 12". My former computer was with Windows XP and it was workin
Using Windows XP Mode, you can run programs that were designed for Windows XP on computers running Windows 7 Professional, Enterprise, or Ultimate... Go here (microsoft web site) to find out how to ... It's not super easy, but neither is very hard to do.
http://windows.microsoft.com/en-us/windows7/install-and-use-windows-xp-mode-in-windows-7
Nov 22, 2013 | Cameras
I used twinkle cam successfully in windows xp. I have upgraded to windows 7. How do I get the driver or will anything work?
According to http://www.chicony.com.tw/download/di/driver.asp , the available drivers were written in 2004. Chicony has stopped supporting their cameras for newer Windows OS versions. I suspect they never made a 64-bit version of the driver for XP 64-bit.
If you had the 32-bit version of Windows 7, you might be able to use the compatibility mode to install the driver. To check your version, click on Start > Control Panel > System and Security > System. Look for your Windows version and check if it says x64. If you see that in the description, you have the x64 bit version. Otherwise, right-click on the driver file from the above site (after extracting the files from the zip file). Choose Properties and the Compatibility tab. Check the box for always Run this program in the compatibility mode and set it to Windows XP in the drop-down menu. You may need to repeat this on the camera software as well.
If you have a 64-bit version Windows Home Premium, you may be better off upgrading to Windows 7 Pro or Ultimate. Then you can download and install Virtual PC and the XP mode, if your hardware can handle that software. This gives a virtual version of the 32-bit version XP that will run your camera. (The CPU needs to have virtualization support and it has to be enabled in the BIOS. Then you need enough memory to give the virtual XP at least 512MB -1GB of memory.) If you already have Windows 7 Pro or Ultimate, just use XP mode. Other virtual PC software exists but they require a licensed version of XP. (If you can find a valid license.) The only issue I've found is that files saved to the C: drive in one OS can't be accessed by the other OS. You have to transfer the files with an external drive, flash drive or burn the file to optical disc.
Dual boot systems with XP and Windows 7 can be set up if you have the XP license. Then pick the OS you need when you boot up the computer. This requires you to repartition the hard drive or have two bootable hard drives. Make sure to back up before partitioning the drive.
I wish that I had better news for you.
Aug 22, 2013 | Chicony TwinkleCam DC2110 Webcam
I have notebook acer aspire 5741g and window7, ATI Mobility Radeon and I have no problem. Now I want to work Windows XP. I look for compatible drivers.
I would suggest that you download and install the FREE XP mode for Windows 7. That way you can easily move back and forth between Windows 7 applications and XP applications.
You can also install the FREE XP virtual machine on your Windows 7 and have an XP computer on your Windows 7 computer. Works great and much better than Dual Booting. I
If Windows 7 is working with no problems on your Windows 7 installation your ATI Mobility Radeon will function fine under either XP Mode or a Microsoft XP virtual machine.
http://www.microsoft.com/windows/virtual-pc/download.aspx
Give it a try. It is very easy to install and use.
Jul 02, 2011 | Computers & Internet
Picco 2000 drivers for win7 ultimate 64-bit
Pico2000 Drivers
There aren't any drivers for windows 7 as of yet. But a solution would be to use Windows XP mode or have a Windows XP/Windows 7 dual boot system set up, then you can just install the xp drivers and it will work.
Jun 03, 2011 | Computers & Internet
I need the software to run it.
The manual and driver for supported OS versions are here: http://www.dxgusa.com/downloads . The manuals for all of their cameras are listed first and then the drivers. They are listed in order so the DXG-572V driver is in the third line, third from the right of the driver section.
The driver may not have been updated from the original which for Windows XP/ME/2000/98SE. In Windows Vista 32-bit the driver may work or the correct driver may be in the OS. For Windows 7 32-bit, use the driver built into the OS. (Microsoft's compatibility center provided the information.)
With the 64-bit versions of these newer versions of Windows, the compatibility is unknown. However, the driver from the DXG site will probably not work without the compatibility mode, if it works at all. For compatibility mode, right click on the exe file and choose Properties, select the Compatibility tab and set it to run as Compatible with an older version of Windows. Then right click and Run as Administrator. Otherwise, keep it on a computer with the older OS, use a dual boot with the older OS or a virtual computer with an older version of Windows. With Win7 Pro or Ultimate, you can use the XP mode for a free virtual computer. (Download and install Microsoft's Virtual PC and then XP mode; install the camera to the virtual computer.) All other methods will need a licensed version of an older version of Windows. The only issue with the virtual computer is that files can't be shared between the two computers directly. Put them on external or optical media to share them with the real computer.
I hope this helps.
Dec 14, 2010 | DXG Technology DXG-572V Digital Camera
Olympus Camedia 4.0/ C-4000 Zoom and Windows Vista Operating System
Doubt the software will work on Vista. If you do have the disk, before you click on the install program, right click it and use the "XP compatability" mode. I would dual boot to an XP partition to take care of all your XP needs. Its a bummer but that is what Im doing...
Feb 25, 2008 | Olympus Camedia C-4000 Zoom Digital Camera
Computers & Internet Logo
52 people viewed this question
Top ADPK Computers & Internet Experts
David Payne
David Payne
Are you an ADPK Computer and Internet Expert? Answer questions, earn points and help others
